Salter PS250 digital floor scale. Male 5 pin XLR plug was pulled off the cable from the display unit (not the scale platform). I can re-solder the connections but need the color code/pin numbers for the wires. Wires are red, green, blue and yellow but none of the colored insulation remained on the plug to indicate which wire was on which pin. Thanks Phil
    Genius:
  • 1,340 Answers
I see your problem and am about to shut down.What I would like to suggest for now is that if you can carefully remove the back from the display and I would think the female in there would match color for color with the plug that was pulled.If you do not want to try that,I could research it as well as possible tomorrow.The display most likely is screwed down and secured well enough so that it won't fall to pieces if the back is taken off.If that doesn't work or doesn't appear right if you do open it,let me know.Good luck Phil! Greg.
Posted on Aug 07, 2010
  • 9 more comments
  • obiecat596 Aug 09, 2010
    Sorry for the slow response. Unexpected delays. Thanks for the suggestion. It almost worked but not quite. In this case, the female side is also on a cable. So, access was fairly easy, other than a lot of hot glue type material was used as additional strain relief when it was manufactured. It covered all the pins/wires, obscuring which color went to which pin. Once I cleared away enough material to see the pins, it turns out they used different color wires on the female side for some reason. The cable has 7 colored conductors, plus a braided, unjacketed conductor. On the damaged, male side, it's obvious the soldered wires were green, red, blue, yellow and braided. On the intact female side, pin 1 is brown, pin 2 is orange, pin 3 is white, pin 4 is green, pin 5 is braided. So, it looks like I really need a schematic for the display/male side to know which wire goes to which pin. Do you think that info is available or am I out of luck for DIY repair? Hope that's enough info. Let me know if you need more.
    Thanks again,
    Phil
    Thanks again,
    Phil
    Thanks again,
    Phil
    Thanks again,
    Phil
    Thanks again,
    Phil
    Thanks again,
    Phil
    Thanks again,
    Phil
    Thanks again,
    Phil
    Thanks again,
    Phil
  • Greg McCarthy Aug 09, 2010
    It's okay about the response.I have searched for schematics for many items and they are not available for free online.User manuals yes.A lot of good that does.The wire colors not matching up,I guess they want you to pay for it to be repaired or something,who knows.It's BS.It is best probably to replace it.You could try calling the manufacturer to see if they will provide the information or see about a price for a schematic.TV makers will not even allow access to consumers for that information.I couldn't find their site but it is worth a try to see what they will offer you for information.
    Thanks for the info. I thought it might be hard to find. I'll keep looking for a bit. I've got a couple options. The item is too expensive to replace at this time.
    Thanks again. Phil
How do I clear the 'L' error on my bathroom Salter scale. I have changed the battery but I cannot get the error to clear.
new batteries? or one's that have been sitting around.
they may be low.
what they say to do...
1.
Open the battery compartment on the scale underside.
2.
Remove isolating tab from beneath the battery (if fitted) or insert batteries OBSERVING the polarity signs (+ and -) inside the battery compartment.
3.Close the battery compartment.
4. Select kg, st or lb weight mode by the switch on the
underside of the scale.
5.For use on carpet attach enclosed carpet feet.
6.Position scale on a firm flat surface. next......
INITIALISING YOUR SCALE
1. Press the platform centre and remove your foot.
2.'0.0' will be displayed.
3.The scale will switch off and is now ready for use.
This initialisation process MUST be repeated if the scale is moved. ie battery replacement.
Feb 14, 2018 | Salter Health & Beauty
One of the male pins on the unit for the antenna broke off. Is there a part that I can get to fix this, maybe the whole male pin unit is one part?
Hello, is the broken pin on the back of the unit or is it on the antenna cable plug? If it is on the unit and not the cable, you would most likely need to replace the connector that is attached to the PC board inside, which extends through the back of the case. This would require knowledge of soldering / desoldering pc boards, etc. and would be best performed by a "bench technician". There are no "user replaceable" plugs available.
Feb 17, 2012 | Standard Horizon Cp180 Chartplotter
My microphone has has disconected from the plug, how do i fix it,the wire
It can be replaced, but if you are not used to a solder iron, I'd recomend buying a new cable off the shelf. Either female XLR to male XLR or Female Xlr to TS (large 1/4inch jack) depending on what you wish to plug into
Sep 07, 2011 | Shure SM58 Professional Microphone
I have a Salter 307 kitchen scale. Are there any instructions for disassembling this unit? Removed 6 + 1 screws and I still cannot open the unit. Please help!!
How to open up the Salter 3007 Aquatronic Digital Scale:
1. Look for a hole (covered by a label) on the bottom of the device, not far from the L-R centre line, and about 1-3/4" from the front. Peel back the label and use a small cross-head screwdriver to loosen the screw that can be seen though the hole (needs about one turn, no need to remove it). Place the scale upright, and rotate the weighing pad slightly in a clockwise direction. This will disengage the tabs on the plastic pad which hold it to a metal base, so that it can be lifted off. 2. Remove the six screws recessed around the bottom of the scale. 3. Place the scale upright and gently "snap" apart the top and bottom shells (catches molded into the left and right ends). Be *** VERY CAREFUL *** when doing this as the display is held in place on a plastic bridge by the upper shell. When this is removed the display is loose except for a flexible plastic printed connector strip (which links it to the circuit board). It is *** all too easy for this strip to break away at one end or the other ***.
Apr 01, 2010 | Salter 3007 Aquatronic Digital Scale
I need to know how to wire an xlr y adapter
I always solder it this way.
Take a female XLR connector, two thin sym. cables and two male XLR connectors.
Solder both cable parallel in the female connector and the ends on the male connectors.
This way you get the same signals on both inputs of your amplifier.
Regards,
Gerard
Oct 26, 2009 | Behringer EUROPOWER EP2500 Amplifier
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
Wires in the microphone at the point where you connect to the lead have come appart and i need to solder them back on, Black, red and white wires. Which in which order do i solder them onto the connecter...
There are many standards of microphone connectivity with 3 pin XLR (cannon) style plugs. It depends on where in the world you are as to the favoured standard,
Your microphone usesthe following::
Pin
1 ground (white) 2 +ve or hot (red) 3 -ve or return (black)
Another way to work out what wires connect to what, is to remove the cover of one of your XLR-XLR microphone cables exposing the connections it favours, plug the connector into the mics scoket , and use the connections to the cable guide you in resoldering the connections back on.
The same connections can be veiwed in the user manual here
Please rate this solution. Cheers
regards robotek
Jul 15, 2009 | Behringer XM1800S Professional Microphone
SE2200a rapid signal drop off
I had the same problem with my Saffire: the phantom power voltage quickly drops when switched on, causing the mic to cut out. This problem is common in older Saffires, and is well known to Focusrite support (a modification in newer-production units solves the problem).
The problem is that a tiny 100 ohm surface-mount "chip" resistor in the phantom power circuit fails due to insufficient power-handling capability. (This is "R196" in the phantom circuit.)
The fix is to replace the "chip" resistor with a "normal" 1/2 watt metal-film resistor (with wire leads), mounted upright on the circuit board.
I replaced the resistor myself, following directions (and photos) sent to me by Focusrite Tech Support.
The procedure is somewhat fiddly (a Swiss watchmaker could probably do OK). If you've never soldered before, DON'T EVEN TRY THIS, and if you've never worked with surface-mount components, I would ask your electronics-hobbyist buddy to do it for you.
Here is the procedure sent to me by Focusrite:
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SAFFIRE PHANTOM POWER MODIFICATIONS
Dismantling the Unit
Remove the 7 screws on the rear panel.
Remove the 4 screws on the underside of the unit.
Lift away the metal cover.
Remove the 4 small black screws securing the MIDI In/Out sockets.
Remove the single screw securing the S/PDIF In/Out sockets.
Remove the two screws securing this PCB to the chassis.
Gently pull the PCB away from the rear panel and move it through 90 degrees towards the front panel.
Place the unit on its front and support the PCB with some suitable non-conductive item.
Modification Procedure
All the components mentioned are located in the same area on the same PCB (see photo).
It is best to remove the coil and capacitor (as shown in the second photo), as this gives easier access to the components.
Remove R196 and measure its resistance. If it does not measure 100 ohms, replace it.
Use a conventional type (100 ohms metal film, .5 or .6 watt) mounted upright as shown in the photo. Before fitting this resistor, check that the three zener diodes DZ11, DZ12 (22v) and DZ9 (3.3v) are OK and have not shorted out. (Diodes are 500mW, 5% tolerance)
Testing units for Phantom Power problems
Connect a condenser Mic or suitable dummy load* to Channel 1.
Engage +48 switch.
Measure the DC voltage between XLR pins 2 & 1 on Channel 2 Mic Input XLR.
Faulty units usually read around +28Vdc and the voltage gradually drops.
Good unts will measure +48Vdc +/- 0.7Vdc.
* Dummy Load for testing: Solder a 20,000 ohm resistor between pin 2 and pin 1 of a male XLR plug and another 20,000 ohm resistor between pin 3 and pin 1 of the same XLR plug.
Here are the photos:
My Saffire has worked perfectly since I replaced the bad resistor.
Good Luck!
Ken
May 04, 2008 | SE Electronics SE2200A Professional...
41 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
