Question about NetGear DG834G Router
Netgear-virgin net connection
When setting up router asks for ip address but virgin say theres change?. got primary and secondary dns but cant connect
    Problem Solver:
  • 6 Answers
Select obtain ip address automatically in the settings,,
Posted on Apr 27, 2008
I CANT ACCESS A FEW SPECIFIC SITES.
Hi Pauline,
Try different using a different DNS address. OpenDNS provides free, fast servers that are used by millions. Here's how to do it with and without a router in your set up:
WITHOUT A ROUTER:
Mac OS X
  1. Go to System Preferences.
  2. Click on Network.
  3. Select the first connection in your list and click Advanced.
  4. Select the DNS tab and add 208.67.222.222 and 208.67.220.220 to the list of DNS servers.
  5. Click OK
Windows 7
  1. Click the Start Orb, then select Control Panel.
  2. Click on Network and Sharing Center.
  3. Click on your primary connection or Local Area Connection under Active Networks.
  4. Click the Properties button.
    Windows 7 may prompt you for permission to make network setting changes.
  5. Highlight 'Internet Protocol Version 4' and click Properties.
  6. Click the radio button 'Use the following DNS server addresses:' and type 208.67.222.222 and 208.67.220.220 in the Preferred DNS server and Alternate DNS server fields.
  7. Click OK button, then the Close button, then Close again. Finally, close the Network and Sharing Center window.
    At this point, we highly suggest that you flush your DNS resolver cache and web browser caches to ensure that your new configuration settings take effect.
Windows XP
  1. Select Control Panel from the Start menu.
  2. Click Network Connections from the Control Panel choices.
  3. Choose your connection from the Network Connections window.
    If you have more than one, choose your default/current connection.
  4. Click Properties button.
  5. Select Internet Protocol (TCP/IP) and click Properties.
  6. Click the radio button Use the following DNS server addresses and type 208.67.222.222 and 208.67.220.220 in the Preferred DNS server and Alternate DNS server fields.
  7. Click OK
Windows Vista
  2. Click on View network status and tasks.
  3. Click on View status.
  5. Vista may ask for your permission to make changes. If so, click the Continue button.
  6. Select Internet Protocol Version 4 (TCP/IPv4), then click the Properties button.
  7. Click the radio button "Use the following DNS server addresses:" and type in OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in the Preferred DNS server and Alternate DNS server fields.
  8. Click the OK button, then the Close button, and the Close button again. Close the Network and Sharing Center window.
WITH A ROUTER:
Generic Router
  1. Open the preferences for your router. Often, the preferences are set in your web browser, via a URL with numbers (example: http://192.168.0.1). You may need a password.
    If you're like us, and you set the router password long ago and cannot remember it now, you can often reset the password to the manufacturer default by pressing a button on the router itself.
    Or preferences may be set via specific application for your router, which you installed on your computer when you added the router.
  2. Find the DNS server settings.
    Scan for the letters DNS next to a field which allows two or three sets of numbers, each broken into four groups of one to three numbers.
  3. Put in the OpenDNS server addresses, 208.67.222.222 and 208.67.220.220, as your DNS server settings and save/apply.
Linksys Router
  1. Visit the router's IP address in a new browser window.
    http://192.168.1.1 is the default Linksys router IP address.
  2. Enter the Network password.
    The "Enter Network Password" window will appear. Skip user name and type the router's password (admin is the default password, if you haven't changed it) and click the OK button.
  3. Type in OpenDNS addresses, 208.67.222.222, 208.67.220.220, in Static DNS 1 and Static DNS 2 fields.
  4. Click Save Settings button.
Netgear Router
  1. Type the router's setup URL (http://www.routerlogin.net, http://192.168.0.1 or http://192.168.1.1) into a web browser address bar.
    http://192.168.1.1 is the default Netgear router IP address.
  2. Enter the password.
  3. Type in OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in Primary DNS and Secondary DNS fields.
  4. Click Apply button.
  5. Wait for the settings to be updated.
D-Link Router
  1. Visit the router's IP address (http://192.168.0.1) in a new browser window.
    If you are attempting to configure a D-Link router, take note of your computer's Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. Most D-Link devices use the 192.168.0.X range.
  2. Enter the router password.
    Note: if you have not changed the original settings, the default username is admin and the password is blank (nothing).
  3. Click on the Manual Internet Connection Setup button at the bottom.
  4. Enter the OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in Primary DNS Server and Secondary DNS Server fields.
  5. Click Save Settings button at the top.
Oct 07, 2014 | Computers & Internet
How do I set up the ecb350 as a repeater. I have an xfinity wifi that doesn't reach the whole house but I can connect with an Ethernet cable to the back of the ECB350 out in the area I need wifi acce
What are you using for your main router (xfinity wifi)? The best way is to set the ecb350 in AP Router Mode not a repeater since you have a rj45 cable long enough to go from one of the ports on the xfinity wifi router and hook it into the ecb350. You will need to know what your ip address range is for example if the xfinity is 192.168.1.1 then you want to assign a static address for the ecb350 to be 192.168.1.100 (assigned IP Address) You will also need the Subnet mask, Default Gateway IP Address, and Primary DNS and Secondary DNS of the xfinity wifi router. Then on the ecb350 you will need to configure the following with the info you go off the xfinity router:
Static IP Internet Connection Type Select Static IP to begin configuration of the Static IP connection. Account Name Leave Blank Domain Name Leave Blank MTU Auto IP Address ie: 192.168.1.100 (assigned IP Address) IP Subnet Mask Specify the subnet mask of your Xfinity Router Gateway IP Address Specify the gateway of your Xfinity Router Primary DNS Specify the primary DNS server's IP address of your Xfinity Router Secondary DNS Specify the secondary DNS server's IP address of your Xfinity Router Discard Ping on WAN Check to Enable to recognize pings on the ECB350 WAN interface or Disable to block pings on the ECB350 WAN interface. Note: Pinging IP addresses is a common method used by hackers to test whether the IP address is valid. Blocking pings provides some extra security from hackers. Accept / Cancel Click Accept to confirm the changes or Cancel to cancel and return previous settings. Note: Clicking Accept does not apply the changes. To apply them, use Status > Save/Load Hope that this help you.
Sep 10, 2014 | EnGenius ECB350 Wireless-N Indoor...
Connect tv to network
Get them from the net gear router if you can.
Or one of the PC's connected to the network.
the subnet and the router you need will be identical to that of the PC.
the only change you need to make to the IP address is to make sure that the last octet is different to all others on the network.
The IP address is made up of 4 octets. looking something like 192.168.1.28
or similar. In this instance 28 is the last octet.
DNS is not required for this setup.
Nov 19, 2013 | LG Televison & Video
I have a Sylvania netbook SYNET7WID. I've entered the DHCP, Primary and seconary DNS, IP addresses, sub-net mask, SSID, password, network key and pass phrase. This piece of junk says I am connected but...
that will depend on the problem on why you cant connect
please reply with this values:
IP address
Subnet Mask
Default Gateway
DNS Primary:
DNS Secondary:
also check if you have mac filtering "on" on your router.
Mar 24, 2011 | Computers & Internet
Need to set up wireless router
you have two ways:-
  1. DHCP (Dynamic Host Control Protocol)
  2. Manual entry of settings in wireless adapter properties.
1.DHCP:-
In DHCP method you dont have to enter any settings on the wireless adapter. The wireless network which you are connecting will automatically assign an IP Address to you. But to use DHCP it must be supported by your wireless network.
This method is mostly used over wireless Connection in small networks connecting 2-200 computers. In this method you have to obtain the following information from your connection provider.
  • IP address (Its format is "xxx.xxx.xxx.xxx")
  • Default gateway address (very important)
  • Primary and secondary DNS (If not given then you can use "8.8.8.8" as primary DNS and "8.8.4.4" as Secondary DNS...thats free DNS service from google and its very fast)
  • Subnet Mask (not needed mostly...automatically generated)
Sep 25, 2010 | NetGear WNR2000 Wireless Router
Unable to connect to internet via router.Computer says signal strength is excellent.diagnostic check highlighted DNS problem.I think VIRGIN (my isp) have recently changed their DNS nos. Virgin (my isp)...
If you're using an ADSL connection the details you need are below.
Settings for an ADSL connection through a telephone line.
Open a web browser and log onto your router.
Find Internet Wan > Connection Type.
Set the Router to use PPPoA, type in your User Name and Password in the spaces provided. If you do not have a Service Name or do not know it, leave the Service Name field blank. After you have typed in your information, click "Apply Changes". After you apply the changes, the Internet Status indicator will read "Connected" if your Router is set up properly.
WAN > Connection Type PPPoA
User Name > firstname.name@adsl.virgin.net (or virgin.com or whatever)
Password > *******
Retype Password > *******
VPI/VCI > 0 / 38
Encapsulation > VC MUX
MTU > Leave as Default
Find Internet Wan > DNS.
Select Automatic from ISP
(Virginmedia DNS servers are Primary: 194.168.4.100 Secondary: 194.168.8.100)
Find Lan Setup > Lan Settings
Ensure DHCP Server is set to On
If the details entered are correct the router will show connected and the internet lamp will be green.
Do the configuration on a wired connection.
Jun 19, 2010 | NetGear WGR614 54Mbps Wireless Router...
Netgear wireless n modem router type DGNB2100-100UKS problem dropping out on games when playing on xbox live
You can consider following steps to for the x-box live with netgear dgnb2100:-
a)Get any computer which has the internet access to it , Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go.
b)Enter the username and password for the router (Default username is admin and password is password).
c)You will be navigated to router administrator page , you will have a blue/purple column on the left hand side which has the different setting options in there.
c)From the browser Main Menu select Advanced and then the sub-title WAN Setup.
d)Under WAN set up,check the box for Default DMZ Server enter the server's IP address[192.168.0.20] the corresponding box for the IP Address.
e)Click Apply.
ON X-box live:-
a)Open the main menu and under setting's select wireless set up and then select manual setting's , it will ask to enter the following information:-
ssid(broadcast name)
security type(wep/wpa-psk) and password to it
ip address:-192.168.0.20
subnet mask:-255.255.255.0
default gateway:-192.168.0.1
Primary DNS:-192.168.0.1
Secondary DNS:-leave that blank and apply the setting's
b)Go for the connection test and it will have the successful connection.
This Link will be of great help:-
http://kb.netgear.com/app/answers/detail/a_id/1118
Nov 28, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Netgear SmartWizard Help
Is there an option to use a dynamically assigned IP address (also called DHCP)?
That's most likely the option you need, almost all home Internet providers use DHCP to assign the information you are asking for automatically to your Internet connected device (in this case, your router).
Let me know what options are available to you if neither Automatic or DHCP is.
Thanks!
Mar 29, 2009 | NetGear WGR614 Wireless Router
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
NetGear DG834G Router Logo
224 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
