I have problem to my printer showing Scanner Error 5 turn off then on please need help
    Genius:
  • 1,089 Answers
You need a tech to check out or replace the scanner. It might be something simple, like a loose wire harness, or just a bad flatbed scanner assembly. Most likely an error code 5 is the the connector with the 2 blue wires over the formatter. Try reseating it. You didn't say what kind of printer you have. So this is just guess work.
Posted on Aug 07, 2010
Solving scanner error 5
If you are using windows - go to Printers / Devices and uninstall the printer
Turn the printer off and wait a couple of minutes
Now turn on the printer
Now add the printer in windows again and it should work
Jun 30, 2017 | The Office Equipment & Supplies
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
HP m2727nf scanner error 5
Hi Anataloi,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp 1800-334-5144 , if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Jun 25, 2010 | HP Laserjet M2727nf Multifunction Printer
After I turn it on it shows an error messaje
there are problem in scanner assembly. please clean care fully and properly of your scaner unit.,than its ok.,
May 10, 2010 | HP Laserjet M2727nf Multifunction Printer
My A940 All-in-One shows a Cartridge error 50C and also shows that the colour cartridge is missing when it is not can you please help tried looking through manual but cannot find what a 50C error is please...
Hi there Error 50c
All the best of luck
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jun 17, 2009 | Dell A940 All-In-One InkJet Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
My printer show this code 2 E 7
I have problem with my scanner.
when I want scan whith that show this message:
cannot communicate with scanner
cable may be disconnected or scanner may be turn off.check status.scanner driver will be closed. code : 21550
please help
Jun 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Scanner error message hp laserjet 3030
my hp 3030 printers shows warning up bulb and make noise how can i solve it ?
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
k24674
jasbo
jasbo
Marvin
Marvin
