Question about D-Link DP-300U (DHDP300U) Print Server
I have installed PS 300 U on my network it works fine with window XP. With windows 7, the PS 300U is not discoverable in the list of printers. However in My Network and sharing center it is listed with all the devices on my network. I am also able to take a test print via the PS web based configuration tool. How do I add the PS to my Printer list?
    Genius:
  • 1,354 Answers
Hi
go to following link you will find your solution for PS-300U
http://social.answers.microsoft.com/Forums/en-US/w7hardware/thread/3874def4-fcf9-4513-af38-98aa33793cc2
Posted on Aug 07, 2010
Dymo labelwriter turbo model 90479 driver
You can download the Windows 7 Driver here:
http://www.dymo-label-printers.co.uk/dymo-labelwriter-drivers-windows-7.html
Note: you don't say if it is a 300/400/450 series, but if it's a 300 series and the model is NOT listed in the compatible printers on that page then there is NO SOLUTION - your printer simply will not work with Windows 7 as Microsoft dropped support for the old USB chipset in this OS...
ps. there is a server problem at the moment so if you can't download 8.4 try 8.3 it will still work just fine.
Apr 11, 2012 | Dymo LabelWriter Office Equipment &...
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
HL-2170w won't print with Windows 7
Windows 7 will not work with earlier Windows versions of printers
Feb 28, 2017 | Brother HL-2170W Laser Printer
Using windows 7. Have a Zebra LP2844 printer connected to another windows XP computer. Unable to print to it across network. Zebra prints fine from all other computers on network.
I dont think this model has a Windows 7 driver. You can check the Microsoft hardware compatability list to see if your printer is listed.
Apr 23, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Windows 7 and Linksys wireless print server
Step for installing Network print server in windows 7.
Click Windows "Start button"
Select "Devices and Printers"
Click "Add a Printer" button
Select "Add a Network, Wireless or Bluetooth Printer"
Printer wizard will searhc for all network printer including wireless.
Select "The printer that i want is not listed"
Select "Select a shared printer by name"   (Make sure you have shared the printer you want to connect)
Type the IP address of the printer if it ia a printer.
If it is printer that is connected to a PC then type like this below
\192.168.0.50printer shared name where 192.168.0.50 is the IP address of the PC where the printer is connected.
Click Next and if you want to Send a test print you can try that too,otherwise click "Finish".
That's it.
Jan 02, 2010 | Dell Inspiron 1545 Notebook
When i install the printer driver on windows vista is not working
there is a problem on working with software in windows vista. .
try to install the windows XP
Jul 25, 2009 | HP LaserJet P2015 Printer
Bluetooth not working after OS re-install on Lenovo 3000 Y500 lap
if you install xp then find out the xp drivers in www.lenovo.com > select country > support and downloads > model number> etc. After downloading file >install the driver > after installation reboot your computer > after machin on you just switch on the wifi or bluetooth switch (near you laptop hinzes) and try it.
Mar 17, 2009 | Lenovo 3000 Y410 Notebook
Dell 1600n All-In-One Slow Printing
Most times the PCL driver will work just fine for printing .pdf documents. Occasionally you will need to us a PS driver to print .dpf docutments. PCL was designed to work best with MS Word, Excel, etc programs and PS drivers were designed to work best with Adobe .pdf.
One way to see if you have the PS driver already installed, is to (in Windows XP) start>control panel>printers and faxes>in here look for an Icon that represents your printer that has PS in place of the PCL. If this is installed then when you go to print your docuement, choose this icon to print with.
If you do not have the PS driver already installed, try adding the printer to your system. You would do this by (Windows XP) start>control panel>printers and faxes>add a printer wizard>Next>Choose your connection(local or network)>Next>Select a printer port>Next>Install Printer Software(If you have downloaded the most recent drivers, choose have disk and navigate to where you saved it. If you have the CD, use have disk and navigate on the CD to where the PS driver is>Next>You may or may not get the next window asking you to choose whick model of printer you are installing, it varies from printer to printer. From here it is pretty straight foward, just read the wizard and click next. The last step you will need to click finish for the drivers to actually install.
As a side note, not all printers have a PS driver available.
Feb 23, 2009 | Dell 1600n All-In-One Laser Printer
Error: Printing data is inaccurate, printing processing is stopped Printer error page is printed with this error prints fine from the webpage printer is installed on windows 2000 over a network
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Aug 22, 2008 | Sharp AR-M207 All-In-One Laser Printer
Problems installing a printer
what is your operating system? If you have windows XP or Vista, you dont need to download anything from Epson. Just go to your start menu and look for control panel. In control panel, open "printers and faxes" or "printers and other hardware" then "printers and faxes". Once you are in "printers and faxes" click Add Printer...
An "add printer wizard" will appear in a new window, click next...
On the next screen, choose local printer. And make sure that the option "Automatically detect and install..." is selected. It will start searching... If the wizard did not find the printer, it will come up with a list of manufacturers... From this list choose EPSON and a list on the right side will show you the model names. Look for the LX-300 on the list, it should be there! Install it and you're done... The driver is already included in the windows operating system. You dont need the disc if you have Windows Xp or Vista....
Jun 27, 2008 | Epson LX-300 Matrix Printer
D-Link DP-300U (DHDP300U) Print Server Logo
250 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
