Question about JVC AV-48P575 48" Rear Projection HDTV-Ready Television
Power problem My television will not power on. The fuse by the plug is good. When I unplug it and plug it back in I get a clicking sound, but it will not power on.
  • 1 more comment
  • tonyb73 Apr 27, 2008
    I don't see any loose connections on the board. When I plug it in it makes the clicking and the power light flashes on and off. Also the television stopped working while it was on. Thanks for your help.
  • bobrobele Jun 22, 2008
    I was watching tv when it just shut down the power light is flashing and there is is a popping noise
  • mrbigpg55 Aug 08, 2008
    Hi tv was working then shut down on own No power. When unplug and plug in again and switch on power light in front of comes on for a second or two then I hear a clicking noise and power shuts off on own. Please advise probelm if relay needs to be replaced and if this is a expenisve job to do. Bill
    Problem Solver:
  • 14 Answers
Dear tonyb73,
Try to check the relay in your power supply, it might have a loose solder or loose connection at the back of PC board. The sound that you hear when you plug is the relay itself. if your set newer , check for loose connections on pins and other connecting parts of relay. That is located in the power supply section. If nothing happened after resoldering, then replace the relay, probably the contact points is corroded or damaged.Hope this will help...pls. send feedback so we can work together.. Thank you....
Good Luck..
Posted on Apr 27, 2008
TV won't power on
Could be an open internal fuse or power supply failure
Jan 03, 2017 | Philips Televison & Video
TV does not power on. For the last several months I would have to unplug it then plug it back in to get it to turn on. It makes a clicking sound when plugged back in similar to the same sound it normally...
I have similar problem with my 42hds69. What I did is unplug the tv and remove the cover and vacuum everything especially the fan and remove the power supply board and brush/vacuum the back side... careful about static so hold the metal frame while you're vacuuming. Reassemble everything... mine worked... and still working... Good luck.
Aug 04, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Not power not picture or sound
If its Dead Dead ,that mean no power is getting past the fuse :> then it needs a fuse
.30 vs 300.00-400.00
Ok there is a way of telling if its posibley
just a fuse . First no blinking lights ,good
no clicking sound from the set when you
try to turn it on .good
now unplug the set for about 30min
the plug it back in slowley if you
see and or hear sparks coming from
the plug , this is normal but bad news
for it being just a fuse , if you dont
see or hear a spark its likley just a
5-8 amp fuse blew inside the set. :>
Hope this was helpful
Jul 02, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My TV does not power up when the power button is pressed.
It's sounds like your lamp or backlight has went out, I suggest reading your manual for service info and look online for a local repair shop.
May 16, 2009 | Televison & Video
No power to tv after unplugging and replugging
either the fuse is burnt out inside or the the problem is the power supply board. You can remove the back cover to see if the fuse is good or not.
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture, no sound, power light steady green
First: Check the power outlet. Check it with a good lamp so you know you are getting power to the set.
Secondly: Check the power cord. Wiggle it around the molded ends to make sure it is not open inside the molded portion of the plugs.
Thirdly: If you know for sure the set is getting power and still no indication at all (you should be getting some little light on the front panel; standby indication) then there may be a fuse on the back panel or just inside the back cover (you will have to remove it; after unplugging the power cord) that needs replaced.
Fourthly: After all these checks if you are getting nothing, you may have some failure inside that is very serious. Normally we do not recommend serious repairs to a set over 4 years of age. This is because the set is likely to develop some other problem soon after the repair is made; further, the repairs are getting more expensive day by day while the price of new sets is coming down dramatically. Lastly, the new sets have better picture, longer lasting circuits and better features.
Hope this is a good solution for you.
thanks for your questions.
Aug 25, 2008 | RCA HD52W56 52" Rear Projection HDTV
It makes a clicking sound when i press the power button but dosent turn on
Good Day, nhl1fan;
The TV is getting power and the main fuse is okay. Try unplugging the TV from the outlet for 3 to 5 minutes then plug back in A/C outlet.
If no fix your TV has something inside that is shorted (drawing too much current), then call an authorized Service Center to give an estimate before proceeding with the repair.
Good Luck, big IRISH.
Aug 20, 2008 | Televison & Video
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Hitachi 50dx10b
Try unplugging and plugging back up the power cord to reset it.
May 14, 2008 | Hitachi 50DX20B 50" Rear Projection...
JVC AV-48P575 48" Rear Projection HDTV-Ready Television Logo
178 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
