Question about Nokia 6300 Cellular Phone
I want to update my nokia 6300 firmware..what should i do?
  • 6,831 Answers
Hello
At the link below you will be directed to a tutorial i wrote on how exactly to update the firmware of your Nokia Handset. Click on the link below to navigate to the page.
Click HERE.
Please feel free to share your thought, to help me better the tutorial.
Kind regard
Lock123
Posted on Dec 11, 2010
Hi there.where can i find v5.50 software for nokia 6300?
My understanding is all upgrades are available by using the Nokia 'Phone Software Update' available on their support site. If you simply want to upgrade, I recommend using that.
Link to Nokia's support for the 6300 is HERE
Hope that helps.
Mar 03, 2011 | Nokia 6300 Cellular Phone
Nokia6300automaticswitchoff
hi dear. hope this solution will solve ur problem. In most cases this happened because of software problem. Kindly update ur firmware to solve this issue. go to this link http://mea.nokia.com/support/download-software/device-software-update and select ur device which is Nokia 6300 and then download this Nokia Software Updater software. install it on ur pc and connect ur phone with PC via data cable. then update ur phone and i hope ur problem ill b solved.
Oct 15, 2010 | Nokia 6300 Cell Phone
I want to update it software version via USB cable
Nokia 6300 firmware update
Subject: how to update firmware for Nokia 6300 to the latest official version
1. You need download and install NSU - Nokia Software Updater (http://europe.nokia.com/support/download-software/device-software-update/download#) and run it to ensure that all is ok! (don't forget to switch on and connect Nokia 6300 via USB with PC)
2. You need to download and install NSS (Nemesis Service Suite) (http://www.b-phreaks.co.uk/index.php?main_page=page_2), the latest version of NSS was 1.0.38.15 (select "Virtual USB Device" mode)
3. Close NSU if it's not closed and load NSS then click icon "Scan for new device"
4. Click icon "Phone Info" and button "Scan" inside it
5. If all is ok you'll see some lines with Phone Version, Phone IMEI and so on
6. Click button "Read" and remember your "Product Code"
7. If your want to clean your phone go to tab "Tools" and switch to subtab "Factory Setting", choose option "Full Factory" then press button "Reset" (NOTE!!! all personal data and settings will be cleared!)
8. Return to tab "Phone info" and type in the field "Product Code" the following code 0537621 (or any code from (http://www.expansys-usa.com/ft.aspx?k=96957)) for version 7.21, or code 0557624 (or any code from (http://www.a2phone.com/6300-rm-217-dp20-900-sw-0730exe)) for version 7.30, select option "Enable" then press button "Write"
9. Close NSS, run NSU
10. Now NSU should update firmware to version 7.21/7.30 (or any latter build) (http://europe.nokia.com/support/download-software/device-software-update/can-i-update)
11. Repeat stages 3 - 5
12. Type in the field "Product Code" the code that you remembered before, select option "Enable" then press button "Write"
13. Close NSS
14. Use you clean phone with new firmware!
Mar 17, 2010 | Nokia 6300 Cellular Phone
I usung nokia 6300 and iam dowloding opera .opera not work my nokia 6300 and how to up grade my nokia 6300
hi may be the opera you are downloading is not suitable for your handset its better for you to not download opera
I bought Nokia 6300b RM-222 with firmware version 4.71, but now the latest firmware is 7.30 (or any latter build). But Nokia Software Updater (link) told me that I already had latest firmware and refused to update my phone. Below I described the steps to upgrade Nokia 6300b RM-222 from version 4.71 (or any other version) to version 7.21/7.30 (or any latter build).
13. Close NSS
Mar 15, 2010 | Nokia 6300 Cell Phone
My nokia 6300 standby time is only 6 hours even w/ new battery
Update the phones firmware to V 07.21..U will get a better standby time.. :)
Mar 12, 2010 | Nokia 6300 Cellular Phone
Hi! My screen is white when turn on the phone. When I removed sim and memory card and turn on again, I see fabric black/gray background but can not see menu or any other commands.. Thanks in advance..
It seems to be a corrupted firmware. Nokia allows you to update the firmware over the net. How???
Fully charge the battery, backup the data on the phone, Connect the phone to the PC through a USB cable only. Start Nokia PCSuite and allow a few seconds for the suite to connect to the phone. It will display on the suite that Nokia 6300 is connected. Click on update firmware and follow instructions. When suite finishes, your phone would be as good as new. Restore the data to the phone.
For more info read the following link.
Updating the Phone Firmware (Nokia)
Dec 11, 2009 | Nokia 6300 Cellular Phone
How to update flash player my nokia 6300..
hi,
Nope, the flash player is embedded with the firmware. Only if they update it via the firmware.
Remember that the Flash Player in the Nokia devices is a version of Flash Lite so it's not the same as what you use in the PC.
check for latest firmware for your 6300......and update it if it is there....
thank you,
vijay
Sep 29, 2009 | Nokia 6300 Cellular Phone
What will happen if i update my NOKIA 6300 software? because my cell phone getting off frequently,, please help me
if you know exactly how to do it (many good forums around with very clear explications), updating your firmware will install latest (stable) firmware. if your problem is strictly software related (having installed and deleted many program, messed around with it a lot) this will definately be good for the phone. if the problem is hardware related (just getting old, defective etc.), there might be a chance a new firmware helps out a bit. In any case updating a firmware (if done properly) can never harm your phone.
Jun 21, 2009 | Nokia 6300 Cellular Phone
Nokis 6300
You've tried to turn off the phone and turn it back on I believe ?
Otherwise try and use the Nokia Software Updater to update the firmware on your phone, this should solve your problem.
You can get the software-updater for free of the Nokia-website.
Sep 21, 2007 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
