Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
Says it needs formating but windows wont format sandisk cruzer 4g
    Genius:
  • 1,234 Answers
Hello , welcome
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Posted on Aug 28, 2010
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How can i format sandisk cruzer blade 2gb
Hello
OK, at the link below you will be able to get step by step instructions on how to format your flash drive.
Click HERE.
Kind regards
Andrea
Sep 04, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer Micro 2GB Usb Flash Drive. Windows was unable to complete format!
Try this:
STEP 1 - Optimize the flash drive for performance
1. Plug in the device to the PC.
2. Double-click My Computer.
3. Right-click on the flash drive, then select Properties.
4. Click the Hardware tab.
5. Select the SanDisk Cruzer USB Device disk drive, then click Properties.
6. Click the Policies tab.
7. Select Optimize for performance, then click OK.
STEP 2 - Format the flash drive
1. Double-click My Computer.
2. Right-click on the flash drive, then select Format.
3. In the File system list, click NTFS.
4. Click Start.
5. Click OK to start formatting.
Jan 13, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I havent used my scan disk cruzer in months and now i plug it into my computer and it lights up but i cant open it up to retrieve or put info on it
Try cleaning the USB pins with cotton swab to clean all copper connectors in it.
If the above solution doesn't work, you may need to do Low Level formatting to it.
Low Level Formatting is very much different than High-Level Formatting (High-level formatting occurs during operating system installation, or when adding a new disk.).
Low Level Formatting on Windows Environment can only be done through "Control Panel > Administrative Tools > Computer Management" or Run "compmgmt.msc".
On the Computer Management Tools window click on Disk Management under Storage.
Select which drive your SanDisk Cruzer is located then Right click select Format... from there you may choose what File System to use. i advise you to use Fat for a fixed formatting.
Hope this helps. Don't forget to rate.
Jan 06, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When I plug in my Sandisk Cruzer 4GB USB it says format it, when i try it says windows can not finish formatting. What shall I do?
Your Sandisk Cruzer 4GB USB can no longer be formatted. It is damaged or corrupted by virus. The only thing you can do is change it.
Oct 14, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How format SanDisk cruzer Micro 8GB
copy the files to you're pc, and if you use windows just go in my computer and right click on the flash disk icon and click format check the quick format box and the press format.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
4g sandisk (wont format)
I'm not sure but did you try to go to my computer: right click the partition and check off (if it stands) protect or hidden
May 27, 2009 | SanDisk 4GB microSD High Capacity Memory...
Window cannot complete format for sandisk cruzer micro 2 GB
san disk can not formated because showing error windows cannot format
Jul 15, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
123 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
