Question about Lexmark X1150 All-In-One InkJet Printer
Lexmark printer lexmark x1150 will not print in color ink, black ink ok!
  • fish 4 Apr 28, 2008
    yes I try a test page and I clean the ink cartridge but no color ink printed
  • 3,587 Answers
Hmmm..did you try a test page?
Posted on Apr 27, 2008
  • Patrick Michaels
    Patrick Michaels Apr 28, 2008
    hmmm..take out the print cartridge, and look at the bottom..make sure there is nothing on that surface, including the tape that comes with it when it's new.
Lexmark Series X1150 My printer does not recognize the color print cartridge and only prints in Black even though the color cartridge is new. First time this has ever happened. I've had the printer...
Make sure you are inserting the correct color cartridge versions for the Lexmark X1150 (either #26 or #27).
Try to clean the cartridge nozzles. On your computer, open the Lexmark Solution Center, click Start > Programs > Lexmark X1100 Series > Lexmark X1100 Series Solution Center. From the Maintenance tab, click Clean to fix horizontal streaks. Your printer will then print a page that will help clean the nozzles from possible dirt and clogs.
If that doesn't help, try to insert a different known working cartridge (e.g. your old cartridge or another new cartridge). It could be a faulty cartridge issue.
Sep 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
Got a lexmark x1150 both black color ink been replaced not reading black ink and text is blurry
Hi. The cartridges may have not
been seated properly in the
carrier or just needs cleaning. Here's an article in the Lexmark website to give you instructions on how to clean the nozzles of the cartridges. It has some graphics to help you better understand the instructions. Just click on this link: . Hope this helps.
Mar 17, 2010 | Lexmark X1150 All-In-One InkJet Printer
My lexmark 1150 won't print and I've lost cd and don't have the manual book. Would it have any thing to do with because I put in ink cartridges 17 and 27 and it requires 16 and 26 ink cartridges.
It works with both 16 and 17 for Black and 26 and 27 for Color.
Go to the Panel from Lexmark X1100 series- Series Solution Center and select the new type of cartridges. Allign the cartridges, make an excel test with 4 colors(cyan, magenta, yellow, black) and it should work
If you need further assistance, do not forget to post and don't forget to rate.
Thank you
Feb 27, 2010 | Lexmark X1150 All-In-One InkJet Printer
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Printing from computer
check the cable connections and re-install the driver/software
go to lexmark website and get the latest driver for your operation system.
Also when you print, make sure you are printing to this printer
print from word-pad or any other program OTHER than internet.
Jan 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Works great but won't print.
not good folks..check driver first. Also, would be helpful to have the operating system indicated for more effective help
Dec 11, 2007 | Lexmark X1150 All-In-One InkJet Printer
Black ink
Did you remove the tape from the cartridge when you installed it?
Has it ever printed black from this cartridge before?
You may need to wipe the cartridge with a moist paper towel at the place where the ink comes out. If there is dried up ink the nozzles could be clogged. Try running the Lexmark Solutions Center from the Windows Start menu (Start -> Programs -> Lexmark 1100 Series) and make sure the black ink level is good. You can also select "Clean Nozzles" in there and that may help.
Oct 15, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
