Question about Electric Mobility Health & Beauty
Unit will not charge more than half way, I've replace the batteries and the problem sill exists
    President:
  • 2,030 Answers
You either have a bad ground or a bad charging unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 07, 2010
Alternator replaced and car is sill running off the battery and not charging
IF you used a 2nd hand alternator then it may be as you say --a bum unit. Have it bench tested as there may be a problem in the regulator or diode pack or it may be that the unit needs an external regulator to work . Have it bench tested at an accredited auto electrician shop.;
Apr 12, 2014 | 1999 Nissan Altima
2008 Yamaha TTR230 Draining Battery
Replace your battery with new one because your existing one most likely became faulty with age.Even if you charge it it wont last. It is time for new one.
Feb 16, 2014 | 2008 Yamaha TTR230
New stator and regulator flat battery after journey
What model motorcycle motorcycle is it. I have had a simular problem one time with a customers motorcycle customer brings the bike in for the same problem i charged the battery then checked the charging all normal could not find the problem so asked the customer to take it for a ride being he lived close to the shop it did it again he brought it in and checked it it was charging normal so i just let it run and heat up checked the charging no charging. It was the stator when it hit a certain temp it stopped working you may want to try the same test.
Oct 26, 2012 | Triumph Daytona 600 Motorcycles
Garmin 255w i replaced the battery, symptons of charging
Hello
There sill be a battery symbol in the forner of the screen which sill indicate advancing the charging signal [very like battery signal of a cellphone] in green color. You can see it on its manu page. To increase the accuracy of the battery guage, gully discharge the battery and then fully charge it. Do not unplug the Nuvi, until it is totally charged. Connect the vehicle power cable to the mini USB connector on your Nuvi and to a power outlet in your vehicle. The vehicle key may need to be turned ON/ACC for Nuvi to charge.
Connect an AC adapter [optional accessory] to the nuvi and a wall outlet.
Connect your Nuvi to a computer using a USB cable. The computer must be ON for the nuvi to charge. OK.
Jan 12, 2012 | Garmin nuvi 255W GPS Receiver
Backup power ends quickly even with new battery
What is the load on the unit? How old is it?
The symptom can occur if the load is too large. It will also happen when the unit reaches a certain age.
I've found that the low-end consumer UPS's should be replaced when the battery fails. The charging circuitry usually fails to charge the battery even with a new battery soon after the replacement.
The way I check if the battery or the UPS charging system has failed is with a voltmeter to give the current voltage and a variable DC power supply (whatever is appropriate for the battery) to attempt to charge the battery. I can watch the battery discharge with an oscilliscope if I want a full trace of the unit.) Charge the battery fully then watch the unit over time. If the battery itself is bad, you won't get the full charge or it will discharge as soon as it is removed from the power supply.
I hope this helps.
(the server UPS's tend to be a better choice if you want to replace the battery and keep the UPS.)
Aug 21, 2011 | APC (BE500U-WEB) (BE500UWEB) UPS System
Battery not charging warning light showing
mcdevito75 here, The replaced alternator should have a warrantee, bring it back to the shop that replaced it. If you did the work yourself and even if it's a rebuilt, you should still be able to exchange it. Some manufactureres recommend a new alternator and not rebuilt, plus if you"ve added any moe electrical items you"ll need a stromger alternator (higher amp).
Jun 16, 2010 | 2001 Ford Focus
Hace a APC XS 900 that said battery needs replacement, unit is about a year old. I replaced the batteries & it lasted about 2 hours & again says replace batteries. I know the new batteries are OK...
disconnect one terminal of the battery then measure charging voltage betwen +ve and -ve it should be 13.8vdc for one 12v battery if charging voltage is not present then battery is ok then connect ammeter to measure the current in Ampere .take care it should be in series if current if no current then battery must ok opern the ups there is a charger transformer measure i/p voltage to transformer if not present then check i/p path if present then check diodes at o/p of charger if faulty replace it also check capacitor and regulator ic if faulty replace it your problem must be solved
Mar 13, 2010 | APC Back-UPS XS900 (BX900) UPS System
Is not charging replaced alternator but is sill not charging. is there an external voltage regulator
what year vehicle ,it would have to be early 70s for an external regulator .Fit a genuine Bosch exchange unit rather than a junk yard unit then it might work
Jan 09, 2010 | 1995 Volkswagen Golf
Health & Beauty Logo
16 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
