Diamond Audio Technology EMC2.0-USB. How can I install?
  • SmartAviator
    SmartAviator Oct 24, 2015
    Hi airbornegonz, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Anonymous Apr 25, 2016
    How do I hook these speakers up?
I need a manual for Diamond Audio's D971 component speakers, I need the thiele small parameters of these speakers
General •Speaker type car speaker Manufacturer Diamond Audio Technology Inc. Features •Amplification type passive •Driver configuration 2-way •Woofer size (inches) 7" m, 30mm m •Nominal (RMS) output power 200 Watt •Max (RMS) output power 400 Watt •Response bandwidth 35 - 30000 Hz •Input impedance 4 Ohm •Sensitivity 92 dB •Connectivity wired Compatibility ' Accessories •Included accessories mounting hardware Cutout & Mounting Dimensions •Diameter 6.3 in •Depth 2.7 in General •Manufacturer Diamond Audio Technology Inc. Thiss should help you out.
Jan 05, 2015 | Diamond Audio Car Audio & Video
The device is not detected or cannot be supported
Something inside the tuner has gone bad. I had a sub video grabber do the same to me. I had to replace the grabber
Apr 22, 2014 | Diamond Multimedia Diamond Tvw750usb Ati...
Is the Wireless N 150 Ultra Compact USB 2.0 Adapter compatible with Windows 8 ?
Make sure you are on Windows 8 Desktop. Try download the Buffalo WLI-UC-GNM_E-105 driver and run setup.exe with XP SP3 compatible. After the installation, your Wireless-N150 Ultra-Compact USB 2.0 Adapter will be working fine in OS Windows 8.
Nov 03, 2012 | Buffalo Technology N-Technology...
How to snchronize htc diamond touch with windows 7?
First, download Windows Mobile Device Center from Microsoft ( Google it) and install it in Windows 7
Secondly, plug the HTC diamond touch with USB connection and wait for the windows update search the driver of HTC Diamond Touch.(This will take a while)
Then It will ready to go.
Hope this help you.
Feb 06, 2011 | HTC Touch Diamond Smartphone
Subs wont pound
could be the wiring or not enough power getting to the amp or check your grounds
Sep 18, 2009 | Pioneer GM-7200M Car Audio Amplifier
Cannot connect htc diamond with pc via usb??
Install Activesync on your computer. http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
Sep 12, 2009 | HTC Touch Diamond Smartphone
My computer does not regonize any audio devices
From a distance, it sounds like you do not have the sound card drivers installed. Since it is a SoundBlaster card, go to creative.com and download a utility that finds, indentifies, and then installs the drivers for your sound card. That should fix the problem. If not, then you have other issues going on with motherboard drivers not being installed installed.
Jun 06, 2009 | Audio Players & Recorders
Can I Install iP2600 using USB 1.1 conectivity?
What will happen is the printer will slow down to the speed of the 1.1 USB technology. Try running the setup and see what happens. I did this in the past and I believe I did get it to work.
May 13, 2009 | Canon Pixma iP2600 Photo InkJet Printer
4,131 people viewed this question
 Grubhead
Grubhead
