Question about Curtis Lifestyle DVD System
No signal I can get surround sound, but no picture from the dvd
  • 682 Answers
Please try first another cd and play it and change video cable second and try.
Posted on Apr 27, 2008
I can get sound through the samsung surround sound system but no picture.
Chech ur video cables to n from tv n surround system. Or ur system may b on wrong input device.
Mar 13, 2013 | Audio Players & Recorders
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
Dec 27, 2009 | Coby DVD-937 5.1 Channel DVD...
I have a kenwood vr-707 it gets surround sound on dvd/vcr but I can't get surround sound on just tv.
Well you have a built in decoder/surround processor that will detect a signal with the surround sound info(dvd/sat.receiver/cable converter etc.) and will then process it to the different speakers on your system. In the absence of that signal it will process it as standard stereo sound(two front speakers). You may want to look in your receiver functions/menu for simulated surround.
Hope this will help.
Nov 24, 2009 | Kenwood VR-707 Receiver
On our Durabrand DVD/Vcr Combo, I get picture, but no sound..I'm using a S video as conectors!
S video connector is used only for video, you need to connect the audio separately via the RCA audio connectors or via digital coaxial or optical connector.
You can read more on S video standard here:
http://en.wikipedia.org/wiki/S-Video
Also see the related topics on audio, maybe you should consult the user manuals for your dvd unit and the amplifier that you use to get more info, but normally the sound can be connected via these connectors on the rear panel of dvd units:
- main left and right analog signal out RCA connectors (2 channel stereo signal - amplifier set to analog signal)
- main left and right, sub, center, surround left and right analog signal out connectors (multichannel surround signal - amplifier set to analog signal)
- coaxial digital signal out RCA connector (a single cable that takes the stereo or surround signal to the amplifier in a coded digital form - you need to set the amplifier to the digital signal mode to enable this kind of signal)
- optical digital signal out connector (same as the coaxial digital output, the difference is that the signal is in the form of light pulses instead of electrical pulses - the amplifier should be set to the digital signal mode as well)
Hope this helps somehow - if it doesn't, post me some feedback, perhaps a brief description of the units that you want to interconnect...
regards
Triarcuate
Sep 26, 2009 | Televison & Video
Have surround sound only when play dvd..
if you have a sat/cable box it may have audio outputs that you can connect to the input of the surround unit or if your tv has an audio uotput it can be connected to the surround unit. The audio outs of the tv may or may not adjust with the tv volume. This will not produce a true surround signal because th tv does not output a true surround signal. But yo can adjust the surround unit to get a nice sound.
Jun 26, 2009 | Philips SoundBar DVD Home Theater with...
No sound, receiver does not recognize signal, picture ok-DVD
So did it ever work or did it just start failing? Makes a BIG difference in possible causes.
You need to make sure the DVD is connected properly and the receiver is configured for it. Did you try the DVD audio connected to an input that DOES work ok? Then we'd know which way to point the finger.
Model numbers of everything will help those of us who can't put an eyeball on it.
May 16, 2009 | Denon AVR-3802 Receiver
I can not get any sound from the surround sound system for my tv
Make sure you have a Dolby surround signal going in. Play a dvd and see. You won't get any sound from rear speakers from over the air broadcasts. Try changing the mode to phantom or 3-ch to get faux surround for tv signals. Only Dolby gives true surround and that is only avail. on movies. good luck
barneyluc
Oct 02, 2008 | Audio Players & Recorders
NO sound and cable signals
Looks like someone sold you a unit only partially working.
You may need to have the main board replaced, which is likely why the previous owner sold it.
My solution would be: Buy an inexpensive surround system and a VCR, Use the VCR as your tuner, and plug the audio output from the VCR into your surround system.
This way you will have a tuner (the VCR), and sound through the surround amplifier. You can also plug the audio output from your DVD player direct into the surround amplifier. This solution would likely run you less than half the cost of replacing the main board in the TV.
May 07, 2008 | Akai LCT2060 Television
Jumping Picture
Does the Sony surround upscale the signal from normal RCA to Component video? If so I have found that sometimes there can be signal sync issue. Meaning the signal that the component video convertor (inside the surround sound unit) sometimes struggles to give a clean component video signal. The TV then struggles to filter the signal correctly resulting in a jumping picture. Try plugging the DVD video only (yellow RCA lead) straight into the plasma and see what happens. You can also try playing with the signal frequency of the plasma, from 50 - 60hz. This will found in the menu of the plasma. Hope this helps. ST
Oct 29, 2007 | Sony DVP-NS530 DVD Player
Samsung TXJ2754 (27") DVD issues (Sound but no Picture)
Assuming you have picture on the TV when hooked up to cable, antenna or satellite I would take the DVD player to a friends house to see if it worked on their set (using your cables of course). If you can't get a picture on your TV no matter what, then it could be either the Jungle IC or EEPROM IC inside the set. Since it displays "No Video Signal" on the screen, that leaves out the High Voltage section of the TV. My main suspicion would be the video cable or settings on the DVD or TV.
Jan 02, 2007 | Samsung TXJ2754 27" TV
Curtis Lifestyle DVD System Logo
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
