Question about Ruud UBHC Air Conditioner
My ac unit will not work at all. It seems like the unit is not getting any power
    Problem Solver:
  • 10 Answers
CHECK FOR TRIPPED BREAKERS.(REST) OR BLOWN FUSES.NEXT CHECKS WIRING FOR BREAKS OR BAD CONNECTIONS.USE A VOLT METER TO CHECK VOLTAGE.
Posted on Aug 08, 2010
I have duo therm rooftop Ac unit, was working fine and just went out. Seems like it is not getting power, I checked breaker and fuses. Still not working. What do i do next ?
First of all are you plugged in at a rv park or home? Had ours do that as well, found the electrical source in rv park was defective. Caused our AC unit to cut in and out then wouldn't run at all. Moved to a new location and the ac was fine.
Jul 24, 2014 | Dometic Rooftop RV Air Conditioner
My ac unit has been down for a couple weeks but i have it working but now the outside fan and compressor dont shut off when the blower does. Im at my wits end now. Please help.
It seem the relay (power leads to outdoor unit) on indoor controller get stuck. If you used to leave the air condiotioner on stand by, now please try totally power off the unit by unplug the power then retry.
good luck.
Jul 28, 2011 | Heating & Cooling
Have a 93 airstream camper with a Dometic AC unit . When I tuun the unit on either to heat or air,it brings the house voltage down to the red zone but does come on but seems to be draining the power.
Does the fan seem to labor when starting up. (basically starts up but seems slow to get up to speed?) Then when fan is turning at normal speed, the power inside seems to go back to normal?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
VOSTRO 1710 BATTERY WON'T CHARGE
If the battery will not charge, try this:
1.) First, power reset the unit by powering it off, unplugging it from AC power, removing the battery, then push and hold the power button on the unit for about 60 seconds.
2.) Next, plug the AC adapter back in (LEAVE THE BATTERY OUT), power the unit on. Does the unit power on?
If yes, Power the unit off and put the battery back in, let it charge overnight. If, after this the battery will still not charge, you will have to replace the battery. Contact the OEM to ensure you get the correct battery.
If no, remove the AC adapter carefully, look inside the DC port (where the charger plugs in to the laptop) you should see a small silver pin. Is this pin missing or bent? If the pin seems to be in good shape, then most likely you will have to replace the AC adapter. If it IS bent or missing, then you will need to contact a laptop repair center.
Oct 08, 2009 | Dell Vostro 1500 Notebook
I can't seem to get the A/C to work. I'm thinking of getting a hose as a last resort. It seems to alternate blowing cool air, then hot air after a few minutes. There's also a tendency for the a/c to...
The symtoms you describe appear to indicate that the AC might be low on the freon charge. Usually blowing cold and then hot is the first sign that the unit is low on refridgerant and is working hard to keep cooling.
Further, the tripping of the breakers/electric power also indicates that the unit is working hard to cool and as a result is running hot and is causing the power to trip off. If you can get a AC tech to recharge the unit, you should be all set.
Here's a link to a site with the owners manual and a troubleshooting guide for your unit. You can access it for free.
http://www.retrevo.com/support/Danby-DPAC9030-Air-Conditioners-manual/id/886bh650/t/2/
Hope this helps you get things working again! Best Regards!
Jul 31, 2009 | Danby DPAC9030 Air Conditioner
ZD7000 Lights, no fans, power switch not working.............
Dismantled notebook thinking compressed air removed component or connection. Nothing. Reassembled most of notebook. Left battery and power disconnected for 6.5 hours, I later plugged only AC power into unit. Fans started spinning. Completed assemble of notebook and installed the battery. Blue lights returned. Problem seems to be the battery. Shorts out something and needs about 6 hours drain out. Works great now without battery, using AC power only. Ordered new battery.....
Feb 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
MAGELLAN ROADMATE 700 ON THE FRITZ.
I had the same problem with myRm 700, too. Solution : connect your unit into the AC power pack . Turn it on. Then reinsert an address into the unit while plugged into the 110 volt ac wall outlet power supply. You may need to repeat this operation a few times.
Also, used mine in my 18-wheeler using a ac to dc power inverter. It seemed to work everytime. Note make sure the ac to dc inverter you by has enough dc output to feed your Gps all the juice it needs. That ac to dc inverter can be used to run other ac powererd appliances, too.
Aug 30, 2007 | Magellan RoadMate 700 GPS Receiver
Delphi NA10000 Losses Power, Turns OFF
I had the same problem and was able to fix it by finding a replacement cigarette lighter power cord with the same voltage and polarity. Input to cord is 12Volts. Output to GPS is 5Volts, with a positive center post.
larryjm123
PS I need an instruction book and disks (or disk copies) if you know where I can get them. Delphi no longer has them.
May 14, 2007 | Delphi NA10000-11B1 GPS Receiver
Ruud UBHC Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
