Question about Toshiba TP55F80/81 55" Rear Projection Television
I have a Toshiba TV with a model TP55F80. There was no picture or sound, just a blinking power light. Tried plugging and unplugging, moving to a different outlet, still would not work
  • Toshiba Master
  • 11,800 Answers
The led is blinking to announce that the power source has been shut down in protected mode because there's a short on one of its outputs. This isn't a setting or outlet problem, an actual part inside the tv has failed.To find which part the tv must be opened and tested by someone with at least a basic electronics experience - most likely on a tv of that age the electrolytic capacitors have aged and are starting to fail and you must know how to spot and replace them. If you haven't done this before then it's time to call a pro.
Posted on Aug 07, 2010
  • 3 more comments
  • rodel_banal Aug 07, 2010
    how much does a capacitor cost?
    my dad told me, he initially noticed changes in the color and shadows, then after 2-3 days, it shuts off and would not turn on.
  • Azrael SRL Aug 07, 2010
    The changes in the image were caused by lower than normal voltage at the convergence circuit because the capacitors have started to fail.
    Best case scenario, just some failed capacitors to replace - less than $25 in parts. If you have the necessary skills the labor will be free; if not add another $100.
    Worst case, you have used the tv till if failed completely and now both the convergence and power board have failed totally and must be replaced - around $300 for the boards and $75 for replacing them.
    This is a good quality tv, it's worth repairing it, but get a quote before to be sure.
    i OPENED THE back of the TV to look for the capacitors. where are they located? I would like to try first before calling a technician
    This is an electrolytic capacitor  http://en.wikipedia.org/wiki/Electrolyti...  . They are all over your tv but the ones that fail are the big ones.
    Why they fail and how they look when they fail is exposed very well here
    http://www.mikerepairscomputers.com/blog...
    Look for bulging and leaking ones, replace them and try to start the tv again. If this doesn't work this means that when the capacitors failed they fried other components like the main power transistor and the rectifying diodes. Those should be replaced only by a pro.
The red light is blinking and the tv sounds like it on when unplugged and replugged; but there is a black screen.
If you are having sounds but no picture, it is either the lamp or the t-com board.
But if it does bot display anything or make any sound at all but from inside the unit it sounds like there is power in the unit, then it means there is a problem with the main panel of the television. Most likely a bad capacitor.
Have the unit checked for bad capacitors and replace them and the television will be in good condition once again.
Take care and good luck
Oct 15, 2010 | Toshiba 32A43 32" TV
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
My RCA 52 blinking power light, no picutre
Flyback transfromer is defective and needs to be replaced.
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
TV shutdown itself. LED on/off indicator is blinking.
That happened to me before. I was watching TV and all the sudden it would just turn off on me. The power switch had gone bad and I had to have a new one put in.
Jul 16, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Jun 22, 2009 | Toshiba 65HM167 65" Projection Television
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
