Question about SmartDisk CrossFire Desktop FireWire/USB 160GB External Hard Drive (XL160) Media
Sda - SmartDisk CrossFire Desktop FireWire/USB 160GB External Hard Drive (XL160) Media
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
I need owners manual for Polk audio SDA 1c
I used http://www.google.com and entered the words Polk audio SDA 1c
The only manual or information besides several youtube videos I saw was this which may not be helpful to you:
http://www.vr3mods.com/uploads/SDA_Handbook_2011_Rev2.pdf
Apr 10, 2018 | Polk Audio Audio Players & Recorders
Tip
Clone a Hard Drive Using an Ubuntu Live CD
Whether you’re setting up multiple computers or doing a full backup, cloning hard drives is a common maintenance task. Don’t bother burning a new boot CD or paying for new software – you can do it easily with your Ubuntu Live CD.
Not only can you do this with your Ubuntu Live CD, you can do it right out of the box – no additional software needed! The program we’ll use is called dd, and it’s included with pretty much all Linux distributions. dd is a utility used to do low-level copying – rather than working with files, it works directly on the raw data on a storage device.
sshot120.png Note: dd gets a bad rap, because like many other Linux utilities, if misused it can be very destructive. If you’re not sure what you’re doing, you can easily wipe out an entire hard drive, in an unrecoverable way.
Of course, the flip side of that is that dd is extremely powerful, and can do very complex tasks with little user effort. If you’re careful, and follow these instructions closely, you can clone your hard drive with one command.
We’re going to take a small hard drive that we’ve been using and copy it to a new hard drive, which hasn’t been formatted yet.
To make sure that we’re working with the right drives, we’ll open up a terminal (Applications > Accessories > Terminal) and enter in the following command
sudo fdisk –l
screenshot_001.png We have two small drives, /dev/sda, which has two partitions, and /dev/sdc, which is completely unformatted. We want to copy the data from /dev/sda to /dev/sdc.
Note: while you can copy a smaller drive to a larger one, you can’t copy a larger drive to a smaller one with the method described below.
Now the fun part: using dd. The invocation we’ll use is:
sudo dd if=/dev/sda of=/dev/sdc
In this case, we’re telling dd that the input file (“if”) is /dev/sda, and the output file (“of”) is /dev/sdc. If your drives are quite large, this can take some time, but in our case it took just less than a minute.
screenshot_002.png If we do sudo fdisk –l again, we can see that, despite not formatting /dev/sdc at all, it now has the same partitions as /dev/sda.
Additionally, if we mount all of the partitions, we can see that all of the data on /dev/sdc is now the same as on /dev/sda.
screenshot_0041.png Note: you may have to restart your computer to be able to mount the newly cloned drive.
And that’s it…If you exercise caution and make sure that you’re using the right drives as the input file and output file, dd isn’t anything to be scared of. Unlike other utilities, dd copies absolutely everything from one drive to another – that means that you can even recover files deleted from the original drive in the clone!
on Jun 09, 2010 | Computers & Internet
Clicking noise and takes long to read
If the data is important I would highly recommend sending it to a specalised data recovery company, they have special hardware/software designed specifically to deal with failing hard drives. Digital Recovery (www.digitalrecovery.co.nz) are well priced and have all the gear to deal with this. If you data is not particularly important you could try removing it from the external case and imaging it in a Linux machine using dd_rescue. Download Ubuntu and install dd_rescue (sudo apt-get install dd_rescue) and have another blank drive installed then image the disk like this "dd_rescue /dev/sda dev/sdd, where sda is the faulty drive and sdd is the blank one, do not get these mixed up or you will overwrite your data.
Dec 24, 2013 | Transcend StoreJet 25 Mobile 500GB USB 20...
I would unlock T-Mobile SDA To work in the local network IMEI no : 35629500024969400
You can Unlock the T-Mobile SDA using the unlock code,You need to specify the Current network it locked now?Then YOU can Unlock it,you can get the Unlock code and instructions from the site
Simpleunlocking and Unlock it ,then use it any GSM Network sim card.....You can't unlock it from CDMA Network Sim card.
Jul 18, 2011 | Cell Phones
You can get the unlock code from the current service provider or from the online unlocking sites. i will suggest the website OnlineGSMUnlock.com which is doing good service .....you can approach this website
Jul 17, 2011 | T-Mobile SDA
Mrere tv me fain tune set karne ke baad save karne par bhi wo auto tune ho jati hai or save nahi rahti jabtak faine tune manual tuning likha rahta hai tab tak hi picher sahi rahti hai sve karni par wapas...
Hello
Your TVs momory Ic is in trouble. It does not respond either to SDA-SCK [Serial data-serial clock] signals or faulty. You just replace it with same type and number. It is an 8pin Ic, not cost more than Rs25/= at all. Check its supply rail also.Check the voltages at SDA and SCK pins to make sure that the voltaged needed to get it memorize is there or not. Usually this voltage be between 4VDC or 4.5VDC.
Oct 18, 2010 | Akai Televison & Video
Driver
Hi mostafa said,
Here is a link where you can down load the drivers for you mother board.
http://www.epox.com/USA/downloads.asp
Sincerely,
Agent Xiong
May 07, 2008 | EPoX EP-5VKMI Motherboard
T mobile mda
If the unit is not new have you checked the status of the battery and is it a manufacturer's battery - some units are quite sensitive to that.
The problem may also be with the charger
Dec 22, 2007 | T-Mobile MDA
Samtron 78DF signal cable conductors
This is solved by the author himself
May 30, 2007 | SAMTRON 78DF 17" CRT Monitor
SmartDisk CrossFire Desktop FireWire/USB 160GB External Hard Drive (XL160) Media Logo
71 people viewed this question
Top SmartDisk Electronics - Others Experts
Marvin
Marvin
Are you a SmartDisk Electronics - Other Expert? Answer questions, earn points and help others
