Question about Jenn-Air JCD2295HES Side by Side Refrigerator
Ice maker does not fill with water and therefore does not produce ice. Do you have a remedy? There is no crimp in water line. The water does dispence to fill a glass.
  • 2 more comments
  • janray May 16, 2008
    our ice maker doesn't fill up with water, so it doesn't make ice.
  • nbislam Jun 27, 2008
    Ice maker does not fill with water. if i manually fill with water it produces ice but all the ice cubes joined together
  • Anonymous Jul 21, 2008
    turn the maker off and back on
  • Anonymous Mar 23, 2014
    Ice is being produced but will not dispence
    Scholar:
  • 150 Answers
Water valve or the ice maker is malfunctioning and not calling for water
Posted on May 07, 2008
My Liebherr ign 2566 freezer is having problems with the icemaker. It is producing ice cubes but also water is pouring direct into the tray therefore producing a big slab of frozen water.
Hello there,
You need to check the water inlet valve, it is having a problem, it is not shutting close after filling the ice maker with water. It is already defective hereby causing water to pour out into the tray therefore producing the big slab of frozen water.
You will have to test and replace the water inlet valve. That way, it will stop pouring water into the already made ice that is in the tray.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Liebherr Refrigerators
I have a side by side refrigerator and ice maker will not produce ice anymore
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Apr 27, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not producing any ice cubs
Apr 26, 2011 | Fisher and Paykel Active Smart® E522BR...
Ice maker is not working properly. I noticed that it dumped water into the ice catcher and fused all the ice cubes together. Now it fills but is not producing any ice. We have the freezer temperature...
Feel under Ice maker to see if it is warm. This is a heater that comes on to loosen the ice cubes just long enough to allow the cubes to slide out of their ice slots. The only remedy is to replace the Ice maker model=> D7824706Q Ice Maker Assembly
Please let me kow if this is helpful or if something different may be happing, Thanks, Sea Breeze
Feb 27, 2011 | Maytag PBF1951KEW (19.0 cu. ft.) Bottom...
No water is goin up the pipe to fill thr ice maker, we have water but no ice.
This uses a dual water valve. One side supplies the ice maker, the other side supplies the water. Therefore the side that fills the ice maker is not working.
Feb 05, 2011 | Daewoo Refrigerators
Refrigerator cannot produce ice
First you need to list the model number of your GE to get correct answers. The problem is either you water control valve or the ice maker itself. If filling the ice maker with tap water and it freezes and dumps without the ice maker refilling then I would point to water control valve for the ice maker side and if the ice maker when filled does nothing the the ice maker is defective. Thanks, Merry Christmas, Sea Breeze
Dec 23, 2009 | GE Refrigerators
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water is leaking out of ice maker and freezing up where cubes are
Sounds like water valve is not closing all the way after the icemaker calls for water. This is because sediment in water builds up on valve seat therefore letting water pass through. Suggest replacing fill valve. Crescent shaped ice....ice maker on needs 4 ounces to fill icemaker, so any more than that will spill out.
Jul 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Check your water valve first. It is usually in the back of the machine on the bottom. If your water valve is bad the it will not fill with water. When it does fill with water and it does rotate to drop ice but doesnt drop it that is probable the heater on the bottom of the ice maker not working.
May 12, 2009 | Refrigerators
Ice maker stop making ice for kenmore 106.56352500
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
1,566 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
