Question about Health & Beauty
How do you recalibrate the static pressure for Sharper Image Model ME791 Arm Cuff Blood Pressure Monitor with Averaging-Mode Accuracy? Can you email a copy of the service manual?
evwood
  • 50 Answers
SOURCE: WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
Try different locations. The sensor must be over a vain to pick up the pulse. Locate the point on the cuff where the sensor is, and place this over the elbow. That should work. Good luck.
Posted on Feb 09, 2009
Max J
  • 22 Answers
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Posted on Sep 08, 2009
DrRonJupiter
  • 10 Answers
SOURCE: mabis automaic blood pressure cuff, pressure monitor
Dear Edward: Likely, either cuff not tight enough or not in correct location on your arm or not holding device at correct height. Make sure you use Lithium Ion batteries. Try it on someone else. Dr Ron Grassi,Jupiter,Florida.USA. www.DrGrassi.com 30ad4e8.jpg
Posted on Oct 13, 2009
SEGlover
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
SOURCE: How do you set the time and date on a Welby Wrist
I was able to do this by 1st pushing and holding the M button and then pushing and holding the on button and holding both for 3-4 sec. Once released you will see the month flashing. change by pushing the M key to desired month then toggle to day etc with the on button
Posted on Oct 07, 2010
My monitor pressure life source UA 767 show in display error cuf , what mean thats error
The Err CUF probably means that the blood pressure cuff isn't properly arranged on the arm. Check that the cuff is around the upper arm 1-2 cm above the elbow. The hose should be near the center of the elbow. Make sure that a rolled up shirt sleeve is not too tight. Next check that the indicator arrow is in the correct range when the cuff is firmly fastened.
Make sure that you are using the correct cuff for the user. There are different blood pressure cuffs (medium, large, wide-range) available for some blood pressure monitors. If the arrow doesn't line up in the indexed range, use a different blood pressure cuff for the unit.
I hope this helps. I used the information about the A&D Medical UA-767 for some of the trouble-shooting details. See https://medical.andonline.com/product/premium-blood-pressure-monitor/ua-767f and click on the Downloads tab to see the manual for this model. (I suspect the Life Source and A&D Medical products are extremely similar.)
Nov 21, 2017 | Health & Beauty
I'm looking for an extra large arm cuff for an automatic arm blood pressure monitor model WGN BPA-530. I have been working out and arm is now 15. Thanks for your help Eric in Fresno Ca.
as you will notice that there is now a blood pressure machine that clips around your wrist
try wrapping the cuff around your wrist or lower arm
Nov 12, 2017 | Health & Beauty
My Blood Pressure comes up with E1 - what does this mean?
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
Mar 27, 2017 | Health & Beauty
HD 1000S Blood pressure monitor will not display blood pressure after inflating code ERR 1
tighten the cuff more around the arm or if you have a small arm pull your sleeve down then put cuff on and try it that way see if it helps
Jan 22, 2012 | Health & Beauty
Insturctione how to use omronHEM432CN2
Taking your blood pressure is easy with the lightweight and convenient Omron HEM432C blood pressure monitor. Simply wrap the cuff around your arm and squeeze the bulb to begin inflation. In seconds, your blood pressure and pulse readings are displayed on the large digital panel. The Omron HEM432C has been tested, evaluated and proven to meet the rigorous safety and accuracy standards set by independent organizations.
Dec 05, 2011 | Omron Healthcare Omron Hem432cn2...
What is the m button for
Hope this helps you out
Sep 19, 2011 | Health & Beauty
Neither of the cuffs on the Homedics S18729 Ultra-Deluxe Automatic Blood Pressure Monitor work. They do not fit well around my arm and constantly slip while inflating. I don't know if it is a design flaw...
Robert, I'm not sure that the cuffs would be interchangeable. But, I suspect the problem you're having with the cuff is operator error. Speaking from experience, it's somewhat difficult at best, to apply and arm cuff to yourself. It does take some practice, but if you can get the cuff snugly in place, it should inflate properly. If you want to pursue with interchanging the cuff, contact HoMedics at 800-469-3342, to see if it's possible. Perhaps, you should get a BP Monitor that has a wrist cuff. They're a lot easier to apply and use.
Apr 01, 2011 | Walgreens By Homedics Automatic Blood...
My Omron 711 seems to register readings that are too high when compared to doctor's office or monitors in drug stores, etc. Is there a way to check accuracy of the monitor?
Take the cuff to your doctors office and have the nurse check with yours and the office BP cuff. If your cuff is too small, you will get a false high reading.
Nov 30, 2010 | Omron HEM-711 IntelliSense Automatic Blood...
Looking for replacement arm cuff for my sunbeam blood pressure monitor model 7652
To get a replacement arm cuff call sunbeam at 1-800-394-2326
The cuff will cost you 12.95 there. If you need you can get the manual and order sheat on the link below. Page 10 of manual.
http://www.foodsaver.com/manuals/HAH/Manuals/7652.pdf
Good Luck
May 24, 2010 | Sunbeam Health & Beauty
Accuracy problem
Hello martintpjr, the difference could be your physical postion,(sitting,laying) location of cuff(on the fore arm), not as relaxed, cuff/tubing has a air leak,or unit is out of calibration. Eliminate the first four than contact the local college or BioMed shop in the local hospital and KINDLY ask if your unit operation/calibration could be checked. Merry Christmas.
Dec 12, 2008 | Omron Automatic Blood Pressure Monitor...
Health & Beauty Logo
51 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
