Question about HP Deskjet F4180 All-in-One InkJet Printer
Uninstall Problem I was using F4180 on my computer.I tried to uninstall all related with HP.But the result is not changing.I can not uninstall it by the way.I need help
  • falca Apr 28, 2008
    THANKS.
    Problem Solver:
  • 8 Answers
If you are installing the software using Windows and the software was not successfully installed or the uninstaller could not be found, run the Scrubber Utility to perform a clean driver uninstallation Use the Scrubber Utility Use the following steps to run the Scrubber Utility.
  1. Disconnect the printer from the computer.
  2. Restart the computer.
  3. Insert the Starter CD into the CD drive. If the CD menu displays, close the CD menu.
  4. Locate the Utils\Scrubber folder on the Starter CD.
    • For Windows 98 and Windows Me, use the scrub9x.exe file located in the Utils\Scrubber\Win9x_Me folder.
    • For Windows 2000 and later, use the scrub2k.exe file located in the Utils\Scrubber\Win2k_XP folder.
  5. Double-click the file to run the Scrubber Utility.
  6. The following message will display: This utility will attempt to remove all HP DeskJet 460 Series devices from your system. It is recommended that you disconnect the device and restart before continuing. Do you want to continue without rebooting?
  7. Click Yes . A message stating Successfully removed the devices(s)! This system is ready for installation displays after the scrubber utility finishes running.
  8. Click OK .
  9. Restart your computer, and then reinstall the printer software
Posted on Apr 28, 2008
  • pavan kumar Apr 28, 2008
    If this doesn't work plz let me know ?
How do i uninstall a printer and reinstall it?
Dear
The uninstall may done on click remove button in ADD/REMOVE program. click on, START-CONTROL PANEL-ADD OR REMOVE-REMOVE. on desired program.
Thanks.
Feb 05, 2015 | HP Deskjet F4180 Inkjet - 6800 Page Yield
Uninstall avast i can not uninstall from programs
If any Process related to avast has been working,then you are unable to uninstall it. First,Stop all the activities related to that,then try. Else use Unlocker Software to stop it and try to uninstall. Another reason,if the software is corrupted,then also its not able to uninstall. Try to install properly then uninstall it. See to it.
Jul 25, 2012 | HP Compaq nc6230 Notebook
I CAN'T FIND MY SCANNER IN HP DESKJET F4180
Use the disc that came with the printer and uninstall the Imaging Device and then reinstall it again. It should work.
When you click on uninstall you will be given two options: To uninstall everything or choose software to uinstall.
Choose the second one, that way you won't have to uninstall everything.
If you've have finished doing so. Try scanning again, there;s a big chance it would work now.
Feb 04, 2011 | HP DeskJet F4180 Inkjet Color All-In-One...
I have the hp deskjet F4180 printer I have used for at least two years. My lap top is a Gateway Windows Vista. Recently the printer failed to print so I deleted the printer as it would not delete the...
HP software can often give you a headache. When you said you deleted the printer did you simply delete it from the control panel where all of your installed devices are listed? If that is the case you need to use HP's Uninstall program to completely remove all HP software for this device before attempting to reinstall the software. If the HP software is no longer listed under your "Start - Programs" menu you can use the Control Panel, go to "Programs - Uninstall a program" find the HP software and remove it. Once that is done you can use your friends CD if it is Vista compatible or download the driver at this link:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=al-64552-2&lc=en&dlc=en&cc=us&product=3177566&sw_lang=&os=2093
May 20, 2010 | HP Photosmart 4180 All-in-One Printer
Trying to scan from a hp 4850 with hp photosmart essential 3.5. Tried reinstalling software with no change.
Hello
Are you able to scan with any other software? Try microsoft paint.
hold down the windows key and press r, type mspaint and click OK
In paint, click file and select from scanner or camera, try scanning does it work?
If it works, there is something wrong with your photosmart, I would suggest you completely uninstall all hp related software and programs from start .> control panel -> add or remove programs / programs and features / uninstall programs.
Find all hp related software, uninstall, unplug printer, restart computer when all software is removed. if the computer restarts before all programs are uninstalled, then continue after restart until all programs are removed.
(After) restart and use your cd and reinstall, plug in when asked.
let me know if you require further assistance.
Dec 25, 2009 | Computers & Internet
Failure of F4180 DeskJet All-in-one to install
frist you need to uninstall the printer from the cd..insert the cd first then go to the cd do explore>>utill>>ccc>>uninstall l3..after that go to control pannel..add a remove program then delete all the programs related hp printers..restart the computer.then download the software from hp.com..reinstall it..it will work..best of luck!!
Sep 15, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
My printer stays on and will not be recognized by my computer ... even when i unplug it to try and reset it the power stay's on .... not sure what the problem is but only used the printer twice so any help...
Hi, this is probably a USB issue. Here is what i would do. Uninstall printers drivers. Unplug the USB cables. Download the latest drivers from HP. Then install the new drivers and wait untill the software tells you to plug your usb cable. Your printer may stay in sleep mode while it's not prining, it may be completely normal. But if you have serious doubts, you could call the HP thech support.
Jun 08, 2009 | HP DeskJet F4180 Inkjet Color All-In-One...
Hp Photosmart C4100 series (copy 6) printer missing!
Uninstall all those printers first. restart the computer and reinstall the drivers again.
May 25, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
HP F4180 Printer printing small
Hi Lady Luxe,
Try running the Manual Uninstall solution (click link below):
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00501015&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Then run the HP Installer from your disk (v. 8.0). You may want to also restart your Mac after installation is successful (make sure you complete the Setup Assistant - don't skip it!).
Try to scan from the glass scanner bed to see that your connection is solid. Try to print now and it should be fine.
David E.
Jan 31, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP Deskjet F4180 All-in-One InkJet Printer Logo
267 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
