Question about Canon PowerShot SD1100 IS Digital Camera
When you turn it on it says "Lens error, restart camera" and I have taken the battery out and everything else I could think of. What else could I do?
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Aug 07, 2010
The lens is stuck inside and dosent come out
try taking the battery out and wait for 10 seconds and replace and see if that helps
Jul 14, 2012 | Canon PowerShot SD1300 IS IXUS 105...
I try to turn my camera on and it tells me "lens error, restart camera". Ive taken the battery out and the sd card... How do i restart my camera?
possibly you have a canon.
open the battery door, leave the battery inside.
press and hold the power button, and close the battery door.
if that dont work... will need to send to service
Jun 30, 2011 | Cameras
My SD850 Canon says Lens Error restart camera. I have tried to turn it on/off numerous times taken out the battery and sd card. Is there anything else I can try
Jun 12, 2010 | Canon PowerShot SD850 IS Digital Camera
Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Lens error, restart camera.How can I restart the camera IXUS 60?
Since the camera is locked after lens error, you will restart camera removing batteries.
If this does not help, then you are in one of the following conditions:
Lens error and lens does not retract.
Try helping lens gently back in while you turn off the camera holding the button at same time.
Lens error and lens do not extend.
Restart the camera , and try gently tapping the camera back with the palm of your hand whilst restarting camera at same time.
If that does not help, then one part on the camera lens assembly is broken or out of place, or dirt inside lens mechanism caused the fault.
The lens must be disassembled by a technician to fix the problem.
If the problem is not fixed swapping batteries and resetting, then the camera must be taken apart and tested by a technician.
Here you can get a quote on repair: Repair
Aug 22, 2009 | Canon Cameras
How do you restart the camera?
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 01, 2009 | Canon PowerShot A560 Digital Camera
Lens error,restart camera
take your finger and slide it inside the lens and pull it out slightly, not all the way but enough that it moves. then hit the power button and it should work fine after that. good luck!
Nov 23, 2008 | Canon PowerShot SX100 IS Digital Camera
Oct 18, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Lens error
try turning it on and when turning it off push the lens
Sep 09, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens
The Lens drive is shot Canon customer support will advise I my opinion if the camera is more than a year or so old the repair cost will be high.
Aug 01, 2007 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
347 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
