Question about Hotpoint Aquarius WF000 Front Load Washer
WF000 waste pipe not blocked but water is not draining through there, the water is pouring out of the soap tray. If I need to clean the filter, where is it and what does it look like?
Hi the filter is located at the back of the machine you have to unscreew the pastic panel at the bottom..look inside at the right hand side black hose with big jublie clip the filter is inside there just undo the big clip ....expect WATER !!!!!!!!!! when done make sure you push the hose on properly !!! didnt do that myself ...and had to mop up again !
DONT FORGET TO UNPLUG THE MAINS LEAD !!!
Posted on Apr 27, 2008
    Novelist:
    Champion:
  • 244 Answers
Hi there when the washer is full of water have u placed the outlet pipe as far down to the floor into a small pan to see if the water comes out of it if it doesnt then uve either got a blocked pipe or a blocked pump or take the sump hose of that is situated under the washer in the centre big black pipe plastic filter is also in there,now if the water comes out of the pipe when it is placed to the foor then u need to replace the pump has it is dead m8
Posted on Nov 13, 2008
Get new washing machine
Posted on Sep 07, 2008
Why is water pouring out the soap dispenser of my Electrolux front loader washing machine
Possibly a part blocked water feed pipe from bespencer to drum check that it's free
Jan 02, 2018 | Electrolux Washing Machines
Water coming out of soap tray and running down the front of the machine
Your soap tray and/or inlet is probably blocked with undissolved powder. Remove the tray and clean it. Also clean the inlet tube from the tray into the washing machine with hot water.
I, personally don't like soap powder and use a liquid or tablets because washers nowadays tend to use cold water only so doesn't fully dissolve the powder. Also the outlet to drain gets blocked along with the underground pipe to the mains sewage.
Sep 25, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Not pumping out water
Most likely cause is a blocked drain hose. With water in machine try removing the drain hose from where it joins the house drainage (connection to waste under sink or pipe that is specifically for WM.) Put this in a bowl and lower bowl to floor. If water runs out the drain hose is not blocked, if no water runs then the hose is blocked. If water runs then the pump is either broken or blocked - when it should be pumping if it makes a noise then it is not broken.
To unblock the hose or pump - drain the water from the machine (there should be a small pipe hidden behind a front cover at the bottom of the machine put this in a bowl (it will be very slow.) Once drained you should be able to access the pump (it is really an impeller) this should have a screw on front, undo this and remove you should now be able to clean the pump housing. You can also check whether the hose is blocked by blowing down it or pouring water down it. If it is blocked then squeezing the corrugated part of the hose will free some of the blockage. Keep doing this until water can be poured down it. If you live in a hard water area then it would be worth while doing a very hot wash on a regular basis to removed undissolved soap from the machine.
Good Luck
Jan 09, 2013 | Washing Machines
Water pouring from soap dispencer digital screen on mashine says H20 have drained water from pump hose at the bottom of the machine at the front
Hi from Englishman in SW France @ 18:55 Sun evening.
Although I do not know your particular machine water from soap dispenser is mostly caused by blocked tray(s).
Remove dispenser either by pulling almost out and 1) pushing down on the plastic flap at the middle back or 2) by pressing spring underneath or 3) by pulling out and lifting upwards- whichever your machine needs.
Clean really thoroughly, especially the conditioner tray and pipe contained in it- often well blocked by mixture of powder and conditioner (ours often is- I blame my wife....but don't tell her!)
The next thing- 'have drained water from pump hose at the bottom of the machine at the front'
makes me think that either 1) the drain motor lint tray/filter is blocked- which you should be able to remove and clean (if you haven't already done so by your draining action) or 2) the drain motor is malfunctioning. Normally it's the former.
Hopefully both these actions should cure both the problems.
Good luck,
John C
Feb 06, 2011 | Indesit W 123 Front Load Washer
Fujitsu split system air con leaking inside the house from the unit
The drain pipe must be plugged up or bent. Lift cover of unit and look for water in the tray, find drain hole and remove obstruccion inserting a piece of wire. Be gentle and careful. After the water in the tray drains out, pour a glass of water in the tray to rinse it out and make sure the drain pipe is completely clear.
While you are at it, clean the air filter of the unit.
Good Luck
Mar 07, 2010 | Electronics - Others
My washing machine displays the word "SUDS" in the box and will not spin
you are over soaping
use only 1 tblsp per load
to clear this issue
do 2 loads without soap
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Miele W830
I have exactly the same problem - what was the answer ?
Mar 15, 2008 | Miele Novotronic Premier 500 Front Load...
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
Nov 10, 2007 | Dishwashers
Water Leak
I have th same problem, apparently a possible cause could be a partially blocked pump filter. Just trying to get infoon where this is and how to get to it though.
Oct 31, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
207 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
