Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
We washed the screen with a windo washer and the coating started coming off. What shoulsd we do?
  • 456 Answers
The chemicals contained in widow washers are incredibly damagingto the plasma panel and should never be applied to clean LCD or plasma screens as they do not have a glass screen, but are a digital panel screen. I'm afreid there is probably nothing you can do other than refer to user guide when cleaning and maintaining products. This may have also voided your warranty. To clean LCD and plasma screens, simply wipe with a lint free/ static free cloth. Sorry to be the bearer of bad news.
Posted on Aug 07, 2010
How do I unblock my dishwasher - mistakenly washed a tealight holder with the candle still in it !!!
The wax probably melted into a liquid state which ran out with the water, but unlike water, when it started to return to a room temperature state, started to solidify and coated a number of internal areas within the washer. If you could run extremely hot water through your washer it could wash it out, but since it does not turn on, you will need a professional to come in and do an analysis on the situation. It might be similar to someone putting sugar in a car's gas tank; once it melts and mixes with the gas and is distributed throughout the internal engine, serious problems will occur.
Feb 25, 2015 | Siemens Dishwashers
How to fix rust on inner tub of washer
You really can't fix it. The surfaces originally coated with porcelain which is a process where a ceramic coating is fused to the metal at very high heat. Once the rust has started there are no products that you can use in your home to fix it even for a short time; the first wash cycle will loosen any commercial paint. Part of the problem is that the rust will prevent good adhesion. If you are short on funds, you may be able to find an exact copy of your washer at a Habitat for Humanity Re-store, Salvation Army, Craigslist, Goodwill etc at a really low price and swap the tub.
Feb 08, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Windshield washer fluid motor.
With most Fords the screen wash motor is mounted on the bottom of the fluid reservoir, it is just pushed into the sealing ring. So just unplug the wires, twist and pull the motor out (your going to get wet, if fluid in reservoir), coat a little washing up liquid on the new pumps nozzle and push into place, reconnect wires. Job done
Jan 25, 2014 | Ford Mustang Cars & Trucks
Washer wont wash-no water comes in washer
Your water valve inside the washer is either stuck, no water going to hose or the washing isn't sending voltage to open the valve. Start first by removing the hose. If water starts spraying all over the place turn off the hose and check for a blockage when it connects. Sediment may have clogged the screens there. More than likely a new water valve should take care of the problem. Sometimes sediment can pass through the screen and accumulate causing it not to open causing it to stick when voltage is applied as well.
Jan 16, 2012 | LG WM-2277HW Front Load Washer
I have a whirpool duet ht washer that doesn't seem t want t spin on high. Trying to wash one coat by itself and it is soaking wet. Have tried drain/spin mode only but all it wants to do is rotate clockwise...
If you only have one coat in there, that is a problem. It will notice the unbalanced load and shut the spin down and try to redistribute the load. Try adding a few wet towels to offset the weight of the coat. This will likely take care of the problem.
Dec 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My clothes have rust marks on them
Most Washing machines have a coated washer basket in them-- But the coating on these baskets can get chipped, (From coins, or keys, etc. left in the clothes being washed..) Can you take a flashlight, and look and feel the inside of the basket, and look for such chips?-- Is the metal underneath showing thru?-- is it rusting?
If that is not the source-- How about the water coming into the machine?
Is the plumbing in the house old?-- and possibly a source of rust?
If all your piping is copper or plastic--
could it be the water itself?-- are you on Well water, or city water?
Tell us more about the rust marks themselves-- any unique pattern, or situation that make the marks come or go?
Mack B
Dec 28, 2010 | Westinghouse Washing Machines
I have a ge front load washer that won't drain i have stuck a coat hanger through the drain hose it doesn't seem to be clogged up.
take front cover off at bottom. there is a fiter that unscrews. be prepared for water to come out. clean filter and replace, good luck.
Jan 29, 2010 | GE WSXH208A Front Load Washer
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Washer trouble
fh means no water coming into washer. remove cold water line from back of washer and see if the screen in the valve is clogged. if so, remove screen and clean it, if not replaced water valve
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Atlantis Washer
This sounds like a foreign object in machine, possible bra wire. Regards Advisor
Aug 22, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
394 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
