Question about Nokia 9300 Smartphone
White screen i transferred a program via blue-tooth onto my 9300i, went into file manger to install and the screen immediately went blank with white back lighting. I think I've used up all the memory. Now when i press the power button it lights up, goes to a screen with the blue NOKIA sign and then blanks out again (white screen) if i press the power button again the cover screen goes white, press it again the desk screen goes white....... but nothing further, just a lot of white screen. I've tried formatting about 40 times, i know at least a few times I've gotten it right but it never works. I've tried Shift+Ctrl+F, I've tried Ctrl+Shift+F I've tried Shift+Ctrl+Chr+F, I've tried Ctrl+Shift+Chr+F and in many different ways but nothing, straight after the NOKIA screen it just goes straight back to the white screen of death! please help!
  • 1 more comment
  • CMTIN May 24, 2008
    My phone was working fine and then went off on its own.... no dropping, no new softawares. When I tried formating with Ctrl+shift+F face only get the white screen.... nothing further.
    Please help... should I show the phone to a repair man.
  • rmike Dec 08, 2008
    Phone worked very slowly for a while now, but did work. Woke up this morning and phone dead. The phone was not dropped overnight, remained on bedside table. Removed battery and only NOKIA word for a few secs on internal screen then only a white internal screen. Re-tried rebooting after battery removal with front on off button and then only white external screen. Also suspect memory full. Tried hard reset with cntr-shift-F but phone wont offer option of format. Screen displays remain as described.
    Does anyone ever reply with help to these problems on this forum?
  • NightWulfe Jan 22, 2009
    Same fault here, I managed to get the phone to turn on last night by removing the battery for about 15 minutes, got into software, tried to backup the phone, died again at 38% complete on backup, since then no luck.
How do you flash the firmware using pc. can u tell the procedure
Posted on Jul 08, 2008
Flash the firmware using pc cable
Posted on Jun 24, 2008
How can i pass my mp3 file via bluetoot to other celphone
go to the song u want to transfer hit the option button look for send via blue tooth if there is nothing that says and about send via blue tooth ur phone is not ale to send media files such as music
May 16, 2011 | Sony Ericsson XPERIA X8 Cell Phone
I had a samsung a412 with alot of photos on it and now have a new phone but don't know how to get the pics off the old phone onto my computer
if the phone has an sd card transfer on to that then put the sd card into your new phone, or connect your old phone to your new phone with blue tooth and transfer them or transfer them to your computor via blue tooth then send them to your new phone via blue tooth
Jan 30, 2011 | Samsung Cell Phones
Problem in transfering file via bluetooth
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jun 17, 2010 | Sony Ericsson K750
How shall transfer files from pc to my cellphone nokia 5130
Hi Hemendra,
hope you r doing good,
You can transfer files to nokia by connecting usb cable and via blue tooth. Nokia pc suite is required in case of file transfer. So install pc suite and choose any medium to transfer files
I hope i have answered your question
Thanks and Regards,
MechIntoSoft
Mar 03, 2010 | Nokia 5130 Cellular Phone
My c261 problem
HI there,
  1. You have to set both unit blue tooth configuration settings.
  2. Turn On the blue tooth for each unit
  3. Make or initialize pairing on the unit that will send the data.
  4. The other end(cellphone) has to accept the connection invitation from your cellphone.
  5. It will ask a password, you can input a 1234 or just leave it blank if you don't want to use a passkey.
  6. After you have done the pairing, select the file you want to transfer.
  7. Select Option >> Send >> Via Blue tooth.
  8. Select the paired cellphone you connected via blue tooth that you have DO on steps 3.
Hope this initial info helps.
Just let me know for further instructions.
micro
Jul 19, 2009 | Motorola Mobility C261 Cellular Phone
How can i download a free ringtones from the computer using a blue tooth. when my cellphone is panasonicX700
First, you should have a program on your computer that you are giong to use for downloading music. You may install LimeWire for PCs or FrostWire for Mac.
Those programs will allow you to search and download songs. You have to save the downloaded songs into a folder.
Now, in order for you to transfer those songs from the computer to the phone via Bluetooth, your computer should be Bluetooth enabled also.
1. Turn on the Bluetooth on your phone.
2. Pair up the phone with the computer via Bluetooth.
3. The computer will recognized the phone.
4. Select the song, right-click on it and then select Send
5. Select via Bluetooth and select your phone.
It should transfer after doing those steps.
Good luck and have a great day!
May 16, 2009 | Cell Phones
I do not have data cable I want to connect to PC via blue tooth
GAME DIDNT TRANSFER. PLEASE CHECK BLUETOOTH CONNECTION
Nov 12, 2008 | Nokia 6233 Cellular Phone
Uploading
how can we download the themes , games and other assesories
Jun 17, 2008 | Sony Ericsson K530i Cellular Phone
Blue tooth
re-installed the driver of the blue tooth after that is not working then go for the internet and download a driver of your product it should work
Dec 30, 2007 | IOGear (GBU221) Bluetooth Wireless Adapter
Nokia 9300 Smartphone Logo
1,738 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
