Question about Antec AR300 300-Watt Power Supply
I am trying to hook up an antec ar300 power supply to the outlet that lets it be plugged into the wall. there are three wires ... green white and black... i can not figure out which one is positive which is negative and which is ground pleace help
  • 225 Answers
The green is ground. There is no "positive" and "negative" because the current in the outlet is alternating (AC). They are called "Live" and "Neutral". The Neutral i safe to touch, the Live is deadly. There is no difference how to connect them - in both ways the power supply will work.
Posted on Aug 07, 2010
Hi, in Antec 300watt power supply there is 3 cables or input or current 220volt. The cables are Black, Green and white. Which one is earth, which on is live(positive) and which one is negative?
For 120 volt operation use
black for the hot, White for the natural, Green for earth ground.
For 240 volt operation use;
Black and White for the 240 volt and Green for earth ground.
Black is generally designated as the "Hot" or "positive" .
You must make sure the switch on the power supply is set for the voltage you are using. ie: 120/240
Dec 15, 2014 | Antec Computers & Internet
Fan stopped working
Power supplies are not meant to be fixed. If you have electronics repair experience, crack it open and replace the fan with a new pc cooling fan of the same size and power.
May 06, 2013 | Antec AR300 300-Watt Power Supply
Orange light 3 flashing
Check your power supply cables Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
Check the light on the power supply. If this solution worked, your power supply light will be green
Dec 29, 2010 | Microsoft Xbox 360 Console
My xbox has a three light red ring
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
    Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this:
My xbox is giving me 3 red rings which should mean that there is a connection or hook up problem ive gotten it to work after this once but there were no connection problems then after not playing it for a...
  2. Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  3. Make sure that all three connections are firmly secured.
  4. Turn your console back on.
  5. Check the light on the power supply. If this solution worked, your power supply light will be green....
Dec 23, 2010 | Microsoft Xbox 360 Console
Power supply won't come on, no output of any voltage. LED power indicater on motherboard is on.
First question: is it a new power supply or existing one?
Then we can progress to some disagnosis.
Oct 15, 2010 | Antec AR300 300-Watt Power Supply
Where to buy a Antec AR300
You should ebay or just put the model number in Google. Let me suggest that while the fan may be going out, the heatsink will still be ok. You should open up the fan box and see what size of fan is in there. I believe it looks like a 120mm fan. You can buy a nice one for under $20 and it'll go right in without you even having to remove the unit from the motherboard.
Feb 27, 2010 | Antec AR300 300-Watt Power Supply
I removed the power supply to install motherboard and did not pay attention to the 3 wires attached to the case. what is the order of the wires? They are green/yellow, blue and brown.
All the wires from the power supply are power connectors, depending upon the motherboard not all power connectors from the power supply maybe required. If there are no matching sockets on the motherboard, then that power connector is not required.
Nov 07, 2009 | Antec AR300 300-Watt Power Supply
Connecting to ground or neutral
SOMETHING DOENST SOUND RIGHT ABOUT THAT AT ALL. i would contact an electrician, would not even want to venture a guess as to whats goin on . let alone advise to hook up a ground to a nuteral and cap the nuetral.theres somehtin up there . i would call in a pro on that one
Mar 08, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Antec AR300 300-Watt Power Supply Logo
201 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Julie Endres
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
