Question about Citizen CLP-7201E Thermal Label Printer
Paper Err M CMND Max. 0.70V min. 0.30V Model CLP7201e
What kind of fuse does my mio moovr503t use in its charging unit
The fuse is to be found in the power adaptor
Fuse type : 1.0A / 250v
input: 10-30V/ DC , Max.1A
output: 5V / DC -- 1A
Len..
Oct 14, 2014 | Mio Moov R503T 5" GPS Receiver
My apple ipod has locked down and i can open it is a emcno 2066 rated 5-30v-1a max fc ce[vci] 1gb
You must restore it that will fix all the problems, if not youtube it
Aug 17, 2011 | Apple iPod touch
Every time i press graph on my ti 83 plus it says ERR:Window Range 1:Range how do i solve this problem so i can graph
You will have to hit the window button on the face of the calculator that is just below the screen and change the values making sure the max value is larger than the min value.
May 02, 2011 | Texas Instruments TI-83 Plus Calculator
I have a stupid question where the heck do Iload the paper in my Lexmark X2350 printer??
Facing towards front of the printer, on the back of it you have raiser - paper support panel, with side slider on the left hand, push slider towards left in full.
Paper accepted by this printer is all standard grades, like A4, L4 and fall in these dimensions:
width min/max - 76mm to 216mm (3" to 8.5")
lenght min/max - 127mm to 432mm (5" to 17")
Printer will accept paper weight between 60g and 180g, that meant that all standard weight of paper including cardstock will be accepted, printer as well will print photo and envelopes.
• The paper is loaded against the right side of the paper support.
• The paper guide rests against the left edge of the paper.
1. Put paper long way vertical on raiser (paper support), about 80 to 100 pages of standard paper will fit there (depends on thisckness),
2. Push paper against right side
3. Adjust width with left hand slider. Do not buckle the paper!
After print paper is ejected at front bottom slot, printer side up. if you use photpaper or gloss paper, remove it immediatelly as need longer drying time and will get smudget by next printsheet.
You can find information with pictures in your manual on page 13/14.
Hope this will help you print beautiful pictures!
Aug 11, 2010 | Lexmark Z2300 InkJet Printer
I have a Royal VF810 crosscut shredder and I have lost the operating manual. How could I get another one?
Doubt if you will get a new operators manual on a "consumer" model machine....remember this is a "light-use" shredder...only run the machine at 70% of its maximum rating...lubricate it occasionaly by putting shredder oil on a sheet of paper then shred the sheet of paper...only run it for a "max" of 5 mins then give it 10 mins to "cool down".....
Jun 14, 2010 | Royal Office Equipment & Supplies
ERR:DATA TYPE
Have you checked your "window" settings?
X min=-10
X max =10....etc.
Please post bck if this didn't affect it.
Hope this helps!
Rumblin_Racer
Mar 11, 2009 | Texas Instruments TI-84 Plus Calculator
When graph get err dim how do you fix
ERR: DIM means your dimension (Xmin,Xmax that kind of stuff) can not show all of your data. You need to change your X,Y min and max so it fits. this usually happends only when you try to display plots of any sort. It is very annoying trying to get the right dimension....
Jan 12, 2009 | Texas Instruments TI-84 Plus Silver...
Error on window range
You should check your window and make sure that the X-min and Y-min are less than the X-max and Ymax, respectfully
Sep 23, 2008 | Texas Instruments TI-83 Plus Calculator
Citizen CLP-7201E Thermal Label Printer Logo
104 people viewed this question
Top Citizen Office Equipment & Supplies Experts
jay kaye
jay kaye
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
