Question about Sentry Fireproof Safe
I unlocked my safe and now the lock won't engage to when I close the door. The lock is stuck in the open position and the key won't turn. Does anyone have a solution to this issue?
  • Anonymous Mar 25, 2014
    I opened my safe and when I went to close it the dial is stuck.
    Scholar:
  • Sentry Expert
  • 170 Answers
Locksmiths agree that you have to unlock the safe just like when the door is shut and locked. Once you dial the sentry safe combination the handle will retract the bolts.
Posted on Aug 16, 2010
Can't get door to lock. I put in code, close the door but it won't lock. Position of key?
Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
Mar 23, 2015 | Home Security
My sentry safe, number bx-887566, is stuck in the open position. The lock is engaged and the key won't turn. How do,I fix this??
I did this on my own safe. Different brand but you can try. Somewhere on the door , look for a latch or pin or rod that you can push in.These are usually triggers that allow the lock to turn only when the door is closed. Somehow, you have locked it with the door open (as I did). Press in any of these and try turning the lock. It will be tricked into thinking the door is closed and allow you to turn the key. Good luck
Dec 03, 2014 | Home Security
How to program my new control remote to my Honda passport 2000
Try this please!
'98 - '02 Isuzu Rodeo and Trooper and Honda Passport(with factory keyless entry) Instructions for programming. 1. Get in car and make sure all doors are unlocked. 2. Open driver's door and leave open. 3. Put key in ignition. 4. Turn key to 'on position' (dash lights on, but do not start) and back to 'off position' 3 times in 5 seconds or less. (you must turn the key very fast) 5. Close and open driver's door 2 times in 5 seconds or less. 6. Turn key to 'on position' and back to 'off position' 5 times in 5 seconds or less. (turn key very fast) 7. Close and open driver's door the doors should lock and unlock twice after this happens push the lock or unlock button on the remote, doors will lock and unlock. Push the lock or unlock button a second time and doors will lock and unlock again. You are finished! The above sequence erases all previous codes and adds the new code as #1. If you are adding a second remote, you should follow the same sequence with the exception of step 6; instead of turning the key to the 'on position' and back to the 'off position' 5 times in 5 seconds or less, do it 3 times in 5 seconds or less and then continue to step 7. ***Remember to turn the key to the on and off position very fast. This works! Follow directions EXACTLY. I had to try 3-4 times before getting it to work. I failed to go exactly by the instructions the first few times.
Jan 03, 2013 | Cars & Trucks
Key won't turn clockwise...
it,s probley the lock cyl.
Jun 12, 2012 | Cars & Trucks
Key turns freely in deadbolt, but suddenly won't engage the lock
get in a locksmith ( possible ******* entry attempt damaged the tumblers)
or
replace the lock unit
Nov 20, 2017 | Locks & Locksmithing
How do you lock it?
Hi Celsa,
Please follow the below instructions to unlock and lock depending on the series of sentry fire safe security you have.
H & F Series:
To unlock and open:
1. Insert key in lock and turn counterclockwise.
2. Apply downward pressure on top of the safe, while
pushing the latch in to release.
NOTE: Due to compression of the gasket, the
unit will require slightly more force
than a safe that does not have a gasket.
To close and lock:
1. Close and press down on lid to engage latch.
Safe can now be transported without locking it.
2. Insert key in lock and turn clockwise.
HD & FD Series:
To unlock and open:
1. Insert key in lock and turn clockwise.
2. Pull up from bottom
of latch while pushing
down on lid to release.
To close and lock:
1. Close and while pushing down on the lid, press down on
the latch until it is secure.
2. Insert key in lock and turn counterclockwise.
For the complete manual with images you can click on this link :- http://bit.ly/lzdBP2
Hope this helps.
May 11, 2011 | Sentry 1110 Fire Safe Security Chest
How do Idisable the alarm
  • 1
    Close any open doors, and lock them all from the driver's door. You should hear the other doors locking when you turn the key in the driver's door. Check the other doors to make sure the lock indicators are in the "Locked" position.
  • 2
    Wait at least 15 seconds. Then, unlock the driver's door with the key. This should disable the alarm.
  • 3 Take your car to the Saab dealership if the alarm engages even with the car unlocked. That likely means there is a contact inside the lock on the driver door that is faulty.
  • Dec 26, 2010 | 1994 Saab 9000
    The key on my 1999 volkswagen beetle is stuck in the door lock. As the key was held in the unlock position both windows were rolled down. No amount of jiggling or turning and twisting can get the key out....
    dont know if you recd my previous so again...unlock/hold over windows go down,lock/hold over windows go up/sunroof closes.(alarm/immobiliser resets)....key stuck in lock, pull hard when upright,moving the key up/down when pulling, should do it.also bootlid lock two positions,turn left,then release or turn right and release,see what happens......(boot isolation from the central locking)
    Sep 25, 2010 | 1999 Volkswagen Beetle
    Programming keyless remote
    2003-04 Mazda 6 REMOTE PROGRAMMING
    Step 1: Open drivers door and leave open.
    Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
    Step 3: Insert key into the ignition.
    Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
    Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
    Step 6: ECU should respond by locking and unlocking the doors.
    Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
    Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
    Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
    Good Luck.
    Jul 12, 2008 | 2003 Mazda Mazda6
    New sentry csw3813 stuck open
    do you have the manual i have the same problem but close and the manual is inside the safe is the original keycode but dont remember it
    May 18, 2008 | Sentry Fireproof Safe
    Sentry Fireproof Safe Logo
    1,814 people viewed this question
    Top Sentry Home Security Experts
    Jim London
    Jim London
    Computer Repairing
    Computer Repairing
    Hannah Johnson
    Level 1 Expert
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
