Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Er if message on display. Not sure the fidge is running
  • LG Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerer if message on display. - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 07, 2010
Error message Er 1F
Maybe this will help. i would check fan first and see if ice has built up in fan.
https://www.youtube.com/watch?v=a4MdwuoN3jc
May 26, 2017 | Kenmore Refrigerators
Sequence error warning comes up on display, as soon as i turned on my ER-5215 M cash register, how to fix it?
I have a cash register Model# ER-5215 M there is a message on the screen as follows: Reg. PBAL how do I fix it.
Jan 21, 2013 | Computers & Internet
What does the message "Er
Hi
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Please get back to us if you have further query or else please accept the solution.
Sep 02, 2011 | U-Line BI-95
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Westinghouse Model WSE6070WB*5 Error code: Cn Er
I recently had this message on my Westinghouse fridge. The CN and ER message stands for Connection Error. This is due to a power surge.
I suggest you disconnect the power cord from the powerpoint and switch off for 5 minutes.
When connecting, if you have a double power point use the other head as the initial one may be faulty and this may have caused the power surge.
Hopefully this will fix the CN ER message to disappear.
Jan 22, 2010 | Westinghouse Refrigerators
There is an ER message flashing.we tried pressing cancel but nothing happens. it's like all the settings are frozen
This is a Common Error Message. Try to Disconnect the Power Supply, and wait for few minutes, say 30 minutes to Turn it ON.
If still ER message is displayed, you need to Replace either Touchpad or Control Board.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2010 | Frigidaire Dishwashers
Er if code on display
ER means Error code......
The If error message indicates that the fan for the ice maker has failed. The main control board receives a feedback signal from this fan motor for the ice maker. If the feedback signal is abnormal or missing, then the error message will be displayed. The fan motor for the ice maker could be bad. You could also have a bad wiring connection between the motor and the control board. A remote possibility would be that the control board is bad. This is not likely since you noticed the ice melting in your storage bucket.
I recommend calling a service technician to diagnose and repair this failure.
Sep 20, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG Fridge Freezer display has CF error code
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
Dec 07, 2008 | LG French Door Cabinet Depth Refrigerator...
Error message
Check and see if there is a fuse on the back of the unit if so check it to make sure that it is not blown. Also make sure that it is at least a 25 - 30amp fuse. If that is not it the make sure you have the power wires hooked up right. See a Er-05 message means that the power that that unit needs is not there. So it will not read all cd's. It takes more power to read a burner than a normal cd. Hopefully this helps
Dec 11, 2007 | Kenwood KDC-MP228 CD Player
Sub Zero refrigerator
Its trying to tell you to call someone to clean the condensor.....nice feature! Sub-zero refrigs are very sensitive and will run too much and even possibly start icing in Refrig compartment.
Oct 09, 2007 | Refrigerators
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
76 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
