Question about LeapFrog Clickstart My First Computer
The on/off switch's light stays on and the computer will not work
  • dwrob Aug 07, 2010
    I have tried the suggestion of removing battery, waiting 3 minutes and then plug the A/C in again. The on/off light still remains on and the game will not work. Any other suggestions?
    No luck! neither suggestions work.,
    Can we try again please for another suggestion
  • 11,896 Answers
If the switch will not shut it off and it stays on but doesn't work, then likely there is a power board issue. possibly bad capacitors or resistors are causing interference with the power signal. Or the switch needs to be replaced because it is shorting something out.
Posted on Aug 07, 2010
    President:
  • 1,961 Answers
Try removing the battery and press and hold the power switch for 5 mins see if it works..tnx.
    Guru:
  • 825 Answers
Remove the batterywhen there is no A/C supply... wait for 3 mins and plug it back and try once again... hope this works...
My 2006 f150 has new brakes and rotors,fluid full but my dash brake light stays on. Soon as you start it and the whole time you drive. Also the cruise quit too. Once the light went off then the cruise
This sounds like the brake light switch or the control switch on the brake pedal is bad or loose. Check under the dash above the brake pedal there should be one or two switches that tell the brake lights to come on and the cruise control to shut down.
Feb 13, 2015 | 2006 Ford F-150
My brake lights stay on while driving my 2008 chevy 1500 Silverado any solution
I've seen lots of problems with brake switches on these style pickups. Usually they stick on. That also prevents you from being able to set your cruise control, because the engine computer sees that the brakes are on, when they're really not. If you have access to a scan tool that can read codes and data, there should be a Diagnostic Trouble Code stored in the engine computer related to the brake switch. You can also verify by looking at data in the scan tool that the switch is actually staying "applied", when it really should be "released".
If you don't have a scan tool, reach under the dash by the top of the brake pedal and unplug the brake switch. If your brake lights turn off (ignition key has to be on for brake lights to work), then you've found your problem.
Oct 13, 2013 | Cars & Trucks
Oven wont start
There are four door operated interlock switches that control various operations. The upper primary interlock activates the high voltage circuit and the light and computer are on a different switch. So the light can come on the computer can work, but the oven will not actually run. Pull control panel to access or remove case.
Oct 06, 2012 | GE JVM1790 Convection / Microwave Oven
My dome light on my 2006 Ford fusion stays on for 11 mins straight how can I fix it
Hi.. On your Fusion the dome light will stay on
If the Body cumputer detect any door open,
This happen when the Door Ajar Switch when bad.
The Body computer Don't receive the signal of the switch.
After 11 Minutes The Body will turn off the Light .
With a system Called Battery Saver.
The Alarm system will not work right.
I recomend Try to do Computer Diagnostic.
To find wich Ajar switch is bad and have replace it
I hope this help on your question.
Thank you for use Fixya. Feel fre to ask anything..
May 17, 2012 | 2006 Ford Fusion
1998 escort zx2 dome light stays on when switch is set for door; all other indicators, chime for key in ignition etc seem OK. Light works normally in switch on and off positions.
It should stay on for about 30 seconds and go off. Otherwise, the car is 11 years old, so find a switch position which does not drain the battery.
Oct 06, 2009 | 2000 Ford Escort
Monitor screens blanks a few seconds after I switch on computer
Took the cable connecting the monitor to the computer and reversed it, this seems to have worked!
Dec 21, 2008 | Sony SDM-S74 17" LCD Monitor
Headlights wont come on and bright lights won't stay on hold bright light switch and blower works
I had the same problem. The solution is simple; the ignition switch needs to be replaced. This is an easy do-it-yourself project. Here are instructions:
http://forums.vwvortex.com/zerothread?id=2532481
Check for a switch on ebay, they are about $15. After 10 years they wear out.
Oct 07, 2008 | 1998 Volkswagen Jetta
LeapFrog Clickstart My First Computer Logo
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
relojmesa
Crystal Turner
Level 1 Expert
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
