Question about Magellan GPS
Gps crossover screen repair - Magellan GPS
    President:
  • 1,111 Answers
Buy a broken crossover off ebay...a 2000, 2200 and 2500 have the same screen...i might have one if you cant locate one on ebay, but will need fixya permission to help you further....the screens are also available new online if you want to pay 100.00 for one...not really worth it, since you can buy a new crossover for that
bill
Posted on Dec 21, 2010
How much to replace the cracked screen of crossover gps , parts only
Hi platchfo,
buy a broken one off ebay....you can get either a 2000,2200,2500 or a crossover they all use the same screen...this guy HERE has a 2000 for 20.00...ask if the screen is ok and ask will it fit yours, just to be sure....
Bill
Standing Member of G.O.T.
Please Support Our Troops
Mar 18, 2011 | Magellan Crossover GPS
Display only blinks, how to reset the unit?
hey there michael_wick,
you need to install version 1.68 first before the 2.14 unless you have that installed already.
why cant you update it via the USB cable to your computer...all magellan GPS require at least Windows OS XP service pack 2 to sync with the computer.
if your not seeing the crossover listed in your computer, can you see the usb connection wizard in the lower left of the task bar on your computer.
btw, is this a true crossover, or a 2200T thats been upgrated with the crossover firmware?
Bill
PLEASE SUPPORT OUR TROOPS
Oct 12, 2010 | Magellan Crossover GPS
Touch screen does not respond
turn the crossover on, looking at it from the front, there is a rest on the side and depending on whether its an older or newer crossover, it will either have a slide switch or a tiny hole to reset it on the left side towards the bottom...if it has the slide switch, move it in the opposite direction (it should turn off) now move it back, then power it on again...if its the pin hole type, get a paper clip and insert it in the hole to reset it..turn the crossover one first. (it should restart by itself)
if the reset doesnt work, it probably needs a digitizer (the touch part of the screen) if you think you need a digitizer, let me know and ill show you where to get one.
bill
Sep 21, 2010 | Magellan Crossover GPS
Magellan crossover gps wont turn on,try resett button held for over 10 seconds its dead
this is very common problem with this and many model magellans.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
Oct 19, 2009 | Magellan Crossover GPS
It wont show the streets and wont shut off
try and reset the your crossover. on the left side under the sd card slot is the reset. depending on the date it was manufactured, it could have one of two different switches. one has a switch you slide down and then back up to reset it. it must be in the up position for your crossover to turn back on.
turn the unit on, then slide the switch down, then back up!
if it is a later model crossover, you just need to depress the button with the gps on and it will reset.
Oct 12, 2009 | Magellan Crossover GPS
My gps does not show streets
My magellan crossover gps keeps shutting off in navigation mode - why?
make sure its charging..plug it in to a known good charger..go to the main menu, then systems options then power the power bar on the bottom should be moving from left to right..if its not, its probably the dc power port
If your GPS is not charging, the following models are known to have faulty power ports.
Magellan Maestro or Roadmate..800 860 2000 2200t 2500 3000 3050
3100 3140 4000 4040 4050 6000t
you can buy a power port HERE
or get it repaired HERE
bill
Oct 01, 2009 | Magellan Crossover GPS
Chatring port Magellan 4040 not working dc or ac adaoter port defective?
Hi beach2640
The following Magellan 800,860,2000,2200t,2500,(crossover) 3000,3050,3100,3140,4000,4040,4050,5310 and the 6000t are known to have faulty dc connectors...if your Magellan
You may also have another issue with the screen but you need to find out why its not charging 1st.
You can get it repaired
here
Or buy the port here
Let me know if you need further help!
Bill
Sep 27, 2009 | GPS
My Magellan Crossover's batttery was dangerously low - tried to charge it with SwitchPower Supply -didn't work.The screen has a faint glow - can't turn it off or on. Can take the back off and change the...
hi gtrojan even with a deed battery or no battery at all for that matter, your crossover should still start normally while connected to external power.
first try the reset, with the unit on (even if it is dim)use a paper clip and insert it in the little hole on the side. if it starts normally and is still plugged to the charger, go to the main menu/options/power and see if the chaging indicator is moving from side to side. if it is not moving,
The following Magellan 800,860,2000,2200t,2500,(crossover) 3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your Magellan gps is not charging or will not power up, its most likely the dc power port.
you may also have another issue with the screen but you need to find out why its not charging 1st.
you can get it repaired here
let me know if you need further help!
bill
Sep 18, 2009 | Magellan Crossover GPS
GPS Logo
77 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
