Question about Kingston 2GB PC2-5300 DDR2 Desktop Memory
I have Compaque Laptop . It runs very slowly. Compaque has supplied me with Kingston 2gb usb but I dont know how to use it and whether by installing it will it improve the speed of my laptop,I do not know how to fix it and what help will it render by its installation. Please explain in details as i am senior citizen and my knowiedge on computers is zero. Thanks. Rusi Siganporia.
  • 808 Answers
Symptoms u have identifies are most probably linked to registry errors on ur computer it is wise to run? a registry repair scan with reg in out? registry cleaner....
Posted on Sep 09, 2010
  • 225 Answers
A computer can be slow by many reasons - viruses, bad sectors on the harddrive, lack of empty space on the harddrive and ofcource, small amounth of random access memory (RAM).
Only to mention, that the memory on the picture is not for laptops and you have written "usb", which is not memory for adding to the RAM space of the laptop.
I will assume they sent you the right kind of memory.
Installing it is easy. You will need a small x-screw driver to open a small cover on the bottom of the laptop. There re usualy 2 or 3 covers there. You may open all of them to see where is the memory connector. You may or may not already have memory there. Remove the old if there is no place for the new. To remove, pull two end latches to the side and the memory will tilt up. To insert the new, insert it the same way tilted and when the contacts are fully in the connector, press it down to lock the latches.
Posted on Aug 07, 2010
Sir em using kingston 2gb usb.bt the problem is that i have deleted autorun fron it,so it is not running in my car fm modulator
Solving this program is SIMPLE. Your BEST option is to contact Kingston directly:
http://www.kingston.co,/support/default.asp
Answer the questions on that page and follow the prompts to get help from Kingston. They will know how to help you solve the problem at no cost. They can e-mail you the proper AUTORUN.INF file; you can then COPY it to the USB drive so it will work again. KEEP A COPY OF THE AUTORUN FILE IN A SAFE PLACE, in case this problem occurs again.
Good luck; let us know how this turns out.
Apr 15, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My Kingston 2GB USB is write protected. i dont know how to remove it coz i cant delete copy or format it
Check the USB device to see if there is a switch that makes it write protected. If so, change it back. If you're still having problems, it's probably defective.
Mar 16, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Cost of 2 gb
the said usb would cost you around 9 usd,if you wanna buy it,here is the link below.go into this link and purchase it from indiatimes shopping.Do it fast as the stock dont last longer
http://shopping.indiatimes.com/Computer-Peripherals/Storage-Printing-Supplies/KINGSTON-Pen-Drive-2GB-Data-Traveller-2-GB/ctl/20376650/cat/960057/pid/1734316
Dec 10, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Dont have drivers
hello
see link below
http://www.kingston.com/flash/datatravelers_consumer.asp
http://www.kingston.com/flash/u3center.asp, you may have to contact Kingston, as one of the links inside is broken
let me know if i can be of further assistance
Nov 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kingston 2gb memory card was locked.how to unlock the memory card.i dont know the password.
What application you are using? This application might have a reset password option. Files maybe encrypted.
thanks,
Dexter
Jul 12, 2010 | Kingston 2GB Secure Digital Memory Card
Unable to open kingston pen drive
try opening by scrolling through addressbar
Mar 26, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB 2GB KINGSTON DATA TRAVELLER HANGS MY LAPTOP
USB KINGSTON CAN'T ACCESS TO MY LAPTOP.HOW CAN SOLVE MY PROBLEM.
Mar 02, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a kingston 2gb and i dont know how to get my pics on it
Hi shenicamangr,
From inside My Computer, open the DT then from the menus at the top click on File, New and Folder. Type a name for the folder. Now go an find the picture files you want to copy. Right click on a file to copy (or press Ctrl-A to highlight all files) then select Copy from the menu. Go back to the DT and open it. Right-Click on the new folder you created and select Paste from the menu. All of the files should now be in the new folder.
For more information on how to use the DT go here: http://www.kingston.com/support/howtodt/default.asp
Kingston Tech Support
Jan 02, 2009 | Kingston 2GB Secure Digital Memory Card
I have 2GB Kingston USB. My computer can't detect it. Can anyone solve my problem?
Hi yseitaj,
First check the other USB ports. Try it in the USB ports on the back of the computer. If that doesn't help then make sure you have the latest service pack installed, if you are running Windows. Test other USB drives on that computer and/or test your USB drive on a different computer. This will tell you if the drive or the computer is the problem.
Dec 15, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 2GB PC2-5300 DDR2 Desktop Memory Logo
105 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
