Question about Haier Heating & Cooling
Blades are hitting water and making a loud noise. no hose in the back of air conditioner to drain water, what should I do
    Problem Solver:
  • 5 Answers
Is there a removable plug (Metal or plastic on the bottom of the unit ? If so remove the plug (Knife of flat blade screw driver. I believe some units are supposed to disipate the water in the exhaust air. If the unit is over a year old you may need to clean the coils (Behind filter - I am assuming you cleaned the filter) to reduce icing and water build up. I have drilled a hole in some to release the water. You drill a hole in the right or left rear on the bottom and YOU MUST MAKE SURE THERE IS NOTHING ON THE OTHER SIDE WHERE YOU ARE DRILLING (like a freaon line, compressor, wires, etc.).
Posted on Aug 07, 2010
Unit makes a loud rattling noise when operating
Hello, most likely the fan blade is either loose or cracked at the hub causing the blade to hit the fan shroud. You will either have tighten the fan blade or have to get a replacement.
Jun 20, 2012 | Kenmore 71121 Air Conditioner
My unit is throwing water out of the front vents not a lot. It sound like the fan blade is hitting water It still cools but makes a loud noise .R bordeaux
The water and noise you hear is from the fan blades hitting backed up water in the drip pan. This occurs when the drain hole near the rear of the drain pan is clogged and/or the rear of the unit does not have enough downward tilt. Which allows the water to flow freely to the drain hole. The general rule of thumb for downward tilt is 1/4" to 1/2". Correcting these to things should solve the problem. Be sure to turn the unit OFF & Unplug it, before attempting remedial service work on the unit.
Hope this helps you and thanks for choosing FixYa.
Aug 22, 2011 | Haier ESA3125 Wall/Window Air Conditioner
My ac is spitting out water in the front and making a loud noise
Your noise is probably your fan hitting water. First try to tilt the ac to slant to the outside. If this is done water should drain to the outside if not your drain hole is blocked from the front to the back you can see this if you remove the unit and look at the front coil housing you will see a very small weep hole clean it out and use a water hose to clean the front coil and the back coil. good luck
Aug 08, 2010 | LG Electronic Window Air Conditioner
Started making a real loud noise like fan hitting. 7 years old should I replace with new one?
It does have a fan and something could have become misaligned allowing the fan to hit the evaporator or it could be icing up and the fan hitting the ice in which case it's low on freon. Take the front off and remove the filter to inspect the fan etc. before you throw it away.
Jun 22, 2010 | Maytag M6Q10F2A Air Conditioner
Started making a noise, spitting water from vent
there is a drain on the pan under the cooling coil - your "blades" if you are looking in from the front cover - the opening could be stopped up going to the back of the unit - you will have to pull it out of shell to see drain line
Sep 22, 2009 | LG Electronic Window Air Conditioner
New unit has loud noise & doesn't drain. Too late to return!
drain line kinked? trying to diagnose a noise problem over the inter net really hard . could be compressor
Jun 17, 2009 | Danby Portable Air Conditioner
HEATER MAKING LOUD NOISES
Check the draft inducer motor for any partial blockages or dibri.
I've seen sticks, birds nest particles and pieces of deteriorating fan blades (squirrel cage type fans) cause this.
You might also find that the inducer motors bearing are going.
If its a loud vibrating grinding type noise, I'd suspect bearings or missing pieces of the blades. (unbalanced)
If it's a clanking type noise I'd suspect loose items hitting the fan.
The inducer motor will only operate right before and during burner operation, while the blower motor can operate at any time depending on your setting.
Dec 06, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Is there a drainage plug or hose on the air conditioner? It's leaking.
To increase the efficiency of the air conditioner's cooling to meet US energy requirements, most manufacturers eliminated the traditional drain plug. Instead, they switched to a design that used the extracted moisture from the room to help evaporatively cool the condenser.
To do this, the traditional fan blade was replaced with a 'sling blade' which was a fan blade with a rim or ring around it. The drain plug or drain hole in the bottom of the pan was eliminated and replaced with overflow notches in the back edge. Along with a solid piece drain pan, this provided a pool of water for the edge of the sling blade to dip into and pick up water to 'sling' or spray around the compartment to create evaporative cooling. The overflow notches established the maximum depth of the water pool and are also the lowest place when installed properly.
Although this is more efficient, this has caused 2 problems: increased noise as the water is slung around and water spray from the side air vents.
Persons have drilled holes through the pan or back edge as drains. This is not recommended as it negatively effects the colling ability of the unit and could lead to a voided warranty or premature failure.
Instead, insure that there is adequate pitch with the installation and make sure the overflow notches are kept clear.
If you 'need' a drain hose, my suggestion would be to drill into drain pan's back edge or the rear potions of the sides. The hole should be at the same level as the overflow notches. Once the drain hose is installed, block/cover the overflow notches to redirect the excess water to the drain hose instead.
Jul 07, 2008 | Samsung AW0603B Air Conditioner
AC make loud noise on power off.
Is this a wndow unit or central air system? if this is a window unit , your problem is it only needs cleanning (dirt dbber nest-- trash around the back blades-- or the unt is twisted and rubbing the fan shroud. Last but not least, the slinger ring around the back blades (a ring around the end of the blades thats picks up water in the bottom of the unit and sling it on the coils to help cool the hot gases....Thank-you Thank you Thank you very much!
Jun 02, 2008 | Heating & Cooling
Water in housing
You will need to clean the evap coil with a bleach type product and then hose out the condenser coil as well. The bleack will also remove algie from the evap water pan. THX RepairUSA
Aug 26, 2007 | Goldstar R5050 Air Conditioner
Heating & Cooling Logo
249 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
