Simpson 175 washing machine: spin cycle noisy and motor cuts out after short spin. Bowl feels stiff
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Posted on Aug 07, 2010
Excessive bowl swing on spin cycle - machine cuts-out. SIMPSON 22s650. tried adjust load balance but still wobbles to cut-out. Sometimes OK with an under loaded light load.
Sounds like it needs new suspension rods. One on each corner. The spring on the rod gets weak causing excessive bouncing & swinging.
Jul 17, 2017 | Simpson Washing Machines
How to clean drum in fisher paykel washing machine ? Also why so noisy and moving across floor on spin cycle?
bowl out of balance
bowl not level
check for suspension bolts and insulators holding the bowl level
Jul 18, 2016 | Fisher and Paykel Washing Machines
Hi, i have a simpson 9.5 kg ezi set and it has been going out of balance only on light loads, could you please tell me possable cause thank you
Could be the drum bearing. If it's noisy when operating that could indicate the bearing is deteriorating.
Jul 01, 2016 | Simpson Washing Machines
Simpson washing machine problem have taken out stainless steel wash bowl and the plastic top/seal around it has water in it is that normal for that to happen
Yes. Some have water & some have sand in that ring. It is a balance ring to stop vibration when bowl spins. Do not empty it.
Jun 27, 2016 | Simpson Washing Machines
I have simpson eziset 7.5kg has trouble spinning throws clothes to one side of tub
check that the machine is level
check that the wash bowl is level as a support mount may be failing and the bowl is not level
when it happens redistribute the clothes to a better balance point and re-spin
if it still happens ,seek the services of a washer technician.
Apr 07, 2015 | Simpson Washing Machines
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Simpson 175 shorting out
there are 2 items that come into play when the wash cycle starts 1 is a capacitor for the motor and the other is the module that works the agitator.. The module when it fails will not spin the motor so I seriously suspect that the capacitor has failed giving you a direct short to earth
Jun 01, 2013 | Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Simpson 175 HD washing machine Programme keeps stopping Is it the timer or some other problem
image_bubblequestion_04.gif Can you please identify the problem with my washing machine?It appears all the functions of my simpson 175 washing machine work normally except the agitator only moves briefly and harshly for between 1 and 2 seconds.
Simpson 175 HD (Dual Action Agitator) Washing Machine.
1517 5M40 A 28 June 1990
Jul 12, 2008 | Washing Machines
Washing Machines Logo
307 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
