Question about Frigidaire Dryers
Frigidaire affinity dryer will not start. It gets the dr code. I assume that means door problem but if I hold the select button down on the temperature selection it will run but as soon as i let go it reads the dr code again. I cant stand there and hold button for an hour while clothes dry. But if it was the door why would it run while the button is being held.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 52 Answers
Repairs should be performed by an authorized servicer. insure that the door is properly closed unplug the unit and perform a continuity check on the door switch. if the door switch is ok reconnect the door switch and plug the unit to the power supply. if the problem still exists then you have a control issue. be sure to call your nearest service center to schedule for a repair. have your model and serial number available.
Posted on Sep 23, 2017
SOURCE: Frigidaire Affinity Dryer
So my husband figured it out. We took out the book in the back and then took out the push button and we figured out that the switch inside was melted and it wasn't reading that the door was closed. He unstuck the switch and it worked again!!! Thanks anyways for your help!!
Posted on May 19, 2008
larryyb
  • 291 Answers
SOURCE: I just bought and installed
you should have 4 wires / red, white, black and green / red and black goes to the outside temmals and white to middle and green to cabinet / check and see if you have it connected that way / larry
Posted on Dec 04, 2008
vickygomar
  • 460 Answers
SOURCE: shuts off, clothes not dry, but if start button is held then drys
this video will help you to check all the possibles couses
http://www.youtube.com/watch?v=rQV-z4f7fvA
you may
Need a good meter to check all of this.
Was this helpful?
Posted on May 14, 2009
maddogsteve1
  • 18 Answers
SOURCE: dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
Posted on May 25, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE Select clothes dryer model DSXR453EVOWW
Open the door and remove the screws holding down the top. Then raise the top and you can get to the screws holding the front on. Get the front out and then the drum can come out so you can clean that guy out and replace that belt. How about some repair PHOTOS?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 12, 2009
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Why is my washer displaying a "DR" when I push start?
  • 1 Press any button on the display panel.
  • 2 Wait five seconds and then press and hold the "Start/Pause" button and the "Cancel" button at the same time.
  • 3 Open and shut the door. A "DR" error code indicates that there is a problem with the door, most likely that it has not shut properly. Check to make sure there are no clothes or other items caught in the door.
  • 4 Open the door and gently wiggle the door latch if the door does not click shut. Clean it with a damp cloth to remove excess dirt or debris that may prevent the door from latching into position.
  • 5 Close the door and re-select a new wash cycle and "Start."
  • Jul 25, 2014 | Frigidaire Affinity ATF6000F Front Load...
    I try to turn my dryer on, and it has a "dr" error on the timer??? I would think that means door, but the door is shut??
    press and hold select and cancel buttons together for six seconds this will reset the board.there is also a chance that the door switch is bad and not seeing the door is shut
    Aug 25, 2010 | Frigidaire Affinity AEQ6000WH Dryer
    My frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please help
    Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
    Apr 15, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
    Error Code "dr"
    Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
    Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
    I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
    dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
    Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
    Frigidaire affinity washer doesn't start
    Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
    Please reply or rate.
    Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
    Frigidaire Affinity/dr error
    dr code means door not closed
    get some crc spray and spray into lock on machine
    that will lube the workings and should fix problem
    Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
    Frigidaire Affinity dryer error code?
    HELLO,
    I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
    Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
    Dryers Logo
    110 people viewed this question
    Top Frigidaire Dryers Experts
    Tim Whalen
    Marvin
    Marvin
    Sal De
    Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
