Question about RIM Blackberry 7130e Smartphone
I have a flashed Blackberry 7130e that shows 'data connection refused' when I try to access Cricket internet. I performed a battery pop and attempted a soft reset of alt+shift+delete but nothing happened. I do have data on my cricket account. Can you help me? I used to work as a cell tech and know that usually outsiders can know more than the call-centers!=)
    New Friend:
  • 15 Answers
Sounds like your Blackberry is locked for certain provider, and it does not accept Cricket SIM card. Also, based on the search for your model, it's Verizon, which could be CDMA only. I don't know, if your SIM card for "old Cricket" (which was CDMA), or "new Cricket / AT&T", which is GSM.
Posted on Sep 27, 2017
2 Suggested Answers
  • 13 Answers
SOURCE: i have a cricket fashed blackberry 7130e it always
I have a flashed Blackberry 8330 for Cricket. I know to get the phone and SMS working is pretty easy. There is a second more complicated step to get the data working. I flashed my phone myself, but I couldn't find the solution for the data.
Posted on Oct 09, 2009
Blackberry 7130e. It is showing that it has a signal but i cannot recieve or make any phone calls or texts. It has an arrow flashing at the top by the signal like its sending somthing constantly...how do i...
This problem happens on pretty much any computer-related device. Something happens and you can send anything. It’s annoying, but there are actually two ways to fix it. You can perform a soft reset, which is done by pressing the ALT + CAP + DELETE keys on your handheld at the same time. If this doesn’t work, perform a hard reset. This is done by finding the RESET button at the back of the handheld. Sometimes, this button might be near the bottom, under the battery cover. Press the RESET button using a pin or paper clip. With either method, you shouldn’t lose any data.
Perhaps, is you did not see the reset button,you can also do the hard reset this way, in the process of powering your phone, pull out the battery straight before it finish loading, this helps fix abnormality on the blackberry phone.
Take care.
Jun 05, 2010 | RIM Blackberry 7130e Smartphone
Data connection refused
After cancelling the data plan with the wireless service provider, the message Data connection refused appears at the top of the Home screen on the BlackBerry smartphone instead of the branding of the wireless service provider.
This is caused may be you were previously subscribed to a data plan through a wireless service provider, and the BlackBerry smartphone is still configured to attempt to access the data network.
To resolve this issue, you need to turn off the Data Services feature on the BlackBerry smartphone. To perform this, you need to complete the following steps:
  1. From the Home screen, open the Options menu.
  2. Click on Mobile Network or Network.
  3. Set the value of the Data Services field to Off.
  4. Open the menu and select Save.
  5. Return to the Home screen.
  6. Turn the wireless transceiver off and then on again.
To enable (turn on) the wireless transceiver on the BlackBerry device, go to the Home screen and select the Turn Wireless On icon or open Manage Connections and select the wireless connection to be enabled. Once enabled, the icon will display Turn Wireless Off .
To disable (turn off) the wireless transceiver, go to the Home screen and select the Turn Wireless Off icon or open Manage Connections and select the wireless connect to be disabled. Once disabled, the icon will display Turn Wireless On.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
I get app error 523 every time on my blackberry 8220 pearl flip display
On the BlackBerry smartphone, the following error message appears after pressing the Mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, first perform a hard reset.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If this does not resolve the issue, the BlackBerry® Device Software must be re-installed.
Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps:
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps:
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider
Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  8. Click Ok > Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
  1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
The BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to open and run the application loader tool.
If BlackBerry Desktop Manager cannot connect to the BlackBerry smartphone, perform the following steps:
  1. Remove the battery and run loader.exe from C:\Program files\Common Files\Research In Motion\AppLoader.
  2. Remember to reinsert the battery after the loading operations begin.
Oct 26, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
How to reset blackberry7290 its pop up on the screen error reset 532 when i push the scroll before its operated im on the mood of exploring the phone i change the language from english i turn to portugues...
smartphone.
1) Open BlackBerry Desktop Manager.
2) Click Help
3) Select About Desktop Manager.
4) Click the Device Software tab.
5) Verify that the BlackBerry Device Software displayed is the latest
version currently available from the wireless service provider.
1) Connect the BlackBerry smartphone to the computer and open
2) Double-click Application Loader.
3) Click Next to start the installation process.
4) Type your BlackBerry smartphone password, if prompted, and click
OK.
5) Select the check boxes next to the names of the applications to be
6) Click Settings, and then select the check boxes beside Delete all
7) Clear the check box next to Backup up device data automatically
8) Click Ok > Next > Finish.
9) When the process has completed, the message The loading
1) Click Advanced , and then select the check boxes beside Erase all
2) Click Next.
3) Select the check box next to Do not automatically backup the
4) Clear the check box next to Backup and restore applications
5) Click Next > Finish.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to open and run the application loader tool.
1) Remove the battery and run loader.exe from C:\Program
2) Remember to reinsert the battery after the loading operations begin.
Oct 24, 2009 | RIM BlackBerry 7290
I have a cricket fashed blackberry 7130e it always says data connection refused on the screen. can it be fixed?
Oct 09, 2009 | RIM Blackberry 7130e Smartphone
Blackberry pearl 8130 flashed to cricket
your internet setting are wrong..im not sure if they do it in the contry your in but in australia the service provider sends you messages for the internet setting..ask your provider if they do that
Sep 04, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Blackberry pearl 8130 flashed to cricket wont connect to internet
You can call cricket and ask them to "refresh" your internet, wait 5 minutes and try again. Worked for me.
Aug 26, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
RIM Blackberry 7130e Smartphone Logo
29 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
