Question about Health & Beauty
Shifted harmonic oscillator in 1 dimension. Actually problem is a harmonic oscillator potential is not symmetric about x=0 but about x=a.How will be the eigenfunctions and eigenvalues. Show explicitly.
2 Suggested Answers
  • 8073 Answers
SOURCE: Matrix - casio fx9750GA plus
This calculator cannot find eigenvalues and eigenvectors of matrices for you. The calculator does have many row and column operation that you can use to solve your problem. You need to know the theory of matrices, determinants, and some eigenvalue and eigenvector finding algorithms.
Posted on Dec 13, 2013
Explain why a curve that is symmetric about the x-axis is not the graph of a function, unless the function is y=0
If a curve is symmetric about the x-axis, for a point (x,y) there is a symmetric point (x,-y). As you know from the definition of a function, to each value x from the domain of definition there corresponds at most 1 value y on the range. So if the curve is symmetric about the x-axis, every point has a symmetric. That is not a function.
Aug 09, 2014 | Office Equipment & Supplies
Is my barracuda a 318 or 360
360 - harmonic balancer pulley you will see a weight cast into the design
318 - is internally balanced like most engines are, and its harmonic balancer pulley will be 'symmetrical' without any balance weight built-in
Sep 04, 2013 | Cars & Trucks
I am attempting to do some basic 2x2 matrix multiplication on my Casio fx-115ES calculator, however it is behaving oddly and I do not know why. I can do the following: Press Mode, Press 6 for Matrix,...
When you press MODE 6 for Matrix, you're clearing any previously entered matrices. So, you're clearing MatA when you go to enter MatB.
Instead, after entering MatA press SHIFT 4 to bring up the Matrix menu, press 1 for DIM, press 2 for MatB, press 5 for 2x2, and enter the data.
Oct 17, 2010 | Casio FX-115ES Scientific Calculator
I want dimensions of speakers &woofer of model hcs200 but i didnt find on any site of JBL &specs for speakers set & avr134. the entire model no is HCS200.5...
http://www.harmankardon.com/EN-GB/Products/Pages/ProductDetails.aspx?PID=HS%20200/230&accT=1&tsT=0&ovT=0
If this link does not work just look up harmankardon.com where you are
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | JBL 5.1-Channel Home Theater Speaker...
When setting the ignition timing on a 1991 ford ranger 3.0 were dose the rotor need to point, after number one or before number one? the engine is on top dead center
The engine timing markers down on the harmonic balancer/crankshaft pulley should be aligned with the timing indicator on the engine block to "0" degrees when the engine is in the compression stroke for the #1 cylinder, and this is TDC or "Top Dead Center". When something blows out of the spark plug hole that only means that the piston is coming up on TDC, but the crankshaft will still have to be turned until the timing markers are at "0" degrees. You should be sure that you do know how to properly align the timing marks to "0" degrees, and the timing marks must be set at "0" degrees before the distributor can successfully be installed.
Be certain that the timing marks are set at "0" degrees and on the compression stroke for the #1 cylinder, or the timing will be 180 degrees off when you install the distributor. This has to be precise and guessing will not get the distributor properly clocked in so that the ignition timing can be correctly set.
Once you are certain that the timing is set to "0" degrees "TDC", then mark the distributor housing where the #1 position on the distributor cap will be when the cap is installed on the distributor, so that the distributor housing shows a reference mark where the #1 position is, then the distributor should be installed so that the ignition rotor is pointing directly at the #1 position on the distributor housing, or just before the #1 position mark according to the rotation of the ignition rotor. The distributor should be able to turn and point the ignition rotor on either side of the #1 position mark to provide plenty of timing advance or ****** so that the ignition timing can properly be adjusted to specifications after the engine has been started.
Be sure that you follow the proper timing procedure for that vehicle and remove any timing spout connectors that are described in the set timing procedures
Also, be certain that you are actually using the #1 cylinder to set the engine to TDC and to actually time the engine with a timing light. Here is a firing order diagram that should also help to assist you. Let me know if you require any further assistance.
Jun 17, 2010 | Ford Ranger Cars & Trucks
How do I enter the number "0" when entering a password for WLAN? I'm trying to connect to a WLAN using WPA encryption with a password including the number "0" but when pressing "0" it shows up as a star...
Brother's documentation is non-intuitive. Pressing the ' 0 ' key shows a ' * ', but it actually is accepted as a 0 and moves to the next character entry position. Just take it on faith that it enters a 0 when it shows * when entering the wireless key.
May 28, 2010 | Brother MFC 7840W Printer
No manual for my amp.
  • Class-D Monoblock Amplifier
  • Bass Boost Level and Frequency Remote Included
  • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
  • Variable Input Sensitivity: 200mV - 5V
  • Phase Shift: 0° / 180°
  • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
  • High- and Low-Level Inputs
  • 1 Ohm Stable
  • RMS Power Output:
    • 500 watts x 1 chan. @ 4 ohms
    • 900 watts x 1 chan. @ 2 ohm
  • Preamp Outputs: 1 Pair
  • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
  • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
Oct 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
MX-450 universal remote code for AVR-354
Harm an / Kardon 0 0 8 1 ,0 0 3 8
Sep 14, 2009 | Televison & Video
Pc draft fractions
if you are using MS Excel, you can type fractions by typing 0 1/2 instead of typing 1/2 only. All fractions must be preceded by 0 (zero).
Regards!
Jul 04, 2009 | Computers & Internet
Gears of war problem
Simple fix for forward-back movement axis inversion:
In "My Documents\My Games\Gears of *** for Windows\***Game\Config", edit the file "***Input.ini". At the very top, under the section "[Engine.PlayerInput]", change your MoveForwardSpeed to a negative number, like this:
MoveForwardSpeed=-1200
Note that I only play offline, and this setting in this file works great for me with Logitech Rumblepad 2 (although all of the other buttons are still a little off, but that I can live with). I tried every other reference to forward-backward movement and the left Y axis in this file, as well as "<installdir>\Engine\Config\BaseInput.ini" and "<installdir>\***Game\Config\DefaultInput.ini", so don't bother with those...
Dec 08, 2007 | Logitech Rumblepad 2 Game Pad
Health & Beauty Logo
55 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
