Question about Bosch Washing Machines
Not spinning properly - Bosch Washing Machines
  • Bosch Master
  • 2,605 Answers
Hello, Welcome to FixYa. Can you specify the model number, there are many models of Bosch washers. Thanks, macmarkus :)
Posted on Aug 07, 2010
Seems like something is caught in the machine and stops the spin
when spinning the agitator and bowl spin as one unit
check for proper operation under machine
call a technician for a proper diagnosis and quote
Aug 18, 2016 | Washing Machines
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Spin and then stop and alarm
(1) If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced
(2) If the drive belt is faulty or if it isn't tight on the pulleys the washer won't spin properly and could cause the machine to stop.
Mar 16, 2015 | LG WFT1071TP Top Load Washer
How do i get to the bottom of a failure to spin clothes i a whirlpool washing machine model awm320 which is an 800 spin model
Is the machine draining properly?
Have you checked the filter on the pump? What happens when it gets to the spin part of the cycle?
Is it knocking?
Does it go through wash cycle properly?
W
Nov 23, 2014 | Washing Machines
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
LOAD TOO WET AFTER SPIN CYCLE
  • NOT DRAINING PROPERLY
  • spin bowl not turning
  • spin bowl slipping and not gaining proper speed
  • pump blocked
  • pump not working
  • too much soap used
  • take out pump and check all the water ways
  • observe the spin bowl turning
  • Next call for pro help
Apr 01, 2011 | Kenmore 23822 Top Load Washer
Will not spin with load of wet clothes but will spin when empty
clutch not engaging properly perhaps the belt is streched. Timing module not grounded properly, faulty module, motor circuit bad (brushes worn)
Nov 22, 2009 | Washing Machines
Washer would not spin
ken, washer wont spin/proper til water out so if noise[washer tring to spin,then its up to the pump to get the water out for proper spin,if no noise most brands the prob.would be a lid switch proplem
Jan 01, 2009 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
