Question about Kitchen Ranges
How can we calculate the stranded wire to ampere? what is the formula?
    Sergeant:
  • 216 Answers
Cooking ranges are generally only a 30 AMP circuit, therefore you would need number 10 gauge Wire. If the range is a 50 Amp cook top then you will need Number 8 gauge wire.
The formula to use is Watt / Volts = amps.
Below is a wire sizing chart to help.
This chart refers to copper wire and not Aluminum.
Posted on Aug 07, 2010
How many amperes of circuit breaker for .75 hp aircondition
At 220 about 3 amp full load, at 120 about 6.5 amp full load. Formula in link below
Electric Motor Online Calculator
Aug 03, 2016 | Carrier Heating & Cooling
Keeps blowing internal breaker
The unit rated at 3 HP at 115 volts draws 13.8 amps is odd, a HP in watts is 745 and should be about 2200 watts and 19 amps plus a efficiency loss. Odd to see the ratings don't jive with electric theory/formulas.
The compressor should be connected directly to the wall and if using an extension cord, the cord needs to be #12 AWG or larger to avoid line voltage loss and over amping of the motor.
Here is contact and support info: For more information, please call 800/4-MAKITA (800/462-5482) or visit makitatools.com.
My bottom line is, A 115V motor circuit needs 10 amperes per horse power or 30 amp circuit for 3 horse power. Using extension cords calls for upgrade in wire gage of the cord. The advantage of using 230 volts is it cuts the amperes in half and allows use of smaller gage wire. Watts, or volt amperes is the product of volts and amps.
May 18, 2015 | Makita MAC5200 3.0 HP Air Compressor
My problem is that Model 16N5-K, 120v 60Hz 12 amp Bissell Vacuum cleaner has no wattage indication in the unit itself, in the box, in the product brochure. our power output in the Philippines is 220v. I...
All the information you need is in your text :>)
Volts, Amp Watts To determine the wattage, use a simple multiplication formula. The ampere (or amps) is the amount of electricity used. Voltage measures the force or pressure of the electricity. The number of watts is equal to amps multiplied by volts.
How to Calculate Wattage (Formula and Tools) - wikiHow
www.wikihow.com/Calculate-Wattage
To find a step down transformer for 1440 watts, you will buy a new vacuum cleaner cheaper.
volts amps watts equation Google Search
Oct 01, 2017 | Vacuums
Source coil
the formula P=EX I will guide you to use the next formulas:
2. Voltage and Turns in Coil:
Voltage (p) x Turns (s) = Voltage (s) x Turns (p)
or Ep x Ts = Es x Ip
A. Ep = Es x Ip
Ts
B. Ts = Es x Tp
Ep
C. Tp = Ep x Ts
Es
D. Es = Ep x Ts
Tp
3. Amperes and Turns in Coil:
Amperes (p) x Turns (p) = Amperes (s) x Turns (s)
or Ip x Tp = Is x Ts
A. Ip = Is x Ts
Tp
B. Tp = Is x Ts
Ip
C. Ts = Ip x Tp
Is
D. Is = Ip x Tp
Ts
God bless you
Jul 01, 2012 | Cars & Trucks
Number of turns of honda tmx 155 source coil
using the formula P= E x I will guide you to use the next formulas:
A. Ep = Es x Ip
Ts
B. Ts = Es x Tp
Ep
C. Tp = Ep x Ts
Es
D. Es = Ep x Ts
Tp
A. Ip = Is x Ts
Tp
B. Tp = Is x Ts
Ip
C. Ts = Ip x Tp
Is
D. Is = Ip x Tp
Ts
God bless you
What size breaker does the sm-11 require 2-30amp or 2-60 amp?
You will need the 2-60A breakers. 11kw is 11,000 watts. Watts = voltage X Current (amperes) If we take this formula and change it around to calculate amperes it is like this. Amperes = watts / volts amperes = 11000 watts / 240 volts This is 45.8 amperes or let us say 46 amperes. The closest breaker that you have would be a 50 amp breaker 2 pole of course . 2 - 50. If you cannot get a 2 - 50 then a 2-60 is fine. I would run with a #6 copper wire, I would check with local code to verify the wire size in your area. Make sure that the unit is grounded as well. Minimum of a #10 wire, I would also check local codes as well. Enjoy the steam!
Dec 27, 2010 | Steamist 11 KW Steam Unit SM11IM
How many watts does a 59516-751 model require to run?
Answer
Simple Answer is just to know two formulas
Ohm's Law
V = IR
Power
P = IV
From those you can calculate voltage, amps, watts, ohms
V = Voltage (volts)
I = Current (amps or amperes)
R = Resistance (ohm's)
P = Power (watts)
Just solve for what you are missing.
Voltage times amps being drawn shows watts produced.
Watts divided by voltage shows amps being drawn or watts
divided by amperage shows voltage applied.
Sep 28, 2010 | Dometic Rooftop RV Air Conditioner
Is there a formula for standard deviation problems
Of course there are formulas for those calculations. You find them in books on statistics. Do not worry, the calculator has been programmed to use them. All you have to do is learn how to get the calculator to give you the results.
If you still want to see the formulas with your very eyes, I suggest you go to the local library, ask a math teacher, an accountant, or launch a Google search for them.
Hope it helps.
Aug 05, 2009 | Casio fx-300ES Calculator
Checking power consumption
you need a clamp on amp probe, a multimeter wont hack it. if you can get a amp probe, you first seperate the wires on your cord and then place the probe over one of the wires only this will give you your consumption. by the way, your approx usage of watts on a 26 inch lcd tv would be 160 watts. models do vary.
Mar 29, 2008 | Televison & Video
Kitchen Ranges Logo
410 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
