Question about Microsoft Xbox 360 Console
4 red lights on the Ring of Light
My Xbox 360 console is flashing 4 red lights on the Ring of Light could you help me solve the problem ? thanks Felix
  • 38 Answers
Hardware issue. Trade it in for $20 or "F" with Microsoft if you're under warranty then trade it in towards the purchase of a working ps3 or wii unit at gamestop.
Billy D
Posted on Apr 27, 2008
    Sergeant:
    Champion:
  • 427 Answers
The 4 flashing lights on the xbox 360 simply means that your A/V cable isnt securely plugged into either your console or your TV. Make sure these are really plugged in tight.
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Xbox360 power cycles by itself
do any lights flash etc, if so check below;
Two red indicator lights flash on the Ring of Light, or no lights flash on the Ring of Light. uparrow.gifBack to the top CAUSEThis may happen in the following situations: The auto-off setting is turned on,... loadTOCNode(1, 'cause'); This may happen in the following situations:
  • The auto-off setting is turned on, and the console has been inactive for six hours.
  • The console is too hot.
  • There is a problem with the power supply.
uparrow.gifBack to the top THINGS TO TRYTo identify and fix the problem, follow these steps:To begin troubleshooting thi... loadTOCNode(1, 'whattotry'); To identify and fix the problem, follow these steps:
  1. To begin troubleshooting this problem, check if the auto-off feature is turned on. To check if the auto-off feature is turned on, follow these steps:
    1. Start the Xbox 360 console without a disc in the disc tray.
    2. In the System section of the Xbox 360 Dashboard, select Console Settings.
    3. In the Console Settings area, select Auto-Off.
    4. Examine the option to see if it set for auto-off. If it is set for auto-off, change your selection.
  2. If the auto-off feature is not turned on and this is the first time the Xbox 360 console has turned off unexpectedly, let's do a simple test before we continue troubleshooting.
    To do this test, turn the Xbox 360 off for about 10 minutes. Then turn the console on and see if the problem occurs again. If the Xbox 360 console turns off unexpectedly again, make a note of how long the Xbox 360 console is on before the console turns off automatically.
  3. If the auto-off feature is turned off but the problem happens again, check the appearance of the Ring of Light to determine what to do next.
    • The two lights in the left quadrant of the Ring of Light flash red: The internal temperature of the Xbox 360 console may be too high. In this case, turn off the Xbox 360 console, and let it cool down. It may take several hours for the console to cool enough.
      Also, make sure that the ventilation openings on the console are not blocked. (For example, the ventilation openings may be blocked if you place the Xbox 360 console on a soft surface, like a bed or a sofa.) Also make sure that the console is not located in a poorly-ventilated place, such as an enclosed bookcase or stereo cabinet. For more information about what to do if the two red lights in the left quadrant on the Ring of Light flash red, click the following article number to view the article in the Microsoft Knowledge Base: 907533 (http://support.microsoft.com/kb/907533/ ) Two of the lights on the Ring of Light on the front of your Xbox 360 console flash red
    • No lights are flashing on the Ring of Light: In this case, we should check the lights on the Xbox 360 power supply for hints on how to fix the problem. A green light indicates that the power supply is correctly functioning.
      For more information about the power supply light, click the following article numbers to view the articles in the Microsoft Knowledge Base: 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red
Jul 31, 2009 | Microsoft Xbox 360 Console
I have one red light on my xbox 360 that is flashing
1 red light usually means a graphics chip problem. A reflow of the graphics processor usually solves this.
Give us a call / shout if you need any assistance.
FixMyConsole
Mar 11, 2009 | Microsoft Xbox Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
RED RING WHEN TURNED ON OFF FOR A WEEK
Nov 26, 2008 | Microsoft Xbox 360 Console
1 red light flashing
1 red light indicates that there is general hardware related problem with the console, 2 red lights indicate the overheating of the console, 3 red lights indicate the red ring of death and 4 red lights indicate that you need to tighten your AV console wire. If you get any of the problems and your system is under warranty, you can ship your console directly to Microsoft and you will get back your Xbox 360 red ring fixed by the manufacturer, however it might take more than a month and you will also have to bear the additional shipping charges. If your warranty period is over, you will have to pay additional amount of $140, if you choose to send the Xbox 360 to Microsoft for red ring fix. Further you will have to also bear the shipping amount and wait for at least a month for getting your console back. However, you can avoid this and can repair your console your own. There are many good guides available at Internet and you can go through any one of them and can fix Xbox 360 red ring problems your own.
Oct 22, 2008 | Microsoft Xbox 360 Console
Three red lights
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE: The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION: If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 08, 2008 | Video Game Consoles & Games
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
Sep 05, 2008 | Video Game Consoles & Games
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Nov 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
