Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
The coffee maker won't brew after 4 cups, even when it is filled to the 10-cup measure.
  • 4 more comments
  • jerry martin May 10, 2008
    My coffee maker is the same one and it also quits brewing after a couple of cups even though the water level is still up. I have to keep turning it back on in order to get a full pot of coffee. Jerry
  • Mrstazar May 13, 2008
    Same problem here. However, cleaning light starts flashing. We turn it off and then back on (several times) to get it to finish brewing a pot.
  • santucgal May 19, 2008
    I bought a Mr. Coffee 5 months ago... Now, it will brew about 4 cups quickly, then it will take atleast an hour to brew the other 6-8 cups.
  • Anonymous Jun 10, 2008
    My coffee maker has the same problem. I purchased it 4 months ago and it worked great for three of those months. Now it takes a half hour to brew
    2 - 4 cups. I never get a full pot and an huge amount of steam comes out of it. I will never purchase another Mr Coffee Maker again. Back to the cuisinart brand. Had one for four years-worth the investment.
  • rmad33 Jul 07, 2008
    I see I am not alone. I also have lots of steam and get about 1 cup of coffee when brewing 6 and the other 5 takes from 1/2 hour to 1 hour. 1 cup goes up in steam. I have also burt myself opening the top door to see what is going on.
  • Anonymous Mar 15, 2014
    how many teaspoons in 1/2 cup measurement
Wow at least you all are getting some coffee. Mine just totally quit brewing anything and there is no way to take it apart for a look see!
Posted on Jul 12, 2008
Same problem I have...took off bottom; two front 'screws' I had to drill out. Looked inside and threw it out!!!!!!! Not a Quality Item Clark.
Posted on May 28, 2008
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Bosch Tassimo TAS4513UC 1-Cup Coffee Maker manual
I looked up your problem and found the same one was answered previously on fixya. I have copied and pasted the previous answer here for you. Good luck and I hope you have a great day!
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Mar 25, 2014 | Bosch Tassimo TAS4513UC 1-Cup Coffee Maker
How much coffee do i use in a 55 cup coffee pot?
I US teaspoon per cup is recommended. 1 US cup = 48 US teaspoons, so for a 55 cup coffee maker you would use 1&1/4 US measuring cups of coffee. Add a little more (1/4 US cup) for stronger coffee brew.
Oct 28, 2011 | Coffee Makers & Espresso Machines
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
10-22 urn
If you have the L1350/155C, the manual states 1-1/4 cups coffee for 12 (5 oz) cups, for 30 cups use 3 cups coffee using standard measuring cups. Take the stem & filter out when the coffee has finished brewing so the bitter oils do not get into the coffee.
Dec 17, 2008 | Faberware 10-22 Cup Coffee Urn
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
More Steam Less Coffee
I had same problem after 4 months. very slow brew time, 10 cups of water poured in made about 6 cups of coffee. I used a packaged coffee pot cleaner powder and this fixed the problem (for now).
Dec 26, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
309 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Jim London
Jim London
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
