Question about Frigidaire Electric Dryer
Getting a dr code when i try to start dryer - Frigidaire Electric Dryer
2 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: code dr keeps popping up even if the door is shut and the dryer will not turn on
It means that the door switch is making a bad connection. You should look around near the door switch for loose parts or wires. If everything seems tight, perhaps replace the door switch
Posted on May 06, 2009
Dr comes up wont start
dr is door error
this generation of dryer has alot of control board failures(the relay for the heat burns the terminals for the wires)
you can inspect these relay connection visably by removing the front control panel
you might want to try setting the machine to the fluff/air dry setting and try starting the dryer, if it starts in air fluff you need to check the connections on that relay
this is not a factory taught test.
its just something a customer pointed out one time and i have tried on many after the fact, and for whatever reason these machines will still run in fluff mode when the board is gone.
Jan 04, 2015 | Washing Machines
I have a frigidaire gallery series front loading electric dryer model # 134509400c.press start and it beeps with a dr code.any idea what is causing this?
dr is door error
this generation of dryer has alot of control board failures(the relay for the heat burns the terminals for the wires you can inspect these relay connection visably by removing the front control panel you might want to try setting the machine to the fluff/air dry setting and try starting the dryer, if it starts in air fluff you need to check the connections on that relay this is not a factory taught test.its just something a customer pointed out one time and i have tried on many after the fact, and for whatever reason these machines will still run in fluff mode when the board is fried
Oct 22, 2011 | Frigidaire Electric Dryer
Frigidaire electric dryer GLEQ2152ES1. Dryer starts for a few minutes then turns off displaying a code of dr on the display screen. What is it and how do I fix it. Also need all the codes or where to get...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 24, 2010 | Frigidaire GLEQ2152ES Electric Dryer
I'm getting an error mssg "dr" displayed on my kenmore dryer model 84082. help!
"DR" is not a known error - please re-check and post the error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 11, 2010 | Kenmore 67082 Electric Dryer
The screen keeps flashing dr when i try to start it whats going on the DooR is closed not sure what else dr stands for
dr is door error
This generation of dryer has alot of control board failures(the relay for the heat burns the terminals for the wires) you can inspect these relay connection visably by removing the front control panel you might want to try setting the machine to the fluff/air dry setting and try starting the dryer, if it starts in air fluff you need to check the connections on that relay
Its just something a customer pointed out one time and i have tried on many after the fact, and for whatever reason these machines will still run in fluff mode when the board is fried
Feb 15, 2010 | Frigidaire Electric Dryer
Frigidaire electric dryer aeq7000es1 low heat only code e4a store
this is a door switch issue make sure the door switch is not broken
Sep 14, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Code dr keeps popping up even if the door is shut and the dryer will not turn on
May 06, 2009 | Frigidaire FGQ1442ES Gas Dryer
Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Jan 24, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire  Electric Dryer Logo
67 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
