Question about KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender
I have the blender and I'm not sure if I want to put it in the dishwasher. Is it dishwasher safe? If not, how do you appropriately clean it? It doesn't come apart easily. I just need to know how to clean the thing.
  • KitchenAid Master
  • 43,501 Answers
We put the top part of aur bleander through the dishwasher all the time... no problems....just take it off of the base and unscrew the chopper from the jar...throw the little parts in the utensil cup and you are good to go...
heatman101
Posted on Aug 07, 2010
I have a breville kinetic blender - not used for a while. Gives a nasty burning smell when used. Anything I can do?
Unless it is food stuck around the blender bottom , you have parts burning up inside. Its not safe to use. Check to make sure it is clean top an bottom if smell returns stop using. Could burn house down.
Jan 29, 2015 | Breville Blenders
Dishwasher doesn't fill and spin
Try asking this in the dishwasher department, asking it in the blender dept will invite unhelpful replies like this 'cos I know nuthin' about dishwashers.
Feb 08, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Diishwasher not cleaning
1. Make sure your spinners are not blocked when your dishes are loaded.
2. Make sure you are using a good enzymatic cleaner like "Electrasol." This type of cleaner eats the food off of dishes and it is very effective.
3. Make sure the water is HOT when your dishwasher is running (open it during the cycle and check the temperature.
4. Lastly, consult your manual or an online manual for troubleshooting tips for your model when it appears to stop cleaning.
Feb 27, 2013 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Top rack of dishwasher does not work
make sure that the tracks are clean on it to roll in and out of.
Dec 27, 2012 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
My blender base has become discoloured with a sort of green mouldy streaks, how do i clean
If you remove the blinder base where the blades are you can put it all in the dishwasher. To do this grab the handle on the pitcher then unscrew the plastic base from the glass. make sure that you look how it comes apart first. then put in the dishwasher to clean. Then reassemble the way you took apart.
Jan 11, 2011 | Oster 12-Speed Brushed Nickel Blender...
Putting glass and washer together
  1. Place glass container upside down on safe working area.
  2. Place rubber gasket/ring on top of opening first.
  3. Place stirring or mixing blade on top of rubber gasket/ring.
  4. Take the plastic retainer and screw it on over everything previously assemble.
  5. Hand tighten only enough that you can reverse the whole operation when comes cleaning and disassemble time.
Feb 13, 2010 | Elite 072-04-1198 Blender
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Found black powder under the base unit
I have a MR5000FS multiquick and want to pull out the blade and clean it. Can this be done safely and how do I pull it apart to clean.
May 07, 2009 | Blenders
KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender Logo
240 people viewed this question
Top KitchenAid Blenders Experts
eyecam
Lawrence Oravetz
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
