Question about Bissell Upright Vacuum - The Pet Hair Eraser 1 ea Vacuum
No suction and is not clogged - Bissell Upright Vacuum - The Pet Hair Eraser 1 ea Vacuum
  • 144 Answers
The motor is bad, when these type of electrical motors go bad the power of the vaccum dies but the motor can still sound like it is running. One way to tell the motor is shot, is the motor while running will be a might louder than it was originally.
Posted on Aug 07, 2010
No suction from dyson dc24
Clean or replace filters if needed. Check for suction at wand, if not good could be a clog somewhere or clogged filters, or a leak in the suction somewhere. If good at hose but not at floor it could be a clog or malfunction in changeover valve area. Make sure brush roll is spinning good and brush roll not worn out or frayed.
Mar 14, 2017 | Dyson Vacuums
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 | Vacuums
Lg 300B no suction through hose
If you have a loss of suction overall, that generally means one of two things, either you have a clog somewhere near the motor or the motor is fried and will never turn fast enough to make proper vac.
Nov 09, 2013 | LG LUV300B Bagless Upright Vacuum
No Suction
i about to say that's always a clog of some sort that causes that
Jan 31, 2013 | Miele S7210 Bagged Upright Vacuum
Why would the vacuum have no suction?
if the motor is running it could be a belt a clog or a hole somewhere else in the hose
Feb 16, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
How do I switch the vacuum from floor to accessory suction
It automatically switches over when you disconnect the hose from the power nozzle. No suction it getting to the power nozzle, so the suction is only through the attachments. If there is no suction through the hose, check for clogs in the hose and in the tank where the hose plugs in. Also, check the screen at the bottom of the tank. If there is a clog in the hose or tank, then there also will be no suction to the power nozzle.
Remove all clogs and you should get suction.
Dec 19, 2010 | Hoover U5721-900 WindTunnel Upright Vacuum
There is a suction problem - the suction power is very low. The filter has been washed, dried and replaced but the problem is still there What is the problem? Thanks.
Something between the bag and the suction opening is clogging the vacuum. Start at the bag. Remove the bag and check for a clog. Remove the hose from the back and check for clog. Release the handle and turn the machine over to expose the sweeper bush. Check for clog. If you haven't found the clog at this point, remove the 4 screws on the brush cover. Then remove the brush and check the hose going into the machine. If the filters are clean the machine should have plenty of suction.
Nov 27, 2010 | Hoover Vacuums
The suction motor is not working, just the power head
Please be more detailed? What brand? one or two motors?
If power is working with no suction. could be a clog or bad filter if -
and if it is a bagless unit - there is usually more than one filter - if filter is clogged you will use alot of suction!
9 times out of 10 it is usually a filter or clogged.
Nov 04, 2009 | Vacuums
Reverse Suction
You have a clog either at the inlet by the brush roll or in the hose. Pull the hose and check for suction at the end of the hose, If it is ok there, then you have a clog from where the hose hooked into and the inlet at the bottom. If at the end of the hose there is no suction, take the hose off and see if you see a clog in it. If no clog there, then check all filters, if they get clogged, then air can't flow thru them and no suction.
Dec 31, 2007 | Hoover U5507900 Elite Rewind Bagless...
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Bissell Upright Vacuum - The Pet Hair Eraser 1 ea Vacuum Logo
664 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
