Question about GE WSXH208A Front Load Washer
Water leaking through soap dispenser drawer - GE WSXH208A Front Load Washer
  • beckertracy Sep 11, 2008
    I have a brand new Frigidaire washer and I have not used the bleach or fabric softener dispenser yet. I've done three loads of laundry and each time I open the dispenser to add the liquid soap, the bleach and fabric softener areas are filled with plain water. What's the deal with this? Is it supposed to be like that? I have a floor model and the instruction manual is missing.
OLDFIXER was exactly right ! I had water gushing out of my LIQUID detergent tray. I removed the tray by pushing down on the flexible tab at the back of the tray and when I had the tray out I discovered A LARGE AMOUNT OF DAMP powder detergent caked up on the inside. I removed it all and sprayed some hot water inside AND ITS COMPLETELY FIXED !!! GOD BLESS OLD FIXER.
Posted on Feb 02, 2009
  • bscott359 Feb 02, 2009
    The moral of this story is DO NOT USE POWDER DETERGENT in the LIQUID tray, it will cause grief !
    Genius:
  • 1,028 Answers
Assume this is a front load remove drawer ck for blockage into tub from inside at inlet and underneath drawer if you use powder detergent old detergent and clump and block line into tub
Posted on Apr 27, 2008
  • 3 Answers
Look inbetween the drum and rubber seal at 10: oclock use a flasflite, I found a thong. george
Posted on May 04, 2010
  • Susan Jenkins Jun 04, 2013
    Oh my gosh! This worked. This was the exact problem. My son said he had a sock missing and sure enough, that was the missing sock. It was so jammed in there, I didn't need a flash light. This solved 2 problems: the leak and the noise the machine had started making prior to this. Thank-you so , so much! Moral of the problem; don't let the boys jam pack the washing machine.
If it is not a clump of soap blocking the in let. It could be a vent problem with the soap drawer removed look to the right side there is a vent tube that lets air out as water flows in. Over time material builds up and blocks it, It is corragated so it can flex when the drum is in a spin cycle. You take the top off of the washer it goes from the top of the wash drum container to the soap drawer holder. The ends are like gromets. clean it out that should help,
My washer was a Frigidair Gallery front loader,about 10 years old. California Itilian Ciao
Posted on Aug 27, 2008
If you have cleaned the drawer thoroughly with a toothbrush, It could be a blockage in the internal filter. Details on www.howtomendit.com/answers.php?id=27499
Posted on Aug 02, 2008
  • Robert Whitlock
    Robert Whitlock Dec 14, 2013
    For what it's worth, I just finished replacing the seal and bearing in the drum and had the same problem: sprinkles of water were streaming out the front of the detergent dispenser. The solution was in making sure that the three hose inserts which are situated in the back of the dispenser inside the three hoses, are fully inserted into the dispenser. They direct the water streams to their proper destinations. Mine were not fully inserted, causing the water to stream and leak in small amounts out the front of the detergent dispenser. Hope this helps!
  • 1294 Answers
SOURCE: LEAKING DISPENSER DRAWER
Refer to your manual regarding the dispenser tray. You could try using a tooth brush to clean out dry detergent, which could be blocking the flow of water. You can take out tray to clean, ref manual.
Posted on Jan 13, 2008
dazmaraz
  • 67 Answers
SOURCE: Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Posted on Mar 07, 2008
SOURCE: Soap dispenser
I got my fixed last night. It was the "lid" for the softener despenser that was making the drawer stick. To remove it you need to take the top off of the washer. There is are two plastic "holders" on the back of the machine that hold the top onto the machine. Each of these "holders" have two screws, remove them, then remove the holder. You can then, with some effort, slide the top of the washer towards the back the then lift it off. You will then be able to see plastic tub that contains the drawer for the despensers. You can't remove this tub, but on the side facing the inside of the washer are a couple of tabs holding the top of the plastic down. You can gently release these tabs and pull up on the top slightly. This gave me enough "play" to then open the drawer. The problem, I believe, is that over time, that tub moves and makes it impossible for the drawer to open. With trial and error, I found that with removing the "lid" for the softener despenser, and completely closing the lid of the plastic tub, that that solved the problem.
Posted on Apr 05, 2008
  • 4 Answers
SOURCE: he2 front loading washing machine leak at the soap dispenser regi
well yea im aprentasing for plumbing. i have rain into these problems before yes it is clogged. its a pain but its fixable..
Posted on Jan 13, 2009
  • 100 Answers
SOURCE: water leak
there is a blockge so the water comes out the way it went in when spinning,
check the filter at the bottom of your drum.
rear of machine, take panel off and look in to see black rubber attached to drum about 3" diameter. filter in there.it's a kind of basket with a ball float in it.
put back the way it came off as only fits 1 way.
Posted on Feb 11, 2009
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
WATER LEAKING from Soap / Softener dispenser
Close the water faucet slightly to reduce the speed of the flow into the the soap drawer...The machine will fill a little slower, so what??!
Oct 25, 2017 | Maytag MAH8700A Front Load Washer
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water leaking out of soap dispenser?
Mar 17, 2013 | Washing Machines
Simpson front loader washer leaking from front soap drawer on the spin and rinse cycle when filling
Mar 10, 2013 | Washing Machines
We have a Kenmore frontloader pooring water from soap dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 16, 2009 | Kenmore 44102 Front Load Washer
Indesit WIE147 leaking from soap dispenser
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Jun 17, 2009 | Washing Machines
Soap Dispenser won't empty
Feb 25, 2009 | Kenmore Elite 45986 Front Load Washer
Leaks water from soap drawer
could be a loose hose to the drum from the dispenser or a tape still in the dispenser not taken off.
please check it.
tnx 4 using fixya,
drcool
Oct 27, 2008 | Frigidaire ATF6000ES Front Load Washer
GE WSXH208A Front Load Washer Logo
2,174 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
