Question about Samsung RB2155 Bottom Freezer Refrigerator
I need the part # for Samsung RB 215 bottom freezer defrost sensor
  • Samsung Master
  • 3,051 Answers
Hello there:
This part is thru repair clinic.com they may be able to help you get it localy also below this is a picture of it
Part 1515199 // Item #
1515199
Price
$12.45 In Stock?
No (B) Qty
Posted on Aug 07, 2010
My bottom freezer samsung freezes over coils and will not maintain freezer temp consistently. Upper works fine. Replaced control board, 3 sensors in freezer.
would check ur defrost terminator and defrost timer. should not have replaced control board so quickly. may even just have abad thermistor/ but I suspect ur defrost terminator is the problem and its rather inexpensive and easy to replace
Mar 09, 2015 | Samsung Refrigerators
Water in the vegetable drawer samsung refridgerator
Thank you I have a rb 215 and having the same problems so yes this does help a lot... thank you t
Jan 22, 2012 | Samsung RF217ABWP (20 cu ft) Bottom...
Model rb 217 having water pool up under the drawer in the top refridgerator and in it also
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 28, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Freezer is not defrosting. it's a RF265ABPN model
Your defrost termination sensor has failed & needs to be replaced.(very very common problem with todays fridge's specially samsung)
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
For some reason fridge spot working did not go below 55 F. Freezer still working fine. What could be a problem ?
You have a defrost issue..if you have a ice build up on the back wall of the freezer..
maybe defective
1. heat coil
2. defrost timer
3. defrost sensor
Dec 19, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
There is an ice build-up underneath the humidity control drawers and the food in the drawers is freezing. It is a model RB 215 LABB. We have adjusted the temperatures of both the freezer and the fridge,...
The problem isn't the humidity control or temperature control. When the refrigerator automatically defrosts it goes through a cycle of heating and melting the ice build-up then drains this water to a tray at the bottom of the refrigerator (underneath). The drain tube that lets this water flow down to the bottom tray freezes so the ice begins to build inside the refrigerator section.
The solution to this is to defrost the tube so water can flow again. There are heating coils in the freezer section behind the plastic in the back that you must remove and defrost.
This is an inherent problem with a lot of refrigerator/freezers. You should probably have your refrigerator serviced and to check the heating capability of the coils to keep this tube from freezing. Otherwise put this on your monthly schedule of manually defrosting.
Sep 23, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
A while back I purchased a Samsung model RB 215 Refirgerator /Freezer. Works well except that the ice in the bin seems to clump or stick together after it has been sitting for a while. The freezer door is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Defrost is running too long and warming the freezer up too much...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Samsung RB215LASH
RB 215 ice maker not making ice very fast? Was great for awhile now using more ice it just can not keep up. No manual
they can only freezer water just so fast. they will not keep up with heavy demand for ice it will only harvest ice about once an hour
Apr 10, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
My samsung rb 1855sl is having an issue where freezer is not working.
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
SAMSUNG RS21DCNS
samsung fridge freezer problem
samsung fridge freezer diy help
Apr 27, 2009 | Samsung Refrigerators
Samsung RB2155 Bottom Freezer Refrigerator Logo
230 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
