Question about Grilling
Temp My Holland Grill lights and gets hot except the plate where you place the meat. Takes forever to cook anything. I have taken it apart, cleaned the screen and everything but still does not get hot.
  • Kyle33 Apr 28, 2008
    Super.............thanx. I will try this.
  • 36 Answers
Not sure on your climate.
But a Holland grill cooks cooler in the coller months and Hotter in the hotter months. This type of grill doesn't reach a very high setting approx: 400 degrees. It might reach higher temperatures in the hotter weather 450-475 degrees.
Also, it has to shut down the same way every time you use your grill.
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Hollands are known for the slow cooking process and a Healthy way of cooking!
Posted on Apr 28, 2008
Leg of pork 1.780 kilos how log do I cook it for
There's no magic number. It depends on what sort of result you want, the heat of your grill, the temperature of your meat, even your altitude. I would do a reverse sear, which means building a two-zone fire (or lighting only half of your gas burners), then using a meat thermometer probe and cooking it on the cool side of the grill until the middle of the roast reaches about 10 degrees (F) below where you want it. Then switch to the hot side of the grill and finish the outside (avoid lengthy flare ups). Let it rest, lightly tented with foil, for at least 20 minutes to give the juices time to redistribute and residual cooking to take place. Personally, I prefer my pork around 140 degrees (F), juicy and slightly pink.
Jun 11, 2017 | Grilling
At what temperature do you cook bone in and boneless prime rib and how long per pound
13 - 15 minutes per pound @ 300 - 325 degrees F, pull when meat is 125 F - 130 F (internal temp.) for rare to medium-rare. Err on the low side. Allow to rest; the meat will continue to cook while resting. For example, if you cook it to be medium-rare (130ish F), then pull it out of the oven, and let it rest, it will end up being medium to medium-well (140 - 145 F) once cut. So be aware.
Bone-in, bone-out it doesn't really matter, because the bone is not in the center of the meat. It's best to let the prime warm at room temp for a period of time, before cooking. An hour or so from the refrigerator (not frozen).
Some people like to place the prime into a hot (425 F) oven or grill/smoker for 10 -15 minutes, then turn down to roasting temp. This is done to sear the outside, which will give it a crispy/seared outside. This doesn't "lock in" flavor, juices or anything else, it is more of a visual and texture thing. If you do this, the cooking time will be reduced, because the oven/grill will have to come down in temp over a period of time while the meat is cooking. I don't recommend doing this with prime rib. It ends up being overcooked and tough, due to the fast then slow roasting of the meat.
What you want to keep in mind is: roast the meat low and slow. Check the internal temp, with a meat thermometer, early to avoid overcooking. Don't forget the internal temp of the meat will rise after taking it out of the oven. Let it rest for 10 - 15 minutes before slicing the meat.
Mar 26, 2016 | Grilling
Meat weighs 2llb 20oz how long should i cook it for we like it medium rare ?
The best thing you can do is to buy a BBQ digital thermometer that you place in the meat during cooking. They have a heavy duty wire with a temperature probe on the end. Sear the meat directly over the coals (or hot side of a gas grill), then move the meat to a cool side and then insert the temperature probe and close the grill lid. Cook until it reaches desired temp, for me 125 degrees is perfect. The total cooking time is hard to judge as it depends on your grill cooking temp, but the digital thermometer takes all of the guesswork out of the equation as to when the meat is done.
Apr 06, 2015 | Grilling
How do I cook ribeye steak
on the grill! get yourself nice dryrub at your local food store and throw it the grill. i dont let my temp get higher then 300 i cook them low and slow!
Dec 08, 2014 | Grilling
Grill troubleshooting
It's not getting hot enough.Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 31, 2014 | Holland Grill Classic II (NG)
Natural gas to LP
It sounds like a pressure problem. Try checking to see if a valve or regulator may be clogged. Some times a valve or regulator or event he line it self may have spider webs or spider nest inside the line and that will block the flow.
Mar 16, 2014 | Holland Grill Grilling
George forman grill taking way to long to cook, are there any recalls?
It depends on several things. How thick is the cut of meat? Thicker cuts take longer than thinner. Is the meat cold or room temp? Are you putting too much meat in the grill at once? All of these go into effect when you cook anything on any cooking appliance. The directions are a general guide
Oct 19, 2012 | George Foreman GRP99 Indoor Grill
How can i sear with my weber gas grill?
When you sear meat all you are doing is cooking the outside at high temperature so a caramelized crust forms. To do this on a gas grill turn all of your burners on high, close the top and let the grill get very hot, I usually shoot for around 400 to 450 degrees. When you put the meat on the grill do it fast, directly over the heat source and close the top to keep the heat up. You'll have to experiment but usually about a minute and a half to two minutes per side is all it takes. You want the meat to be thoroughly browned on the outside. Now turn the heat down or off on one side if your grill is set up for that, flip the meat and cook it slowly on the side of the grill that's turned off or over indirect heat to your desired done-ness. This will depend totally on the thickness of your meat, again experiment. Another important step is to let the meat stand for five to ten minutes after taking it off the grill. This keeps all the juices from running out of the meat the first time you cut into it and ending up on your plate.
Jan 17, 2011 | Garden
It takes a very long time to cook anything on the weber grill. it never gets really hot. The grill is about six years old. What do I do to correct this problem?
check for rust/debris on the nozzles (these are small screws with single hole in them inside of the burner, clean the burner, dissassembly and clean the valves on the grill NOT ON THE BOTTLE!
this should solve the problem, alternatively, if burner was not used for long time, regulator maybe stuck in this position and will need replacement.
Jul 15, 2010 | Weber Genesis Silver A Grill
Is meat placed in main grill or in attached box
The "offset" box is your firebox. This is where you will put your charcoal. The meat goes in the larger chamber on the grill. This type of cooking is known as indirect cooking where the heat source is not directly under the meat. A grill cooks direct with the heat source coming from charcoal or gas burners located directly under the cook grills. Smoker can really deliver some great tasting food. Be patient and learn the ins and outs of cooking with a smoker. The most important thing is to cook low and slow. try to keep your temps in the cook chamber around 225. I hope this helps.
Jun 29, 2010 | Char-Broil Sierra Offset Smoker
Grilling Logo
341 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
