Question about Samsung WF203ANW Front Load Washer
Why does my samsung front load washer make an air horn (on low) noise when it fills?
2 Suggested Answers
  • 12962 Answers
SOURCE: my Samsung front load washer will continue to fill with water
Fill valve is not shutting off. Check it out.
Posted on Aug 06, 2017
What does flashing nf sign means on the samsung front loader
It means "No Fill". NOt enough water is making it into the washer. Make sure your water connections are good and hoses are not kinked.
Jul 24, 2016 | Samsung Energy Star 3.9 Cu. Ft. Front Load...
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
Water will not stop running into washer
one of 2 things can do this,first unplug the unit from the power if it continues to fill then its the water fill valve thats bad,second if it stops filling when unplugged from the power outlet then its probably a plugged pressure switch line from the tub so the water pressure cannot switch the pressure switch diaphram from fill to wash cycle,open the cover and remove the pressure hose from the tub and blow into it and you will hear a click in the pressure switch its connected to,then replace hose onto tub side and blow into the other end of this same hose and make sure theres air movement in the tub as you will see and hear bubbling noise
Jun 03, 2012 | Samsung WF448AAP Front Load Washer
Jumps around really bad even on the "low spin" cycle Samsung front loading brand new
First check that the "shipping" bolts have been removed...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 18, 2011 | Washing Machines
No spin... makes a clacking clattery noise
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Samsung WF337AA Front Load Washer
WF218ANB noise like a bag of rocks being shaken.
This is a direct result of Samsung's Vibration Reduction Technology(VRT). There is a hoop at the front and the back of the drum holding 18 ball berrings in each hoop (36 in total). These balls use centrifugal force and automatically move to the opposite side of where the load is unbalanced and balances it out. It is only in the washing machines, not dryers.
Dec 16, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Aug 30, 2009 | Samsung WF203ANW Front Load Washer
Hi... My washing machine... samsung front load. will stop in the middle of the wash and beep and flashes nF. We had bought the floor model and when we got it home realized we didnt have a manual... I can...
nf is the failure code for [no fill].check your water valve screens for a mineral buildup/blockage.they are where the fill hoses attach to your washer.make sure water is present at washer[run the water from each hose into a bucket].i live in ohio its 0 degrees out side now.i did't know it but there was an air leak near my dishwasher drain hose in the house and water froze in it blocking the drain.i hope this info helps you fix this washer, God bless ,tom
Jan 16, 2009 | Samsung WF337AA Front Load Washer
GE Front Loader Washer
Door latch is sending false signal to control board,first replace the door latch.
May 26, 2008 | GE WSXH208A Front Load Washer
Samsung WF203ANW Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
