Question about Poulan Garden
The mower blade drive belt on my Poulan Pro 16.5 HP, 42", model #310777 broke. The only manual I could find was for a model 60614 which was of very little value to me. The parts store sold me a Gates Hi-Power II A85 (1/2" X 87" belt. We installed the belt using the diagram in the manual as a guideline but now the blades DO NOT disengage when the attachment clutch lever is disengaged. The mandrel pulley on the left blade has small flat piece of metal that appears to have a 'brake pad' on it. It was badly bent (probably when the belt broke) and we straightened as good as we could. Please advise if that needs to be replaced and, if so, what is it called? Thanks for any help you can give us. bl
  • 144 Answers
The only thing I can suggest to get you in the ballpark of what is wrong or if you can replace what you need replaced is to look on the Poulan website and get a customer service phone number. Chances are they will know exactly what you need. Hardware stores are too broad and it sounds like you need specilized attention.
Posted on Aug 07, 2010
  • 1 more comment
  • bjlattin Aug 07, 2010
    Thanks for your input. Must tell you I have spent hours scouring Poulan's website and have only come away very confused. Thanks, again. bl
  • goldenglove1
    goldenglove1 Aug 07, 2010
    I am working on getting you a service manual please be patient, ok, I will figure it out.
    What a blessing you are! And the manual, too! I thought I had found the right manual and the only version that would print was in french--not anywhere close to my native tongue. :))
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
2008 poulan pro 18.5 hp 42" cut 6 spd smokes bad when i put it in gear
check drive belt make sure its not rubbing against melt guied tabes
Aug 18, 2013 | Poulan Pro Lawn Tractor 2006 and Newer...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a Poulan pro, 42 in, 18hp, How do i adjust or replace the drive belt?
steps:
1. elevate tractor.
2. lower blades all the way down.
3. remove battery and battery slot
4. place belt through battery slot around first pulley and then feed it through the middle two.
finally loosen the front pulley and slide new belt over the front of the last (front) pulley,
note: be sure to feed belt through all medal guides on the bottom of the tracoitr or else the belt will continue to fall off.
May 02, 2011 | Poulan Pro 46Inch 22 HP Yard Tractor with...
I have a Poulan PRO Model PB20H42YT. It was working great when slowly I lost forwar/reverse motion; freewheel control is engaged properly.
sounds like the drive belt is off or broken, on the lawn tractors if you remove the plate, where you shift gears, you will see the belt.
Oct 29, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How do you remove the rear wheel to fix flat tire?
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
May 21, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I cant get the drive mower belt on my poulan pro lawn tractor!
The belt you should have bought is part # 140294 and yes, it is longer.
Jul 27, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
POULAN 42" 19HP RIDING LAWN MOWER
42 inch poulan belt broke on mower deck diagram to replace new belt
Jun 14, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
334 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
