Question about Timex Marathon Night Light Watch
I just replaced the watch battery on my Timex Marathon with the correct battery (CR1620). There was a sticker covering the battery that says "short ac pad and battery to reset". I'm not sure how to do this and my watch is not working. Thanks for your help!!!
escapement
  • 2334 Answers
SOURCE: timex watch cover replacment
Align the caseback exactly as it was before you opened it. Make sure thet the groove for stem is in correct position. Lay the napkin on the flat table surface, put the watch on it (dial down) and using both hands and your body weight push the caseback down back in place. Remember: the side of the caseback wich first came out must be last pushed in.
Do not use very soft napkin (towel) as this can brake the glass under the pressure.
If all above described DO NOT work, then there is not enough power in your hands or not enough weight in your body and you will need watchmakers help (he/she will be using special watch press to close the watch).
P.S. Do not get upset if you can not close it; I'm very expierenced watchmaker and very often came across the watches wich I was not able to close without the watch press (even my arms are quite strong and the weight is 95kg).
Do not forget to rate, please.
Posted on Mar 07, 2009
SOURCE: Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...6e1fe0e.jpg
Posted on Jul 06, 2008
slp11508
  • 43 Answers
SOURCE: Changing tome for a cr1620
Copy and paste this link into your browser. It will take you to a page where you can download the necessary manual for your watch model.
Posted on Jan 05, 2009
  • 65 Answers
SOURCE: after replacing a battery in a timex ironman with
You will find them on the module itself.
So after replacing the battery look on the PCB (printed circuit board) for the letters"AC" and "VSS". Adjacent to these markings there should be little contact points (probably gold or silver looking in colour)
Use a paper clip or similar and bridge (short) these two points simultaneously. Please rate my solution.
Posted on Jul 27, 2009
SOURCE: how can I reset the
You know where AC pads are right? If you don't know, look at the sticker. there is an arrow on the sticker. An arrow points out 11'oclock.
After insert the bettery, you just touch the golden pads with metal screw. that is how to short AC pads.
Posted on Jan 15, 2010
How do i find a manual for my timex marathon wr50m digital white watch t5k805?
I'm guessing that your watch is described here
http://www.walmart.com/ip/Marathon-by-Timex-Digital-Mid-Size-Black-and-Silver-Tone-Watch/38229915
(at the bottom it says model = T5K805, name is marathon)
[also on Amazon - http://www.amazon.com/Timex-Womens-Marathon-Sports-Digital/dp/B00R4XTAJ8/ref=sr_1_3?s=apparel&ie=UTF8&qid=1421449802&sr=1-3&keywords=t5k805&pebp=1421449828860&peasin=B00R4XTAJ8)
Then.look down the list for marathon in this http://www.timex.co.uk/info/product-manuals-downloads
and choose the one of the three you want. The non GPS one is very short and not really what I'd call a manual. I hope this is what you need. Otherwise contact Timex
16.January.2015
Jan 16, 2015 | Timex Watches
Where can i got a replacement band for my timex marathon?
Yonkers department store has a section for watch repair.
Jul 04, 2011 | Timex Marathon Fullsize Watch
I just replaced the battery on my Timex WR100 watch, but can't seem to reset it correctly. There is a sticker on the original battery "AFTER BATTERY INSERTION SHORT AC PAD AND BATTERY (+) TO...
It sounds like you're not far off. Peel the sticker back a little, and see if there is a small contact point (usually yellow metal) - this should be marked 'AC'. Short this to the + for 3 seconds, then repeat for good measure. If that doesn't sort it, try taking the battery out, wait about 30 seconds then put it back in and reset if necessary. If there's still no display, obtain a known working battery and try again.
If you still have no display, it's time to give up and admit it's dead.... unless you've been using a plastic coated paper clip.
Good luck.
May 19, 2017 | Timex Watches
What type of battery is needed for the Timex Marathon T5G811 Stopwatch?
The obvious answer is to look for the numbers on the battery that is in it. If it doesn't have a battery then that gets a little tougher and you could probably contact Timex through the internet. Good Luck!
Oct 30, 2009 | Timex T5G811 Marathon Stopwatch
How can I reset the "short AC pad and battery (+) on timex expedition
Oct 13, 2009 | Timex Digital Expedition watch
NEW BATTERY. NO CHIME OR BEEPS ON THE HOUR,TIMMER, AND ALARM WHAT CAN I DO TO FIX THIS PROBLEM
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry2.gif & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: info@goamfix.com
web: www.goamfix.com
Sep 14, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Timex Marathon Night Light Watch Logo
283 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
