If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
We disconnected all the hoses and ran a wire through and got nothing, so it appeared they were clear, however, no water would run through the hoses. We could blow air through them, but not water. Turned out there was a clump of lint/fabric strings blocking the hose. The wire slid right past it and came back past it without pulling any debris out. It was kind of a puzzle until I took a flashlight and was able to see down into the hose. Once we were able to clear it out, we were functioning again. Never thought it would allow air through but not water? Wierdest thing. I had already reviewed the sites you suggested. Thanks anyway.
Problems
with a washing machine not spinning or not draining are often inter
related..
Washing
Machine
Front
Load Washing
machine not draining and or not spinning
heatman101
