Question about Lexmark X5070 ALL-IN-ONE InkJet Printer
How do i reset me lexmark 5070 printer after i used a refill for ink
    Scholar:
  • 50 Answers
  • Launch "Printer Solution Center." You should have installed this program when you installed your Lexmark printer. Click on the Start button and selecting "All Programs." The menu command or shortcut for this program is located under the "Lexmark" folder. Click on it. If you do not see this program for some reason, insert the installation CD (provided in the printer box) into the CD/DVD-ROM drive. Follow the on-screen prompts to install the program.
    Step 2
    Click on the tab that says "Maintenance" on the top menu.
    Step 3
    Click on the button titled "Install a new printer cartridge."
    Step 4
    Hit "Next" to launch "Print the Alignment page" window.
    Step 5
    Hit the "Print" button. This will reset your ink cartridges. You should be able to see a correct reading of the ink levels on your Lexmark printer.
    Step 6
    Repeat this process until you successfully reset the ink cartridges. Sometimes, it may require multiple attempts to complete this task
    if you want to know how to reset the complete thing then...
    Resetting a Lexmark printer
    You will firstly need to switch off your printer. Then simultaneously press the RETURN and READY keys while switching the printer on. This will take you to the Diagnostics Mode. The display unit will show the message 'Performing self test'. Choose 'Maintenance count'. Reset the count to make it zero. Then select the RETURN key and go back Diagnostics Mode. Then you can reset the printer to go back to the normal mode.
    hope this works for you...
  • Posted on Aug 07, 2010
    2 Suggested Answers
    JackHeath
    • 1049 Answers
    SOURCE: lexmark 5070 printer
    Hard to tell...There are other issues which could contribute related to the printer itself, etc.
    But I will say in my experience often refill kits for ink cartridges don't work if you allow them the cartridge to run bone dry. Maybe the internal components become hard and won't re saturate with new ink, not sure. If new cartridges work; and the refills don't I'd say there may be a problem with them.
    Posted on Jul 23, 2008
    Lexmark S405 refill cartridge reset
    When a Lexmark cartridge is refilled, it will not be able to report its ink level.
    Please note that all Lexmark printers work best when original supplies or genuine Lexmark cartridges are used. We do not recommend the use of third party, refilled or remanufactured cartridges - you might not get the print quality you expect from ink that is specially formulated by Lexmark.
    Nov 27, 2011 | Lexmark Interpret S405 Wireless All-in-One...
    I need to reset my ink levels so my X3550 refilled cartridges
    If you have refilled the cartridges you got along with the printer, you can't reset them. 23 and 24 are not meant to be refilled. They are what Lexmark call "return program cartridges"- they can't be refilled, you can send them back to Lexmark ( that's why they are called "return cartridges"). You need to buy either 23A and 24A or 34 and 35, those cartridges are refillable.
    Here is a link to Lexmark, with a list of cartridge compatibility for your printer:
    http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=x3550
    If you find my answer helpful, please vote. Thank you!
    Oct 22, 2009 | Lexmark X3550 All-In-One Printer
    Does not work lexmark x 2650. is there any way to reset old refilled cartridges no.14 and no.15
    “Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
    May 21, 2009 | Lexmark X2500 All-In-One Printer
    Refill inkcartridge 17 of lexmark x2250 don't work
    Apr 28, 2009 | Lexmark X2500 All-In-One Printer
    Refilled the black cartridge and now it doesnt recongize it
    Apr 13, 2009 | Lexmark X5650 All-in-One InkJet Printer
    Is it possible to refill ink cartridge on Lexmark x6690 printer?
    Take out all cartridges, switch printer off and then on again and let printer see that there are no cartridges. Do this 5 times, it resets the cartridges. Then install refilled cartridges
    Apr 08, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
    Using a refilled ink cartridge on a Lexmark x4850
    Yes, most Lexmark cartridges as well as many other manufactures use something called 'Smart' Chips in the bottom of the ink cartridge. Usually unplugging your (about 10 seconds) printer resets the memory in the printer. Hope this helps!
    Mar 20, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
    Lexmark 5070 printer
    Jul 22, 2008 | Lexmark X4270 All-In-One InkJet Printer
    X5470 Lexmark printer
    Lexmark and Dell use a sensor in the cartridge to sense a low ink level. Once the sensor has been activated, you cannot reset it. The printer should work fine except for the fact that you'll have to override the "low ink" message on your computer.
    Manufacurers don't make money on printer hardware. All the money is made from ink replacement, so they make it as difficult as possible to use anything other than the stuff you buy from them. Some (HP) put in chips for an "expiration" of the ink/toner. Go beyond the expiration date, the thing won't work.
    May 13, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
    Lexmark X5070 ALL-IN-ONE InkJet Printer Logo
    491 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
