Question about Dell Dimension 8400 PC Desktop
Sleep mode is turning off the monitor how do i disable itjdelaile@
    Scholar:
  • 50 Answers
Well in most system the sleep mode can be found in the power options...
generally you can go to your battery icon in the bottom right and right click on it and go to power options if its a desktop computer or laptop just goto Control Panel and then to power options, in the power options it will have Change plan setting.. depending on the windows you are running it may take you directly to the changing of this options, but once you get into the plan setting you will see all you need to and change the monitor from sleeping to never...
hope this issue is resolved...
Posted on Aug 07, 2010
    Genius:
  • 1,354 Answers
Hi
go to following link you will have your solution
http://www.howtogeek.com/howto/windows-vista/disable-power-management-on-windows-vista/
4 Suggested Answers
SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
Posted on Mar 25, 2008
  • 285 Answers
SOURCE: Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
Posted on May 24, 2009
jadiazq
  • 2878 Answers
SOURCE: My monitor seems to be stuck in sleep mode
This happens when there is no communication with video card. Check cables, re-seat video card, make sure monitor is set to correct mode. VGA (15pin blue), DVI (white), or HDMI.
Posted on Aug 28, 2012
My screen symtoms are a little different on my L1975NW.
I am guessing the LED power indicator blinks green then becomes steady when the screen "turns on" (shows video). The problem is most likely a failing backlight power supply. That's why there is a 30 minute delay. Try to disable sleep mode and see whether that helps.
Aug 30, 2012 | Westinghouse L1975NW Monitor
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
Feb 01, 2011 | Acer AL1916W 19" LCD Monitor
My hp L1506 going to sleep again and again
Follow this instructions to disable sleep mode
In windows XP
1)Right-click the desktop, and select "Properties."
2)Click the "Screen Saver" tab, and click the "Power"
button at the bottom.
3)Change the option next to "System Standby" to
"Never" for either "Plugged in" or "Running on
batteries" or both if that is what you want. Click
"Apply," "Okay" and "Okay" once again to close the Display Properties dialog.
In windows vista
1)Click the "Start" menu, and then click the Control Panel.
2)Click "System and Maintenance," and then select "Power Options."
3)Select "High Performance" to disable the overall sleep mode. The monitor will still go into sleep mode unless you click "Change Plan Settings" and disable all sleep options.
In windows 7
1)Click "Start," and then select "Control Panel."
2)Double-click "Power Options."
3)Select "High Performance" under "Additional Plans," and then click "Change Plan Settings." Change all of the options to say "Never."
Dec 16, 2010 | HP L1506 15" LCD Monitor
Monitor going to sleep
juanmgerman0, Connect SDM-X82 to known-good pc that has all sleep mode, power-save mode disabled. (turned-off) If unit still goes to black screen mode, then look at the "date of Manufacture" on rear of unit and let me know if you see "2002 -2004" as the year produced. Retrevo lists unit as "time to retire". Power supply may be going into shut-down mode having detected a problem with itself or the CCFL inverter circuit. 12fixlouie
Aug 19, 2010 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
WF1907 Monitor is in sleep mode - how can i get it to stay on?
If understand your issue correctly , your system and monitor is fine . The only problem is that the monitor switches off after some time.
If after moving the mouse or taping on the keyboard the monitor comes back . Then we can solve the problem buy adjusting the power settings in the OS .
If the monitor doesn't come back on if you strike the keyboard or click the mouse. Then the problem could be with the monitor.
Depending on the OS you have you can disable sleep by going to the following link
http://www.wikihow.com/Disable-Sleep-Mode
Jun 17, 2010 | HP Compaq WF1907 Monitor
Disable sleep mode for HP w1707 LCD minitor
Read -> this <-guide on how to disable sleep mode/hibernation
Aug 14, 2009 | HP W1707 LCD Monitor
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Monitor keeps going to sleep
In windows click start, control panel, power options. On the first page"when the computer is plugged in" turn monitor off NEVER on the hibernate tab uncheck enable hibernation if checked, also disable sleep mode
May 12, 2009 | Computers & Internet
Disable sleep mode
For XP: Start>Control Panel>Power Options>Click the options you would like under the Power Schemes/Advanced and Hibernate. Vista may be a little different but it is still under Control Panel and Power
Don't forget to rate this solution with 4 diamonds.
Feb 22, 2009 | HP w1907 LCD Monitor
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
Mar 19, 2008 | Computers & Internet
Dell Dimension 8400 PC Desktop Logo
115 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
