Question about Kenmore Heating & Cooling
I have a new kenmore ac unit model 580.75101500 i bought about two weeks ago and installed last week. its been blowing ice cold as it should no problems until today. Now the ac turns on runs about 5 minutes and compressor tries kicking in but wont?
    Problem Solver:
  • 5 Answers
Take it back or call Sears. A 2 week old unit should not do that. I'll assume the settings are right like set on AC Auto or Max cool and not just fan. Are the coils icing or were they icing behind the filter? If not, I think it may need to be serviced.
Posted on Aug 07, 2010
97 Plymouth Breeze won't blow cold air due to freon leak.
Your AC system is a closed system, so the fact you have to put more Freon in, means there is definitely a leak. I would check it out with a mechanic.
Apr 26, 2015 | Plymouth Cars & Trucks
Why does The freezer side stays cold but the refrigerator side gets warm
Your problem is more than likely a defrost issue. There is ice building up in the freezer coils and when it gets blocked with ice the cold air cant blow into the fresh food section. When you shut it off the ice melts and it gets cold again for a few days. remove the freezer back panel and check the defrost heater and defrost thermostat. if they check OK then check the defrost timer. It is best to replace all three components at the same time. This way you will be starting out with new components rather than one failing then the other.
Jul 16, 2014 | Kenmore Side by Side Refrigerator
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
My air conditioner isnt blowing cold air
is the ac a manual one or automatic? if it's manual then it froze and will no longer work. it froze and is all done working. time for a new one. I bought one 12 years ago and apparently I was suppose to turn on and off. The ac couldn't do that. IF it works on it's own maybe the circuit isn't the higher amp for 220 ac units.
Sep 07, 2012 | tranexp.com Computers & Internet
I got my battery changed and immedietly the ice cold AC went to only heat.
may have diconnected a connection to AC unit when replacing battery?? start with this.........also check AC fuse in fuse box,,,could be blown....good kuck and if you find this info helps then please rate my post and thank you in advance..
Aug 16, 2012 | 2005 Chevrolet Silverado 1500
AC sometimes does not blow cold
recharging wouldtn hurt, a mechanic can tell you the level and if needed, but check also your serpentine belt, it might just be loose and worn and not engaging the condenser properly.
Aug 24, 2009 | 1998 GMC Jimmy
Ice cubes coming out with silver (grey) paint specs on them
Do you know exactly what part he changed? It sounds as though it was some sort of water flow regulator, or valve. The service person should have flushed the system prior to installing the part, and replaced the filter.
Without knowing exactly what he changed, it's hard to tell.
Ive heard horror stories where the techs replace ice maker units, and accidentally put the OLD water source filter on backwards instead of replacing the filter, and all of the contaminants end up in the new unit, and in the ice / cold water.
Feb 07, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore Trio Elite 596.75529400
Has anyone got you a solution? I think I have the same problem with mine!
KSheridan
Oct 27, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Heating & Cooling Logo
406 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
